Lunokhod
Russian Moon Rover
Neil Wyatt17/06/2017 14:51:47
17109 forum posts
690 photos
76 articles
Using the plans here: spacemodels.nuxit.net/lunokhod/lunokhod.htm for a 1:10 scale model of the Russian lunar rover Lunokhod 2, I've created an STL version of the simpler Lunkhod 1 (basically adding all the extra sensors and cameras would drive me completely round the bend).
It's probably the ultimate cyberpunk machine with the appearance of a robotic toilet on wheels.
I've obviously left out a lot of small detail and made a lot of the thinner parts oversize with a minimum print size of 1.2 mm diameter, which has allowed me to print out the bits at 1:20 scale with a minimum diameter/thickness of 0.6mm. I've mostly limited things to 0.8mm unless they are well supported and used 1mm square for many trusses that should really be only about 0.5mm round.
I just need to fit the spectrometer to the front then try and print out the four low-gain antennae, which will be a challenge as they are 35mm long and mostly only 0.8mm diameter.
I'm accepting the shortcomings of 3D print, rather than adding non-3D printed parts, as it want to explore both the capabilities and limitations of the technique.
Unfortunately it's a bit fragile. Shame I haven't got a bigger printer, it would be impressive and more robust at 1:10!
Photos of the model, unpainted, to follow.
V8Eng17/06/2017 15:25:10
1338 forum posts
28 photos
Ah so that's what a naked Dalek loks like then!winksmiley
Those wheels look tricky to print.
Edited By V8Eng on 17/06/2017 15:27:18
NJH17/06/2017 16:16:06
2314 forum posts
139 photos
I think you need a holiday! teeth 2
Norman
Neil Wyatt17/06/2017 18:30:52
17109 forum posts
690 photos
76 articles
This is a half-size museum model.
Neil Wyatt17/06/2017 18:42:19
17109 forum posts
690 photos
76 articles
Posted by V8Eng on 17/06/2017 15:25:10:
The wheels printed really well, they are small enough that the over-thickness and simplified spokes 'bridged' fine, but there was a lot of stringing to get rid of, took a while to clean up all eight! They are remarkably strong.
MW17/06/2017 20:36:31
2050 forum posts
51 photos
PLA is a lot stronger than I thought it would be.
Michael W
Neil Wyatt17/06/2017 21:06:39
17109 forum posts
690 photos
76 articles
There's a site that tested 30 filaments and found PLA generally stronger than other plastics despite the being theoretically stronger. I suspect it fuses together particularly well if you get the settings right.
Neil Wyatt18/06/2017 19:44:15
17109 forum posts
690 photos
76 articles
Some photos of the model
Hacksaw18/06/2017 20:19:01
425 forum posts
173 photos
As kids we laughed at that . It was pictured on a PG tips card if i remember? We ,(well ok, the Americans ) had a great looking 2 seater go kart , lunar rover , and the baddies came up with a soap box boiler !
Neil , there's a guy on the Porsche forum printing replacement 911 speaker housings https://www.impactbumpers.com/forum/index.php?/topic/30246-rear-speaker-grills-87-coupe/
Edited By Hacksaw on 18/06/2017 20:23:43
V8Eng18/06/2017 20:33:25
1338 forum posts
28 photos
Nice work Neil, some finely finished small parts on there as well.
Neil Wyatt18/06/2017 20:56:29
17109 forum posts
690 photos
76 articles
Posted by Hacksaw on 18/06/2017 20:19:01:
Neil , there's a guy on the Porsche forum printing replacement 911 speaker housings **LINK**
The final porsche part is impressive.
Lunokhod looks completely whacko, but once you understand how it's put together it's a clever design. Most people (and the model imaged above) don't show that BOTH inner faces of the 'clamshell' had solar panels (plus extra ones on the bits that stick out). It closed up for 14 days in every 28 and the thing at the back that looks like a radar dish pointed at the ground is a radioisotope heat generator that stopped it freezing.
Neil Wyatt07/08/2017 14:41:30
17109 forum posts
690 photos
76 articles
I anyone fancies a go a printing this, the STL files are now here:
www.stubmandrel.co.uk/model-engineering/150-print-your-own-lunokhod-model
Now I have to paint the darn thing!
Henry Artist07/08/2017 21:01:41
68 forum posts
46 photos
What a splendid model! Congratulations Neil. face 1
Moonwalker 1 (8EL#203) was an extremely successful mission. Originally intended to operate for 3 lunar days it actually operated for 11 lunar days. It still has value today. Though the mission ended in 1971 it was "rediscovered" in 2010 and found to be the brightest reflector on the moon thus allowing very accurate laser range-finding of Earth - Moon distance.
Will you make a model of the Luna 17 lander?
Neil Wyatt07/08/2017 21:45:18
17109 forum posts
690 photos
76 articles
Posted by Henry Artist on 07/08/2017 21:01:41:
Tempted...
Simon Williams 307/08/2017 23:02:28
450 forum posts
75 photos
So THAT'S what the Soup Dragon was using!
Neil Wyatt08/08/2017 12:23:00
17109 forum posts
690 photos
76 articles
Posted by Simon Williams 3 on 07/08/2017 23:02:28:
I think it looks pretty darn steampunk! Just needs a chimney...
