Myford ML4 Rebuild
Nige17/07/2017 16:37:57
370 forum posts
65 photos
I have a new piece of Kitchen Worktop in HPL (High Pressure Laminate) to mount the lathe on. It is about 40 mm thick. Originally the lathe was mounted on two soft wood blocks which were in turn mounted on a softwood plank baseboard. The cantilever bed of the lathe was bolted down with 5/16 bolts passing through the blocks and the base board.
I am at the point in the photo above when I need to decide how to mount the bed onto the new surface. It has been suggested that I use 'proper' machine mounting feet but I am unsure of the type I would use. I presume any such mounting would bolt through the table top and then have some sort of separate adjustment to 'tweak' the lathe bed straight/level etc.
I would appreciate any advice on the way forward from here please
Nige
Bazyle17/07/2017 17:27:16
5694 forum posts
208 photos
Just bolt it down with 3 regular bolts, not 4. That type of bed is designed not to need levelling as it would take a lot of force to twist it with feet that close and on one solid foot.
Nige17/07/2017 22:02:36
370 forum posts
65 photos
Thanks Bazyle I had wondered how much twist you could really get with that sort of construction and an effectively 'light weight' lathe.
Nige19/07/2017 19:29:13
370 forum posts
65 photos
With the new base board fitted to the repainted stand I have started bolting things down. I have been locating the mounting for the motor and motor counter shaft getting it the right sort of distance from the business end of the lathe
Honda VFR 1200 Crosstourer in the back ground
Edited By Nige on 19/07/2017 19:32:02
Nige28/07/2017 16:00:06
370 forum posts
65 photos
A while ago I purchased a Thread Dial Indicator for the ML4. The saddle doesn't come ready drilled so it hgas been a process of checking the location then going through the fitting process.
TDI, bracket and fittings were purchased on eBay
This is where the bracket fits and to mark, drill and tap the holes I dismantled the saddle top from the apron.
Make sure the bracket doesn't rub the dovetail on the way
Mounted the saddle top on the pillar drill clamped up to a piece of angle iron which is the best I can do to ensure it is drilled vertically. Centre punch marks just about visible.
Tapping 4 BA. It was a blind hole which I started with a second cut tap and finished with a plug. WD40 as lubricant as so far it is all I have apart from clean engine oil in the oil can
Saddle top secured back on the apron and TDI fitted. Jobs a goodun
In dismantling the saddle I found that the 1/4/x 1/2 whit slot headed machine screws that fix it to the apron are a bit the worse for wear so I have some hex socket cap headed replacements on order.
EngineDIY
