Airbrush connections?
choochoo_baloo17/07/2017 23:21:00
206 forum posts
28 photos
Evening all.
Are 'hobby' sized airbush connections standardised (e.g. propane cylinder regulators)?
I bought a cheap ebay compressor airbrush set (was going to see how far I could go with it), and now wish to upgrade the airbrush - to the linked Harder & Steenbeck - and am hoping that my existing mositure trap will screw into this airbrush.
https://www.everythingairbrush.com/airbrushes/harder-steenbeck-airbrushes/airbrushes-harder-steenbeck-airbrushes-harder-steenbeck-airbrushes-ultra/harder-steenbeck-ultra-2-in-1-airbrush.html
Any advice gratefully received.
JasonB18/07/2017 07:35:41
17081 forum posts
1839 photos
Most traps and compressors will be 1/4BSP (unless it is a very small compressor) so you will be able to get an adapter from 1/4BSP to H&S and then use an H&S hose
There is a small chance your e-bay brush may share the same thread as teh H&S but without knowing what it is hard to say.
Henry Artist27/07/2017 09:33:47
68 forum posts
46 photos
RDG Tools sell a range of airbrush adaptors. **LINK**
XD 35128/07/2017 08:09:37
1392 forum posts
118 photos
Just gone through a similar scenario but i needed a new air line .
Seems most use the same thread but iwata and a few others use a different one 1/8 bsp i think .
You can get adapters off ebay for most guns although i have a realmcheap gun that uses fittings that are around 5 mm , it is cheap junk but good for priming so i will adapt it to my other fittings .
Any thoughts on paasche guns ?
I have a cheap diaphragm compressor and want to add a small air tank to it , possibly from a small fire extinguisher or gas bottle .
i only use it for my model engines or static models like 1:72 scale models but it seems to work well .
Howard Lewis28/07/2017 08:20:57
2747 forum posts
Whereabouts are you?
I have an empty small tank, used for filling Helium balloons, (stamped for 130 psi) that you can have.
I am in East Anglia. (going to Hereford this Sunday to The WaterWorks Museum via A14, M6, M5 if you wanted to meet en route) PM me if any good.
XD 35129/07/2017 00:37:30
1392 forum posts
118 photos
Hi Howard,
Thanks for the offer im in Australia but there maybe someone reading this that can use it .
