Neil Wyatt | 20/06/2017 09:07:54 |
![]() Moderator 16740 forum posts 689 photos 76 articles | Yesterday I accelerated hard up to 60-70 to overtake a lorry after leaving a roundabout, the car pulled well, but when I changed up, there was no 'drive'. Basically the clutch feels normal, and I could select any gear but the engine just raced as if in neutral. There were no nasty bangs, no strange noises afterwards. I managed to coast to a slip road and the AA got me the 42 miles home (only taking 10 hours and a change of pickup) from 4pm to 2 am. It all seems to sudden to be clutch wear, the web is full of 'it could bes' but I need some advice of deciding what problem it really is, I can see three possibilities;
Anyt advice on deciding which it might be? I need to figure out if its a write off, expensive job or a DIY (probably only the drive shaft) Neil |
Jonathan Garside | 20/06/2017 09:16:36 |
41 forum posts 3 photos | Neil What make and model is the car and current mileage would be helpful. Not saying I can help but others with similar cars may be able to Jonathan |
Hacksaw | 20/06/2017 09:18:28 |
419 forum posts 173 photos | Get over to Autoshite forum , ask them . They'll have it sussed and fixed within the hour ! |
DMB | 20/06/2017 09:19:36 |
932 forum posts | 1 Dump AA 2 Find new, much cheaper breakdown outfit - some do home start and roadside for £40+ 3 Hope jamjar goes better now John |
RRMBK | 20/06/2017 09:27:00 |
128 forum posts 18 photos | Not up to speed on modern cars but had a not dissimilar problem on a tractor where the central splined section of the clutch plate broke away from the friction disc. No obvious nasty noises but the friction disc was spinning with the flywheel but had no connection to the gearbox input shaft which remained static. One test might be to see if the car can be rolled back or forward whilst engaged in gear. good luck. |
David Jupp | 20/06/2017 09:27:57 |
701 forum posts 17 photos | Had something similar on a front wheel drive Vauxhall - it was just a circlip dislodged that allowed the first motion shaft to retract from the clutch (as per design when changing clutch without removing gearbox). Really need to know make/model, or at least FWD / RWD... |
ChrisB | 20/06/2017 09:28:18 |
429 forum posts 171 photos | Check the gear linkage or cable, could have disconnected in neutral and give you the symptoms you mentioned |
not done it yet | 20/06/2017 09:34:49 |
3553 forum posts 15 photos | What does the gear stick do? If it is a PSA gearbox, it could be the selector mechanism. Had two that failed in the same mode. Cheaper to change the box than repair, in my case (high mileage and box needed to come apart for new expensive bits in an older vehicle), as a second hand box was easily sourced. Unfortunately the replacemment went the same way. |
David Standing 1 | 20/06/2017 09:53:35 |
1280 forum posts 46 photos | Ten hours to get home? Super Adept Man could have flown that in a nanosecond! But seriously, per post #2, more details of the car required |
Hacksaw | 20/06/2017 10:01:15 |
419 forum posts 173 photos | Does Neil drive a Mitsubishi Space wagon? |
John Stevenson | 20/06/2017 10:03:28 |
![]() Moderator 5068 forum posts 3 photos | Pretty sure he has a Mondayo |
Speedy Builder5 | 20/06/2017 10:22:36 |
1840 forum posts 128 photos | Oh you can't go to heaven in an old Ford car, |
peak4 | 20/06/2017 10:32:39 |
![]() 901 forum posts 85 photos | I don't know much about modern cars, but I'll have a guess at a blown CV or a circlip popped off a driveshaft allowing it to disengage. Any pools of oil underneath? |
Hacksaw | 20/06/2017 10:32:52 |
419 forum posts 173 photos | You can in a Ford Orion.. |
Gordon W | 20/06/2017 10:51:43 |
2011 forum posts | Well I'll have a guess at broken prop-shaft , no noises etc. |
David Standing 1 | 20/06/2017 10:59:13 |
1280 forum posts 46 photos | Posted by Gordon W on 20/06/2017 10:51:43:
That'd be interesting, it's FWD if it's a Mondeo |
Cornish Jack | 20/06/2017 11:06:18 |
953 forum posts 134 photos | It's obviously caught the 'gearbox disease'!! I hope your problems will be simpler (and cheaper ) to fix, Neil. rgds Bill |
ega | 20/06/2017 11:11:15 |
1333 forum posts 109 photos | Neil's AA experience contrasts strongly with their current advertising but worse things happen: yesterday I was told about an acquaintance who set off to drive the seven miles from north London to a central location for dental treatment allowing two hours for the journey; arriving ten mnutes late, they were told they could not be seen that day! Good luck with the car - a broken halfshaft on an Austin Seven could have been fixed at the roadside. |
Gordon W | 20/06/2017 11:18:33 |
2011 forum posts | Well, live and learn. How do FWD get the power to the wheels ? Now I see-- prop shaft / half shaft. |
David Standing 1 | 20/06/2017 11:25:27 |
1280 forum posts 46 photos | Posted by Gordon W on 20/06/2017 11:18:33:
Gordon The generally accepted terminology is with RWD - prop shaft and half shafts; with FWD - drive shafts. |
