Mick Henshall | 01/07/2017 19:26:24 |
![]() 561 forum posts 34 photos | Hi folks----can anyone give me the overall dimensions (height x depth x width) of shaper so I can see where I can fit in workshop, I have trawled internet but no luck so far, just bought from Home & Workshop Machinery and waiting delivery, its the under motor version Cheers Mick |
charadam | 01/07/2017 19:50:51 |
185 forum posts 6 photos | Doesn't have the dimensions, but the manual is here: http://neme-s.org/Shaper%20Books/Boxford%20Shaper/Boxford%208%20Inch%20Shaper.pdf I had the machine a few years ago and the space claim was about 1000x600 - but you have to allow ram space at the rear. Hope this helps.
Mick Henshall | 01/07/2017 20:05:13 |
![]() 561 forum posts 34 photos | Cheers have the manual but so far not found footprint,am excited been chasing a shaper for years but always pipped at the post but this time been lucky, much underated machines but getting more popular now Mick |
charadam | 01/07/2017 21:02:53 |
185 forum posts 6 photos | I agree that shapers are very underrated, which is why I had one. I was trained on a big'un in the late 60s and learned to appreciate - and respect - them. However, when I built my workshop the plan was to stop myself from owning too many machines. The space is 10' x 9' and contains a bench, a Chipmaster lathe and Boxford mill. As well as a surface plate, 2 reloading benches, 2 Bisley tool drawer cabinets plus materials storage etc. There is also some clutter! The Boxford mill is why the shaper had to go, but I still miss the surfacing capability as well as the gear cutting, and dovetailing with inexpensive tooling.
Nick Taylor 2 | 01/07/2017 21:31:14 |
102 forum posts | Hi Mick, just been out to the garage with a tape measure; Cabinet is 18 inch wide and I have mine so the front of the cabinet is 40 inch from the wall to allow for full rear movement of the ram. You could maybe get away with less. Also remember you'll want the left hand side of the machine in the 'open air' so you can get into the motor compartment easily, and obviously its the safest and easiest place to run the machine from. cheers |
Mick Henshall | 01/07/2017 22:12:33 |
![]() 561 forum posts 34 photos | Nick thats just what I needed thank you for taking the time to help Mick |
Steve Pavey | 02/07/2017 09:23:53 |
361 forum posts 41 photos | Out of interest I just measured mine, which is also about 40" away from the wall, the same as Nicks. I like the idea of 'open air' on the motor door side of the cabinet, but that's a bit rare in my workshop. Any serious work on the motor and I have to move it forwards (on a couple of bits of ½" pipe). No need to bolt it down. |
Mick Henshall | 08/07/2017 07:25:31 |
![]() 561 forum posts 34 photos | Shaper arrived Thursday, all stripped down on Friday for a clean, its 3 phase but have a single phase 3/4 hp motor runs at 1440 rpm I am going to use instead, does anyone know where I can get an exploded parts drawing ? Been looking for one of these for ages feeling like a kid in a sweetshop Apologies photo designed to give you neck ache Edited By Neil Wyatt on 08/07/2017 11:42:44 |
Mick Henshall | 08/07/2017 08:43:32 |
thaiguzzi | 08/07/2017 09:17:13 |
![]() 704 forum posts 131 photos | Very clean. Hope you got the vice with it. Also leave enough access to the door for stroke adjustment. Unlike others posted above, mine is stroke adjustment door side against the wall, just enough space to get at it. |
John Hinkley | 08/07/2017 09:39:49 |
![]() 1298 forum posts 423 photos | I can't help with the exploded diagram, but I do have a pdf of the operator's manual. It has metric equivalent dimensions and capacities which look as if they've been inserted after publication. PM me if you don't already have it and would like a copy. John |
Gray62 | 08/07/2017 10:33:19 |
1057 forum posts 16 photos | Mick, I've never found a proper exploded parts diagram however, there are some drawings on the boxford spares site which may be of some use to you. They are a relatively simple machine, there are a number of us on here that have this machine so, If you have questions, ask away and I'm sure one of us will be able to help |
Mick Henshall | 08/07/2017 10:36:29 |
![]() 561 forum posts 34 photos | Hi John, Â thanks I have the pdf, tguzzi- yes I will got to find the best place for it before I start putting it back together and no didn't get the vice, saw one for £275 (ouch!!) So will use a milling vice for now and maybe make a low profile one later Mick |
Mick Henshall | 08/07/2017 10:41:31 |
![]() 561 forum posts 34 photos | Thanks Graeme will have a look, just got the electics out, going to drop motor assembly so I can fit replacement motor single phase don't know if I can use existing 440v switches or have to put 220v switches in Mick |
Mick Henshall | 08/07/2017 10:44:55 |
![]() 561 forum posts 34 photos | Graeme, had a quick look at spares site just what I need I am much obliged Mick |
OuBallie | 08/07/2017 16:02:56 |
![]() 1164 forum posts 662 photos | Mick, You will be mesmerised by it's action, BUT do, however, fit a guard on the front to deflect the blue swarf that flies off, onto the tray. Mine with DIY handles Geoff - Day off organising Ruby repairs photos |
