Forum sponsored by Allendale Until July 27th
Etched engine maker's plate
steamdave25/03/2017 23:56:50
412 forum posts
34 photos
I want a small fairly detailed stationary engine manufacturer's plate to be etched. A search on here doesn't bring up any names, so I'm asking the readership for suggestions. A google search lists several plate engravers and laser plate makers. The etchers that I have found concentrate on small scale railway stuff or larger scale engine name/number plates, etc.
I did have one guy who was going to do it for me, but after 9 months I'm still waiting because he has 'domestic problems'.
It has to be etched because the plate thickness will be not more than 30 thou with the area removed about half the original thickness.
The Emerald Isle
JasonB26/03/2017 07:41:09
15536 forum posts
1594 photos
Have you tried Fox, look under "made to measure" for bespoke etching
mark smith 2026/03/2017 09:51:26
572 forum posts
296 photos
p1250953.jpgUsing a laser printer and ferric chloride would probably work quite well at that depth of etch. heres a southbend lathe QC Gear box plate i did and it was my first attempt.
Edited By mark smith 20 on 26/03/2017 09:53:45
Phil P26/03/2017 12:04:41
478 forum posts
128 photos
Mark
I would be interested in a description of the steps you took to produce that plate if you wouldn't mind.
Cheers
Phil
Richard S226/03/2017 13:25:36
157 forum posts
84 photos
Dave, At risk of offering a link to one you've already checked out, I offer this one to click on. They are used quite a lot by my colleagues on a few Vintage Machinery Forums. Won't be cheap though!.-
- Etched Plates-
mark smith 2026/03/2017 13:58:40
572 forum posts
296 photos
Phil,
Its quite simple the hardest part is painting the plate.
I bought a cheap used laser printer off ebay.In my case a Samsung ML-1860. It had half the original toner cartridge still in (worked great) and later found out that cheap compatable toner cartridges dont work very well.
I printed out the reverse image onto mylar drafting film using the best quality and blackest print settings.
I then placed it over the brass plate which was cleaned and polished before hand with alcohol or acetone and ironed the mylar on a hot setting .
Carefully and slowly peeled off the mylar before it cooled too much and it leaves the black toner as a mask on the brass plate.If all goes well it should look like this.
I then coated the back with a couple of coats of shellac,quick drying acrylic varnish will do,just to stop etching on the back of the plate.
I then prepared a simple warm bath of ferric chloride in an old icecream tub. I didnt take much notice of the strength of the solution but probably about 25gms in 1/2 litre of water.
Then just put it in the bath and gently tilted the tub occasionally to keep te solution a bit agitated.
You can use a very soft brush to brush the surface but after a while the toner becomes sensitive to abrasion.
Heres a different plate in the bath.
Thats basically it ,clean off the toner with a dish cleaner scruber (like the scotchbrite pads).
Neil Wyatt26/03/2017 18:03:04
16102 forum posts
675 photos
73 articles
I use photo etching, bit expensive for a one-off unless you use sunlight as a UV source.
richardandtracy27/03/2017 11:58:05
938 forum posts
10 photos
Simpler version of Mark Smith's method is to print on the paper here: **LINK** then iron on to work.
Richard.
Maurice27/03/2017 12:07:15
437 forum posts
50 photos
When using ferric chloride to do the etching, it is worth remembering that oxygen is a catalyst to the reaction, and increasing the strength of the solution will actually slow things down. I was warned about this by a technician at a firm from which I scrounged some photo etch chemicals.
Maurice
mark smith 2027/03/2017 12:26:45
572 forum posts
296 photos
Posted by Maurice on 27/03/2017 12:07:15:
Maurice
Maurice , i noticed this when i add more ferric chloride to the bath,it stopped the reaction.
The film that forms prevents the reaction and its a fine balance using the toner method between carefully brushing the surface with a soft brush and removing parts of the toner(which you dont want until your finished). If your not going very deep then just agitating the bath works.
I think i added some citric acid to the bath as well but cant remember, may have been something else.
Maurice27/03/2017 12:51:01
437 forum posts
50 photos
Hi Mark
This is why I thought I would pass on what I was told by the technician. The firm used to bubble the ferric chloride through a piece foam rubber to ensure plenty of oxygen would be present. I was advised to bubble plenty of air through the solution before use, and not to use too strong a solution.
Maurice
steamdave28/05/2017 20:31:57
412 forum posts
34 photos
Some time ago I requested etched plate suppliers details because my original contact had domestic problems and was unable to assist me.
Contacting the suggested possible etchers did not prove fruitful, but lo and behold my original etcher came back soon afterwards and said the plates were ready. I'm very pleased with his work and considering the condition of the original plate from which he had to work from, and the small size of the replica I would say it is a a job well done. The cost was very reasonable, too.
If anyone needs etched name plates, then I would have no hesitation in recommending Peter's Plates
http://www.petersplates.co.uk/
The Emerald Isle
Phil P28/05/2017 22:06:09
478 forum posts
128 photos
Is Peter's Plates currently accepting orders ?
It appears from his website that is not the case, pity because I need one doing myself at some point.
Phil
Neil Wyatt28/05/2017 22:57:05
16102 forum posts
675 photos
73 articles
Posted by steamdave on 28/05/2017 20:31:57:
Well I have now tried gargoyling motor oil, and it leaves a pretty bad taste in the mouth, and it didn't result in any etching, just retching...
steamdave28/05/2017 23:06:30
412 forum posts
34 photos
Posted by Phil P on 28/05/2017 22:06:09:
Phil
Phil
Give him a holler. I've had to wait about 9 months for these. If I've got mine, maybe he's back in business pre-domestic situation.
The Emerald Isle
Massimo Dalmonte29/05/2017 21:04:07
17 forum posts
12 photos
"I use photo etching, bit expensive for a one-off unless you use sunlight as a UV source.
Neil"
Not necessarily so, here's a little contraption I made with aluminumm sheet, pop rivets and parts from the scrap box when I bought some photoresist PCB laminate at a fair; the vendor told me I could use a Philips TL 8 W tube (standard tube, but it seems they "leak" some UV radiation) for 90 seconds at a distance of 7 cm.
You simply put the "mask" (artwork on a printed drafting paper, best with a laser printer, but inkjet was about the same) on the pcb, a piece of glass over the two ( I quickly took it from a small display case I have, just to show that I'm a casual pcb "developer"...) and this gadget on top.
Results where consistent ( I always turned it on for a few minutes before using it on the pcb, to be sure that it had reached it's working temperature) radiation bounces on the inner walls. Working area 32x13 cm, TL tube axis height (guess...) 7 cm.
I searched now, and found that you can buy UV TL tubes, anyway I think that a standard tube is safer, as the exposition time is longer and plus\minus a couple of seconds won't ruin your pcb.
Anyway experiment on small samples of the pcb laminate you have before trying "full size".
Cheers,
Massimo
Meridienne Sept 2019
TRANSWAVE Converters
