Prusa i3 Build
Neil Wyatt15/04/2017 10:02:09
18585 forum posts
723 photos
78 articles
I've started assembling my Prusa i3 kit.
So far all going OK, except I had the main frame back to front...
Bazyle15/04/2017 13:49:23
5863 forum posts
217 photos
Ok you've had nearly 4 hours, what's the first print look like? laugh
Neil Wyatt15/04/2017 17:06:08
18585 forum posts
723 photos
78 articles
Assembly takes quite along time... I spent two or three hours on it last night, and I've probably put eight hour in today.
Some of it was correcting mistakes (mirror image assembly!) and a few things at variance with the instructions. Severally fiddly things were pre-assembled, that the instructions said you would have to do yourself.
Now I've got to work up the courage to connect it up to 12 volts at 20 amps disgust.
Something that surprised me, was the effect of having two steppers wired in parallel for the z-axis. You turn one, and the other moves in unison!
Neil Wyatt15/04/2017 20:36:00
18585 forum posts
723 photos
78 articles
>SOB<
The Z-axis didn't work. It's the stepper board, I swapped to the Y-axis and the fault moved too. Only £2.50 for a replacement, but it won't be here until Thursday
So I now have a 2D printer...
Russell Eberhardt16/04/2017 10:50:23
2668 forum posts
86 photos
A problem I noticed with my slightly different version of the Prusa i3 is that the Z-axis screws are supported directly on the steppers. Apart from it being poor practice it locks the flexible couplings up. I hung the screws from ball thrust bearings at the top and get much smoother Z movement as a result.
Russell.
Bob Stevenson16/04/2017 12:10:46
504 forum posts
7 photos
Neil,...what are you going to make with it please?
....I took a look at the website....the 'gallery' of made items is massively uninteresting,...just little plastic widgets with no apparent significance or use except in low cost Christmas crackers.....
Chris Baetens16/04/2017 12:31:23
78 forum posts
Neil,
I suppose you've seen this..?
https://www.youtube.com/watch?v=oVWLpvekby0&t=215s
We've built three i3 so far, works very well.
Dave Smith the 16th16/04/2017 13:13:32
123 forum posts
33 photos
Posted by Bob Stevenson on 16/04/2017 12:10:46:
You could make some rough and ready angle blocks, or V blocks or how about a tachometer sensor holder and a push bolt to lock the spindle on an SX2 mill. Small square frame as a one off holder to cut a gear at an angle? Or a T=Rex or some runners for the sliding doors on a steel shed or some hinges for a shower screen or.... Insert endless list.
Neil Wyatt16/04/2017 13:58:39
18585 forum posts
723 photos
78 articles
Posted by Russell Eberhardt on 16/04/2017 10:50:23:
Russell.
The manual pointed out that if the motor shaft or threaded rods go into the flexible part of the coupling it will lock it as well. I was very careful to avoid this which is why the z-axis rods stick up so far - once all is working i will shorten them. I may go for decent acme threaded rods as an upgrade, also PGMS rods for x and y axes should give a smoother action.
I've tracked down bearing carriers for the z-axis on Thingiverse.
It seems an Ikea Lack table (£8) is just the right size to make a case!
Neil Wyatt16/04/2017 14:01:14
18585 forum posts
723 photos
78 articles
A lot of 3D printer users seem tom have an imagination bypass... I'll be printing this sort of thing:
Enough!16/04/2017 18:50:32
1719 forum posts
Posted by Neil Wyatt on 15/04/2017 17:06:08:
When I was fooling around with a Prusa some years ago, that double-drive z-axis arrangement was the thing that caused me most grief. If one motor loses any steps, it becomes quite problematic. It would have been better, I think, to connect the two z-axis leadscrews via a toothed-belt and to drive them from one (perhaps larger) motor.
Neil Wyatt16/04/2017 19:35:14
18585 forum posts
723 photos
78 articles
Posted by Bandersnatch on 16/04/2017 18:50:32:
Some people fit a toothed belt across the top and lose one stepper.
Hopefully that won't be a problem for me - my kit has larger than normal steppers and now I've swapper the Pololu over the z-axis seems to run very smoothly. I may upgrade to 2mm-pitch 8mm acme leadscrews.
Zebethyal18/04/2017 11:13:59
197 forum posts
Or you could even make a separate 3D printer out of one: Printtable
I saw these in action at last year's TCT show last year, pretty rigid for a very low cost printer.
Russell Eberhardt18/04/2017 20:30:43
2668 forum posts
86 photos
Posted by Neil Wyatt on 16/04/2017 19:35:14ome people fit a toothed belt across the top and lose one stepper.
I doubt if acme lead screws will make much difference. The load on the leadscrew is not very great and is in one direction (the weight of the x-axis carriage and extruder). It is worth making a decent brass nuts to fit the M8 screws though if yours use standard steel nuts. Also, as previously suggested taking the load on the top of the lead screws to enable the flexible couplings to work properly. Before I did that I could see the carriage moving slightly from side to side as it went up.
Russell
Neil Wyatt19/04/2017 09:43:32
18585 forum posts
723 photos
78 articles
The company that sells the kit I bought, Factory3D, say that they actually use these machines to print the parts they sell. I have to be 100% honest and say they quality is indistinguishable from the prints off the Dremel 3040D. They do stress that it does take careful setting up to get best results.
One thing I noticed was that it's easy to get the Z-axis steppers at a slight angle, loading the flexible joint. They say they are planning to include a simple setting jig in future kits, but ho can do it easily enough with a square.
Journeyman19/04/2017 09:59:50
961 forum posts
179 photos
I notice that Factory-3D don't seem to be selling these kits at the moment. Plenty of other bits and pieces but no indication of availability for the full kit. Seems quite a good price currently shown as £272 on the flyer which is still on e-bay store. These printer kits seem to be available from about £150 up to £629 from Prusa Research. What should I be looking for in a good kit?
Edited By Journeyman on 19/04/2017 10:17:20
Zebethyal19/04/2017 10:25:14
197 forum posts
I redesigned my i3 and swapped the orientation of the X axis stepper to allow me to use shorter belts.
I have only ever used nylon tubing for my Z axis couplings and apart from one of them unscrewing itself on one occasion I have never had any issues with the Z axis.
I added a tensioner to the X axis belt, as this was not easy to adjust as standard. I also switched to a Wades extruder from the bowden setup shown above.
By far my biggest issue is with back EMF from the relay that switches my heated bed on and off, causing the X axis stepper to miss steps every so often. I use a Sanguinololu board (because they are dirt cheap) but they do not really have suitable traces for running a 10A heated bed, so I took the control off board.
I use an Xbox 360 PSU for all power, I could probably resolve the issue if I split off the heated bed power from the stepper power with a separate PSU, but I can't be bothered at present, so I live with the issue.
Edited By Zebethyal on 19/04/2017 10:25:39
Neil Wyatt19/04/2017 22:10:45
18585 forum posts
723 photos
78 articles
Posted by Journeyman on 19/04/2017 09:59:50:
Aluminium frame, the larger steppers, 200W PSU and a decent build manual.
Edited By Neil Wyatt on 19/04/2017 22:12:38
Neil Wyatt19/04/2017 22:13:25
18585 forum posts
723 photos
78 articles
Posted by Zebethyal on 19/04/2017 10:25:14:
Looks very neat, I have to get some more spiral wrap, I've run out!
Neil Wyatt19/04/2017 22:29:18
18585 forum posts
723 photos
78 articles
Well I got a pololu today and it works.
I printed a few test pieces including a 'Benchy'. A couple of issues to sort - the lower layers are not cooling fast enough and curling up badly at overhung edges and corners, giving a poor finish. I think I need to use a cooler bed or adjust the fans on the extruder head.
I also had 'stripping' nearly interrupt the benchy when it was printing five small areas at one. I think this is because somehow I had cura retreating the filament much too far - about 1cm! It was thrashing up and down and I think that's why the filament stripped. Also my first few layers don't seem to be printing too well. Where those problems didn't apply, the print quality is very good, if I can sort the curling issue I think I can equal the dremel print quality, but probably Sunday before I can spend some decent time on it.
That said, the 'Benchy' appears dimensionally identical to one printed on the Dremel, so hopefully it will only take a bit of experimenting to get good results.
JD Metals
