Live steam Globe valves
Ron Hancock05/07/2017 11:29:44
526 forum posts
95 photos
hi can anyone suggest a good steam Globe Valve. I have bought several from different suppliers but seem to seal for a very short time. I need a 3 1/6 pipe fitting to supply my Injector had new one fitted only two weeks ago it's already seeping
Ron
steamdave05/07/2017 11:47:16
426 forum posts
33 photos
Have you tried the PM Research globe valve? 1/4" x 40 thread available from Forrest Classics
http://www.forest-classics.co.uk/pm_research_sw-4.htm#Globe%20Valve
or if you fancy machining your own from castings, have a look at PMR
https://www.pmmodelengines.com/shop/pipe-fittings/globe-valve-kits/
They are easy to make up.
The Emerald Isle
JasonB05/07/2017 11:49:04
17073 forum posts
1839 photos
Ron, most globe valves have a right and wrong way round. You need to get them in the right. see here right way round for steam
J
Edited By JasonB on 05/07/2017 12:23:11
Henry Artist06/07/2017 09:12:51
68 forum posts
46 photos
I have found the valves supplied by GLR Kennions to be very good quality. **LINK**
Sometimes, after a lot of use there can be a tiny leak at the valve stem but it is a simple matter to replace the graphite string packing. You may also like to experiment with O rings.
Alternatively, you may want to try the valves sold by Bengs Modellbau. **LINK**
They are made by Winfried Niggel and are rated to 6 bar.
