First Project
Start machining the model lathe at last
David George 116/03/2017 20:31:24
1194 forum posts
409 photos
I have started the model lathe which my wife bought me for Christmas. Its the first thing which isn't to do with tooling or parts for my lathe etc since retiring and my first model. The first few castings started.
David
Nick_G16/03/2017 21:21:15
1808 forum posts
744 photos
I will be watching this. - Always wondered why more of these are not made. smiley
Nick
Benny Avelin16/03/2017 21:31:42
80 forum posts
86 photos
I second that! Nice lathe btw.
David George 123/03/2017 18:55:50
1194 forum posts
409 photos
A couple of parts turned ready for milling, faceplate and tailstock hand wheel.
David
mechman4824/03/2017 09:53:44
2634 forum posts
408 photos
Hi David; from the drawings I am assuming it's a Stuarts kit. looking at seeing the final built, do you plan to motorise it?
David George 124/03/2017 10:41:13
1194 forum posts
409 photos
Hi I hope to motorise it is am looking how I can make an electic motors look old style enough and what belt to use strong enough but small enough to drive it and to cut metal.
David
Martin Kyte24/03/2017 11:45:31
1807 forum posts
33 photos
The T slots on the cross slide are shown just as slots. I found if you take a piercing saw to them with the cross slide held on the vice you can cut reasonable representations of the _ bit of the T slot. The saw will only really cut on the outside of the piece but that's the only bit you can see. I didn't like the big hex nuts on the end of the spindle either so did some with slots on a 8 point PCD a la crescent wrench style and they are better but still a little chunky. Sometime I may get round to making some more with holes instead of slots. It's an attractive little model. A brass makers plate would look good too after you got rid of the STUART on the casting.
regards Martin
Ian S C25/03/2017 12:10:36
7468 forum posts
230 photos
For strong belts, the ones I use for driving things from my Stirling Engines is 3 mm round, heat joined plastic belting. I use 5 mm dia of the same stuff to drive a Super Adept lathe.
Ian S C
David George 101/06/2017 21:03:55
1194 forum posts
409 photos
A few more parts in progress to Stuart lathe.
David
Edited By JasonB on 02/06/2017 09:19:23
David George 124/07/2017 12:00:53
1194 forum posts
409 photos
I have done a few new parts for Stuart Lathe.
David
Martin Kyte24/07/2017 12:09:45
1807 forum posts
33 photos
Are the bearings not in Brass?bronze?
Looks nice though.
regards Martin
David George 124/07/2017 13:16:42
1194 forum posts
409 photos
I have tried to fit ball bearings into the headstock so I can run it at a higher speed, two in the front bearing and one in the rear. When I have made the spindle I shall see if it works.
David
BERT ASHTON24/07/2017 13:33:43
69 forum posts
46 photos
Hi David, I obtained a set of castings when Stuart first produced them many
years ago. I think the most difficult part to make is the 4 jaw chuck.
I you need any help or advise on this please PM me.
Martin Kyte24/07/2017 13:44:19
1807 forum posts
33 photos
Posted by David George 1 on 24/07/2017 13:16:42:
David
Aha. That would be it then.
Martin
David George 130/07/2017 16:48:20
1194 forum posts
409 photos
Next stage finished on Lathe. Headstock finished and chuck fitted to tailstock. All looks ok at the moment.
David
geoff walker 130/07/2017 17:43:43
398 forum posts
154 photos
Hi David,
I have been following this thread with interest.
Well done a really nice outcome, I'm jealous, I want one!
Look forward to seeing it powered up.
Could you post future pictures with a ruler in the foreground so I/we can get an idea of the size.
Geoff
Neil Wyatt30/07/2017 17:44:29
17729 forum posts
697 photos
77 articles
Coming along well!
Thomas Staubo31/07/2017 15:47:22
54 forum posts
Great work David! thumbs up
Too few are making models of machine tools IMHO.
The tailstock chuck you attached looked out of proportions though.
But I have a tip for you; I bought a miniature chuck from Banggood, that may be more appropriate in size. I thought I would show the size of of the one I bought, by taking a picture in my hand, but I can't locate it at the moment (too small maybe? cheeky)
It has a JT0 taper, but comes with a tapered adaptor if you need. Dimensions is ø 21.5mm x l 35mm
Here's the link:
geoff walker 131/07/2017 16:34:31
398 forum posts
154 photos
Hi David,
I think Thomas has a point, the chuck does look a bit on the large side.
I have just bought a mini chuck from Arc euro trade 4mm capacity and jto taper, it's a good chuck.
geoff
David George 131/07/2017 18:29:33
1194 forum posts
409 photos
I agree with you that the chuck is a bit large, but it is the smallest that I can find at 21mm dia by 28 long 4mm drill .
David
