Questions: Myford ML 10
Ignatz12/07/2017 07:57:20
98 forum posts
55 photos
Just purchased a Myford ML 10 from out of the Netherlands (I live in Belgium). It is in pretty good shape for its age and all tolerances appear to be tight. Only a few little problems to be sorted.
Warning: I’m a bit of a newbie with Myfords, so please bear with me. I’ve experience with metal lathe work (Sheldon, Taig, Unimat), just not with the British made Myford.
Stupid, obvious question first: What wrenches are needed for the Myford? Do I need to purchase a set of British (Whitworth) wrenches to use on the hex head bolts, or will American inch-measure wrenches serve?
A similar question applies to the Allen head screws on the lathe. It sort of seems like metric Allen wrenches fit (??), but can that be correct?
The biggest issue is that prior to my purchase most of the change gears went missing. That means no threading and no auto feed (horrors!). I see that almost all change gears are still available, either from Myford UK, RDG Tools or on eBay. My big concern here is that the splined bush for the center transfer idler gear pair is also missing. I could probably make it with a bit of fussing, but far easier if I could just purchase a replacement. RDG tools offers a change gear stud assembly. Is that what I am looking for?
- **LINK**
Another problem: The lathe came with two Pratt Burnerd chucks. The 4-jaw independent is just fine. The 3-jaw self-centering chuck is missing two out of the three external jaws. Are replacement jaw sets for these chucks to be found? Or is it simpler to avoid the grief and just buy another (complete) 3-jaw chuck for external use?
I see from the literature that a dog clutch was once available for this lathe. I don’t really need to tackle this issue right away, but it would be quite useful to have in the future. It doesn’t appear to be so very difficult to machine such, but are there any plans or literature available to help me with this?
Any other tips or pointers gratefully accepted.
Edited By Ignatz on 12/07/2017 07:58:20
Clive Hartland12/07/2017 08:39:50
2502 forum posts
40 photos
Maybe the missing bush is still in one of the missing gears? You are still needing retaining washers and screws for the gears anyway.  There should also be another bolt and spindle for the fitting of 2 gears. .Do the mod. to the cross slide spindle as well.
Clive.
Edited By Clive Hartland on 12/07/2017 08:45:15
Ignatz12/07/2017 08:43:36
98 forum posts
55 photos
That is probably true. Sadly, the change gears were already missing when the previous owner purchased the machine.
Clive Hartland12/07/2017 09:13:43
2502 forum posts
40 photos
The cross slide spindle bearing mod. is from Arceurotrade. Is the lathe metric or imperial? Clive
Hopper12/07/2017 10:11:11
3968 forum posts
84 photos
You will need Whitworth or BS spanners to fit the nuts and bolts on a Myfrod. American AF spanners will not fit.
But ordinary American AF Allen keys will fit the Allen head bolts on the Myford.
No metric fasteners on the machine that I know of, unless fitted by previous owner etc.
Note too that many of the smaller threads such as oil nipples and gib adjuster screws are BA threads. The hexagon nuts on the gib screws use a Whitworth/BS spanner though and the oil nipples a small BA spanner (AKA shifting spanner in my shed.)
I havent come across a standard dog clutch for the Myfords but have not extensive experience with them. But Martin Cleeve's book Screwcutting in the Lathe has plans for a shop-made screwcutting dog clutch that could be handy if doing a lot of screwcutting but not really needed for occasional use.
Jim Guthrie12/07/2017 11:23:44
92 forum posts
5 photos
Ignatz,
The two open ended spanners supplied with the plain bearing ML10 were
1/4"BSW:5/16"BSF + 3/16"BSW:1/4"BSF
5/16"BSW:3/8"BSF + 3/8"BSW:7/16" BSF
I can't remember ever having to look for another spanner for my ML10 in 40-odd years. smiley
The Allen keys required were Imperial and there is one special one to use on the cap head screw holding the locking dog on the bull wheel. It has its end at around 70 degrees rather than the normal 90 degrees and is shorter than normal. This lets you get at the screw in behind the front headstock bearing.
Another mod you might consider is fitting a calibrated ring to the leadscrew handle so that you can move the saddle by known, accurate amounts. If you do this, you will need a leadscrew clutch to avoid having to put your gearing out of mesh when using the hand wheel. There should be a groove ground round the leadscrew which showed where to cut the it for the Myford clutch.
I note that one of your lathe's previous owners did what I did, and fitted wick fed lubricators requiring a cut out on the belt guard. smiley
Jim.
Edited By Jim Guthrie on 12/07/2017 11:25:35
Ignatz12/07/2017 15:24:39
98 forum posts
55 photos
Thanks for the feedback on which spanners I will need to purchase. Likewise the Allen keys.
I already noticed what an incredibly tight fit there is around that bull wheel locking dog. I figure to take a normal Allen key, cut it short and TIG weld it to a proper handle.
Robbo13/07/2017 23:38:43
1504 forum posts
142 photos
If you look through the pictures in this link, there are some clear views of the leadscrew clutch - **LINK**
Chris Evans 614/07/2017 07:39:37
1565 forum posts
Google "Rotagrip" a UK supplier based in Birmingham for the chuck jaws. It may though be cheaper to buy a complete chuck. I have a 160mm Pratt Burnerd three jaw and the jaws cost around £180 Brittish Pounds.
Mike14/07/2017 10:20:42
713 forum posts
6 photos
Thanks, Chris, for the tip to Google for Rotagrip. However, their prices! For some time I have been looking for outside jaws for a 4in for a 3-jaw Pratt Burnerd. They want £149.04. I know we have to pay for quality, but a complete chuck of Indian origin from ARC Eurotrade costs a lot less than that, and would be quite accurate enough for my purposes.
Ignatz14/07/2017 12:03:58
98 forum posts
55 photos
Yes, I did see that Rotagrip offers those jaw sets, but - 'ouch!' - the price hurts. Buying a second complete 3-jaw chuck, if even just to use for the external jaws, seems more realistic.
Ignatz14/07/2017 12:04:33
98 forum posts
55 photos
Robbo, thanks for that link to the ML 10 pix.
Ignatz14/07/2017 12:07:26
98 forum posts
55 photos
By the way, does anyone have a link to somewhere that offers a small, pump oiler for the fitting on the main spindle pulleys?
Myford UK sells one, but that is nearly ?70.
Does one have to have such a pump or is there some other way to inject oil into that fitting?
ian j14/07/2017 13:47:21
278 forum posts
249 photos
Pump oilers are available from here:-**LINK**
NJH14/07/2017 13:49:03
2314 forum posts
139 photos
Hi
The lead screw clutch is pretty simple to make and it is very useful.
I knocked this one up quite quickly. I don't recall the dimensions now but I worked it out from measuring the machine.
The nut holding the bottom of the lever is a locking one and it is tightened just enough to allow easy movement. The collar at the left retains the short end of the (cut) lead screw. The lead screw has a groove at the point it is split and the LH mounting bolt provides a convenient place for the pivot to be located. The two pins are made from steel rod and threaded to fit the two points in the lead screw. Sorry I can't give dimensions as I don't have the machine now having swopped it for a S7 some years ago.
Good luck!
Norman
Ignatz14/07/2017 16:21:29
98 forum posts
55 photos
ian j, thank you for the link. Your a prince, sir.
Likewise a tip of the hat to you, Norman. It looks simple enough to machine. But I'll have to leave that as a future project for after the rest of the lathe setup is sorted.
ChrisB31/01/2019 11:57:07
449 forum posts
175 photos
Wondering if such a dog clutch could be applied to a WM280 and similar lathes...the lead screw connection look similar - any one tried this before?
Mick B131/01/2019 14:00:04
1357 forum posts
75 photos
Posted by ChrisB on 31/01/2019 11:57:07:
I think it'd be quite a lot of work - though I'm thinking from the WM250V point of view, not 280.
You'd have to lose or substantially mod the telescopic leadscrew cover to make room for it.
Plus the only reason I can think of for doing it - the purpose I used it for when I had a Speed 10 (ML10 derivative) - is to have a handwheel and dial on the distal end of the leadscrew for precise setting of saddle position. But if you add one o' them, you'll then be stuck with manual crossfeed for facing or milling unless you can be sure to remember to lock the saddle and disengage the halfnuts before re-engaging the dogclutch. All seems a bit much to hold in the head to me, with a bit higher risk than I generally like.
Tim Stevens31/01/2019 14:51:40
1123 forum posts
A dog clutch as shown above would have an added advantage. It would be very easy to add an adjustable rod, running leftwards from the saddle, which would disconnect the clutch at a set position. This would enable you to cut threads without the worry of overshooting. So, I'm going to have a good look at my ML7 to see if I could make something up.
Regards, Tim
clivel31/01/2019 15:51:49
288 forum posts
12 photos
Posted by Ignatz on 14/07/2017 12:07:26:
A cheap alternative is to use a 16 Gauge blunt tip dispensing needle fitted to the end of a regular oil can. Searching on eBay will turn them up for a mere dollar or two including free shipping from China.
I am still waiting for the tips to arrive that I ordered from an eBay seller a few weeks ago, so can't personally vouch for the method, but if the above video is anything to go by this definitely seems to be the cheapest way of oiling a Myford.
