Help from any Kennedy Hexacut Power Hacksaw owners out there?
Russ B15/05/2017 13:50:46
599 forum posts
26 photos
Can someone please measure the diameter of large driven flat belt pulley and read off the motors rpm if legible? - I gather the motor's shaft was used directly as the driver pulley so I can measure that.
I'm over the moon to have picked up a model 60 (I guess) as I've been wanting one for years. Its missing its driven pulley, and needs a good strip and clean.
I've got a handful of Vee pulleys sitting about so I'd like to use these, however given that the original arrangement used the motor's spindle directly, to drive quite a large pulley, I think I'm going to struggle to get the reduction I need inside the standard guarding which I would like to try and retain because its quite nice!
In addition, the standard 1/6 horse motors are known to be feeble, so ideally, I'd like to achieve a slightly higher reduction than standard or run a lower speed motor which then gives me ample room under the standard guarding. If say the motor is a pretty standard 2 pole 2700-3000 rpm, I should be able to easily source a little 4 pole and halve the speeds.
I'd be grateful of any advice, tips, parts diagrams, manuals or a word from anyone who shares an interest in these.
All the best,
Russ
Chris Shelton15/05/2017 14:31:54
92 forum posts
46 photos
Hi Russ,
Motor RPM is 1425, large driven pulley is 149.05 mm and motor pulley is 20 mm in diameter.
I have some instructions in PDF I will try and send them via private message.
Sorry Russ can't see a way of attaching pdf files to PM
Will try and create an album with them
Sorry that failed, is it ok to include them in this posting, perhaps mods could advise.
HTH
Chris
Edited By Chris Shelton on 15/05/2017 14:38:01
Edited By Chris Shelton on 15/05/2017 14:47:04
michael cole15/05/2017 15:30:19
163 forum posts
As this question has been answered i will ask , i have a slipping belt on a model 60 is there any way to tension it .
Chris Shelton15/05/2017 15:41:20
92 forum posts
46 photos
Michael, I think the original belt was slightly elastic, I manage to find an automotive ribbed belt, which I turned inside out, and this has been working OK.
HTH
Chris
Clive Foster15/05/2017 16:30:01
2675 forum posts
96 photos
Chris / Michael
The automotive ribbed "serpentine" belts actually work better rib side down on flat belt pulleys rather than inverted. Ribs squidge a bit so there is some length tolerance.
The one we had at work used a Stephens Miraclo (spelling!) glass fibre backed leather belt which worked a treat for the 20 years i knew of it! Might have shut down by now tho'. Some of the plastic types may be OK but I know the yellow one supplied for my Clarkson grinder would be too stretchy.
Clive.
Edited By Clive Foster on 15/05/2017 16:30:21
Russ B15/05/2017 17:39:05
599 forum posts
26 photos
Chris,
Thank you for taking the time to measure, I have sent you a private message with my email address.
Regarding belt tension, the holes for the motor are drilled, but I believe the whole machine is on slotted holes, so you can tension the belt this way.
Robbo15/05/2017 19:36:00
1504 forum posts
142 photos
Chris
Are your "Instructions in pdf" from the original 2-page description and general maintenance instructions?
If not I can send these to Russ, and yourself.  Will need email addresses, as this forum will not accept files in pdf format, only jpeg.
I have sent this pdf to so many people I have lost count. You can't beat spreading the word, even though it is a brief word.
Regarding tensioning the belt, this is done by loosening the two bolts on the base of the machine (at the front) and sliding the machine along slots in which the bolts run. As you need three hands to do this, I always use a short piece of wood (2" x 1/2" say and 12" long) placed between the motor and the machine to apply leverage and keep the machine in line with the motor. This way the belt can be stretched board tight, essential if it is an original type belt. The original belts were stretch-free. If the machine and motor are not lined up properly then it will throw off the belt.
Note that the motor drive is not just off the motor spindle, there is a small flat belt pulley.
Edited By Robbo on 15/05/2017 19:37:09
Chris Shelton15/05/2017 19:45:36
92 forum posts
46 photos
Hi Robbo,
Yes, Thank you that is the info I have, plus a sales leaflet describing the two models offered, one motorised and one without motor, having a V pulley fitted, instead of the flat pulley.
Dave Halford15/05/2017 20:58:05
1446 forum posts
12 photos
Might not be belt tension.
If it tends to stick and slip the belt and when you adjust the sliding hex sloppy it's OK then it's caused by a wear ridge in the main arm. You can stone off the first couple of mm or so front and back of the moving bit to dodge the ridges.
Just keep oiling it.
David Standing 115/05/2017 21:41:43
1292 forum posts
50 photos
Posted by Robbo on 15/05/2017 19:36:00:
Chris
As I, too, have a Kennedy, could I be a cheeky bugger and ask if I could have a copy too.......pretty please wink 2.
Russ B15/05/2017 21:51:17
599 forum posts
26 photos
Chris, thanks, pdf's received, ill print them out and have a good read through thanks!
Robbo, thanks for the input, very useful.
Dave Halford, a smart observation and a great tip, thanks, I'll be sure to keep that in mind when I'm looking over it initially - I feel some hand scraping might be in order laughany excuse!
David Standing, private message me your email address and I'll send you the PDF's - due to the recent swarm of viruses I suspect you'll find my email in your junk mail folder so be sure to check that out.
David Standing 115/05/2017 22:22:08
1292 forum posts
50 photos
Russ
You have PM
Thanks
David
michael cole15/05/2017 22:39:34
163 forum posts
thanks everyone , i will try to tension the belt tomorrow
Robbo15/05/2017 23:45:50
1504 forum posts
142 photos
Had a better idea, have scanned the maintenance instructions as jpeg and put them in my albums, album called"Kennedy Hexacut No 6"
Now anyone can see them without emails. Here they are-
David Standing 116/05/2017 09:17:07
1292 forum posts
50 photos
Thanks to Chris, Russ, and Robbo, I now also have a set of instructions to go with my Kennedy saw cool.
michael cole16/05/2017 16:55:05
163 forum posts
Thanks again, back up and cutting . Get the belt tight then tighter again,
JD Metals
