Looking for a light fitting
Nige19/07/2017 19:37:40
370 forum posts
65 photos
The ML4 came with this light fitting but the lamp end is broken and original shade is missing. The bulb holder I can replace with a modern equivalent, along with all the cable but I still need a shade something like the original.
Any ideas on where I might get the shade or a similar light unit complete please ??
Jeff Dayman19/07/2017 19:45:53
1853 forum posts
45 photos
You might be able to buy a cheap lamp with suitable metal shade somewhere like IKEA , use the shade only, or modify the whole lamp to suit use on the Myford bracket. JD
Watford19/07/2017 19:51:27
130 forum posts
11 photos
Have used an aluminium pudding basin very satisfactorily in the past. Plenty on ebay.
Nige19/07/2017 20:15:04
370 forum posts
65 photos
Mike: Thanks, that's a great idea
Speedy Builder519/07/2017 20:59:21
2079 forum posts
145 photos
Nige. Have you tried the forum search facility - try the word "lighting" more good ideas there than you can shake a stick at.
BobH
Nige19/07/2017 21:00:53
370 forum posts
65 photos
Thanks BobH, I had forgotten that option
John Reese19/07/2017 21:39:19
845 forum posts
Try a Google search for lamp parts.
Neil Wyatt19/07/2017 21:45:21
18133 forum posts
713 photos
77 articles
If you use a suitable LED bulb you could 3D print a shade
Mike E.19/07/2017 22:45:27
208 forum posts
29 photos
A little stainless steel bowl with a hole punched in its base could make a very nice reflector.
Hacksaw19/07/2017 23:57:02
428 forum posts
173 photos
If that's bakelight i might have one. Check tomorrow
Martin Connelly20/07/2017 11:26:28
1420 forum posts
165 photos
Due to replacing old machine lights with new LED lights we have some old lights to bin. I have grabbed this.
Any use?
Martin C
not done it yet20/07/2017 11:55:17
4877 forum posts
18 photos
Any use?
Robust, but most certainly I would not be using 240 Volts!
Any good lathe light would be 110V max and more likely only about 35V. A low output-voltage wall wart and LED lamp is the way to go these days, would be my advice.
Martin Connelly20/07/2017 12:01:02
1420 forum posts
165 photos
The writing on the shade was for people who had to replace the lamp. Every machine (lathes, surface grinders, tool & cutter grinders etc.) seemed to have a different voltage and wattage combination so that was the easy way to know what was needed. The replacements are all 12W 24V LED units from RS, very much a safer and far brighter option.
Martin C
Howard Lewis22/07/2017 12:38:39
3536 forum posts
Some of the B C lampholders are designed not to be taken apart. You only find out after wrecking one.
There is a ratchet mechanism that allows it to be screwed together, but not unscrewed. If you can insert a thin screwdriver (Unplugged from the mains, obviously) the two metal "pawls" can be bent away from the teeth moulded into the composite outside, and then it can be disassembled to repair or replace the wiring.
Nige22/07/2017 22:02:43
370 forum posts
65 photos
Martin: yes please 😀 I will message you my address.
EngineDIY
