Forum sponsored by Allendale May 23
Beware Melting Connectors on RAMPS boards
Neil Wyatt02/06/2017 11:55:58
15990 forum posts
674 photos
73 articles
Just a warning to anyone making any type of 3D printer using a RAMPS board.
Check your power connector plug - it seems that despite being rated between 12 and 15 amps they overheat easily and melt with obvious risks. Just google 'ramps power connector melted'.
I had a problem with a loose nozzle causing a PLA leak and discounted the smell as burning PLA., when it was actually the connector frying.Luckily it went open circuit as the dodgy connection filled with molten plastic/gummed up with char. It would not have been nice if it has shorted instead - the dividers between the plugs had largely disappeared.
This problem seems to be common to all types of machine as the connector is a standard p[art of the RAMPS board. Prusa themselves say it is caused by not tightening the connectors suffciently. On my connector the wires were so solidly locked in the ferrule they wouldn't pull out, it was poor contact between the pin and socket - as evidenced by the location of melting and scorching, which was away from the screwed connections.
I have replaced my power connections with soldered ones, there are spade connectors in the power lead and these are showing no signs of warmth.
I am also considering putting automotive fuses in the power leads as the ones on the RAMPS board are after the connector.
Nick Hulme05/06/2017 20:26:58
682 forum posts
37 photos
Neil,
Thanks for posting this info, I've ordered a 25A DC-DC Solid State Relay for the princely sum of a tenner to take the heated bed load off the control electronics before I do any long print runs,
- Nick
john swift 105/06/2017 22:48:37
316 forum posts
180 photos
part of the problem is the number of fake / cheap copies of components in the supply chain
the original 1/4" blade connectors used in my mini lathe are made of a too a soft metal
once un-pluged and plugged back in they didn't have enough contact pressure and had to be replaced with connectors made by Lucas ( supplied by my local Motor Factors)
searching for SSR-25 DA 25A solid state relays , I found fakes being sold that only had a 12A triac inside !!!
http://www.ul.com/newsroom/publicnotices/ul-warns-of-solid-state-relay-with-counterfeit-ul-recognition-mark-release-13pn-52/
https://www.youtube.com/watch?v=DxEhxjvifyY
shows whats inside the fake  ssr
Edited By john swift 1 on 05/06/2017 22:52:50
MW05/06/2017 22:56:18
2050 forum posts
51 photos
I probably have the same one, as I have a different model to the prusa, but it's made by the same Chinese people who originally designed the prusa, I believe they explicitly said on the ebay page of mine, that the board really needs some kind of extra forced cooling to what it comes with if you expect it to work hard!
Depending on how the soldering went, maybe a different connector or the amount of solder used is now dissipating more heat!
Michael W
Edited By Michael-w on 05/06/2017 22:57:41
Neil Wyatt06/06/2017 10:27:01
15990 forum posts
674 photos
73 articles
Posted by Michael-w on 05/06/2017 22:56:18:
The soldering appears fine, it was definitely a poor connection in the plug.
The design of the printer I bought included a small fan blowing directly on the lower part of the RAMPs. it includes a bracket to install another fan aimed at the top, I haven't found this necessary although I have a second fan ready to fit.
Andrew Johnston06/06/2017 10:39:23
4650 forum posts
522 photos
Posted by john swift 1 on 05/06/2017 22:48:37:
Quite so. One of the issues I had with my Tormach CNC mill was an intermittent spindle run problem. I eventually traced it to an 'industrial' push on connector on the control board. The exact same connector, but from a reputable industrial manufacturer, was available from Farnell. I've had no issues since changing the connector. The original connector mated with barely any force needed. The replacement connector needed a significant push to mate.
john swift 106/06/2017 11:38:23
316 forum posts
180 photos
Hi Andrew
it was only last week I read a post on CNCZONE about the same problem with a   Leadshine  3ND883  three  phase stepper driver used on a Tormach CNC machine !!
the connectors are used on a large number of drivers from a variety of manufactures
Edited By john swift 1 on 06/06/2017 11:41:38
Neil Wyatt06/06/2017 14:40:51
15990 forum posts
674 photos
73 articles
The green connector at bottom right is a five-pole version of the 4-pole one on a RAMPS.
By any chance is that the one that gives trouble?
john swift 106/06/2017 19:24:28
316 forum posts
180 photos
Hi Neil
yes that's the one in the CNCZONE post that's burnt - not mine I'm glad to say !
going by the Leadshine manual its W phase that drives the stepper motor
the same connector is used on some of the infamous TB6560 stepper drivers
( but not the version that featured in Carl Wilson's Arduino controlled Indexer published in the December 2016 issue of MEW )
Zebethyal07/06/2017 14:52:31
188 forum posts
Posted by Neil Wyatt on 02/06/2017 11:55:58:
Even with a 15A rating, you may be exceeding that on a typical 3D printer with a heated bed:
  • Heated bed - aproximately 10A
  • 40W 12V cartridge heater - 3.3A
  • 4 x Nema 17 steppers - about 3A
  • Nema 17 stepper for extruder - 1A
In total around 17A
Sanguinolo board also has issues with heated bed traces melting, so I offboarded the control of my heated bed.
(Sanguinololu is effectively a Mega + Ramps with a 644 or 1284 chip, but in a much smaller footprint)
Neil Wyatt07/06/2017 18:34:57
15990 forum posts
674 photos
73 articles
Posted by Zebethyal on 07/06/2017 14:52:31:
In total around 17A
I think the connectors are rated 15A per way rather than total i.e. 60A total
Your sums give a total current of 34A - as it comes back out again on the ground pins.
Either way it's a lot to put through a small connector.
Andrew Johnston07/06/2017 19:57:39
4650 forum posts
522 photos
Posted by john swift 1 on 06/06/2017 11:38:23:
Hi Andrew
The problem I had was with a connector on the Tormach custom control board, the green connector bottom right:
Although not obvious the PCB part is a header with round pins. The mating half, with the wires, slides over the pins. The circuits are all low current. The problem was poor contact, rather than related heating, due to low insertion force and possibly poor spring contact design.
Changing both halves solved the problem. I also changed the similar connector top left, just to be safe.
Edited By Neil Wyatt on 08/06/2017 07:37:42
john swift 108/06/2017 00:19:50
316 forum posts
180 photos
Hi Andrew
the connectors look like the ones used by Gecko Drive on their stepper drivers (G540 for example)
and your control board looks like its a version of the boards from Campbell designs / Sound Logic Combo Board
http://www.campbelldesigns.com/Combo-board.php
Edited By john swift 1 on 08/06/2017 00:24:44
Zebethyal08/06/2017 07:53:59
188 forum posts
Posted by Neil Wyatt on 07/06/2017 18:34:57:
In total around 17A
I was thinking more of 17A in on the +ve and 17A out on the -ve power connectors, so still exceeding the 15A per way limit.
But I also think we are violently agreeing with each other.
Neil Wyatt08/06/2017 09:34:23
15990 forum posts
674 photos
73 articles
Posted by Zebethyal on 08/06/2017 07:53:59:
I'm sure we are, but on a standard RAMPS the supply is split across four pins, two 12V two 0V theoretically 1the biggest current is the heater supply at 10A/way.
John Stevenson08/06/2017 10:10:09
5068 forum posts
These are the same type of connector that leadshine have been fitting for years. When I was over in China at the Sieg CNC factory which has nothing to do with the manual machine factory, I noticed they used a gun,similar to a cheap cable splicer that fitted over the pins and gave the pin a toggle making it a harder push fit.
We obtained one when over there or rather they got us one as they must be a commercial unit but not seen them anywhere else.
Result being that when we do rebuilds or new conversions we have never had a problem.
John Swift, I can positively say that the Tormach board is a dedicated board, designed in China and produced exclusively for Tormach.
This board came about as the mill needs encoder input for rigid tapping and the lathe requires similar for threading.
Non of the Western boards at that time could offer this and presently only the Pokeys57CNC can do this but only with Mach4 which after 6 years is still a work in progress.
Edited By John Stevenson on 08/06/2017 10:12:37
TRANSWAVE Converters
