Retaining washers?
mick H10/07/2017 13:33:51
705 forum posts
21 photos
What are those washers called that one pushes on to a shaft and which will retain their position? I think that there are two types. The first have two or more sprung tabs and the second type is a bit like an inside out star washer. This is a bit of a clumsy description but hopefully someone will recognise what I am after.
I need them to fit a 3/32" shaft.
Thank you in anticipation
Mick
Nick_G10/07/2017 13:38:59
1808 forum posts
744 photos
Do you mean C clips. ??
Nick
Juddy10/07/2017 13:57:41
65 forum posts
circlip??
Clive Brown 110/07/2017 14:00:49
318 forum posts
7 photos
Starlock?
Or Starlock push-on.
Edited By Clive Brown 1 on 10/07/2017 14:02:01
Martin W10/07/2017 14:06:22
811 forum posts
29 photos
Hi
There is a star washer that does what you describe and they can be seen here.
PS
Looks like Clive beat me to it blush
Edited By Martin W on 10/07/2017 14:07:59
edit to remove location error
Edited By Martin W on 10/07/2017 14:10:13
Martin W10/07/2017 14:18:15
811 forum posts
29 photos
Hi
A quick search on ebay for Starlock produces a good selection of retaining washers, end caps, etc. in both metric and imperial sizes.
Martin
mick H10/07/2017 14:30:09
705 forum posts
21 photos
Starlocks are the ones. Thank you very much gents.
Mick
Neil Wyatt10/07/2017 20:25:43
17070 forum posts
690 photos
76 articles
There's a different type of spikey nut designed to be pushed into a tube allowing a bolt to be fitted. They used to be popular for mountain bike stems before more elegant alternatives were designed, and are still used on cheapies.
They glory in the name of 'star-fangled nuts'.
Will Bells10/07/2017 21:38:37
152 forum posts
7 photos
Hi Mick
I believe that the generic term for them is Push-On Fix. Starlock is one brand.
Cheers - Will
larry Phelan11/07/2017 10:53:50
544 forum posts
17 photos
Never knew what they were called,used to see them on prams years ago. Must check them out,could be very useful things to have around.
Howard Lewis11/07/2017 14:10:15
2731 forum posts
Have to admit that I don't like the, for two reasons.
1) They can work loose, but then still cannot be removed.
2) Being non removeable, cannot be reused , once mangled to remove.
Wherever possible, like the Luddite that I am, resort to drilling through the shaft and then using a washer and split pin.
