Help with ultrasonic cleaner
Todd Barrett13/03/2017 15:16:36
5 forum posts
I was given this ultrasonic cleaner. I don't know if it even works. I don't recognize the type of electric plug. If anyone is familiar with any of this please get me started hooking it up!
Thank you
[IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
Keith Long13/03/2017 16:58:01
877 forum posts
11 photos
Hi Todd, welcome to the forum.
I can't help with any info on the cleaner but the mains plug (the round one) is a standard 230 volt single phase ac plug as used in continental Europe - well certainly in Spain anyway. The live and neutral go to the round pins and the earth to the side contact. In Spain the plug will go into the wall socket either way up so it's pot luck as to whether the on/off switch on the unit winds up switching the live or neutral. If you are changing the plug try and find out which of the wires from the plug goes to the switch and make that the live connection. You may find that both wires go to the switch which would then be a double pole device switching both live and neutral, and then you'd have no worries which side you connected to live.
Brian Oldford13/03/2017 17:05:00
686 forum posts
18 photos
Whenever I get passed a piece of electrical equipment of unknown parentage it is wise to initially power it up via an isolating transformer and wind the voltage up with a variac if they are available. Less likelihood of a jolt or letting out the magic smoke if things are not as should be.
John Rudd13/03/2017 17:21:03
1450 forum posts
12 photos
Posted by Brian Oldford on 13/03/2017 17:05:00:
Sound advice there Brian.....and given the current draw of the unit, I'd be inclined to reduce the fuse rating to 3 amps...( assuming you are using a British 3 pin plug...).....
You wouldn't believe the number of items that come my way with a 13amp fuse fitted in the plug!
Todd Barrett13/03/2017 17:24:38
5 forum posts
Thank you for the help!
Keith Long13/03/2017 17:26:12
877 forum posts
11 photos
Even worse - that type of european plug doesn't have provision for a fuse. The cleaner will be relying on a unit mounted mains input fuse if it's got one, but being of German manufacture I'd be very surprised if it didn't have one.
malcolm wright 113/03/2017 17:31:47
4 forum posts
Did a search and found the operating instructions here.
Michael Gilligan13/03/2017 17:39:19
20216 forum posts
1053 photos
Posted by malcolm wright 1 on 13/03/2017 17:31:47:
Can't ask for better than that yes
Todd Barrett13/03/2017 17:49:08
5 forum posts
Nope. That's perfect!
David Colwill13/03/2017 18:18:25
778 forum posts
40 photos
To test an ultrasonic cleaner you generally use the foil test. This involves suspending strips of aluminium foil at various points in the bath and switching on. After 10 / 20 seconds you should see pin holes in the foil. In an ideal world all the strips should show the same damage.
Regards.
David.
Neil Wyatt13/03/2017 21:32:17
19041 forum posts
734 photos
80 articles
Welcome to the forum Todd, ultrasonic units are great.
My stepson has recently had an interview with a specialist marine maintenance firm, and he said they showed him an ultrasonic tank. I said "I've got one of those", he said "they used to put thing in this one with a fork lift, but it was too small so they fitted a crane in the roof".
Todd Barrett13/03/2017 21:39:46
5 forum posts
Thank you for the welcome. I found the forum by tracking down Harold Hall! I'm mostly a lurker but since I have no experience with European electronics I thought this would be a good place to ask.
Thank you for the foil test that will be the first thing I try
Todd Barrett14/03/2017 00:33:46
5 forum posts
Double post
Edited By Todd Barrett on 14/03/2017 00:34:39
Ian S C14/03/2017 11:23:33
7468 forum posts
230 photos
I'v got a couple of small domestic ultrasonic cleaners, they make a buzzing noise (50Hz), I have not used them yet, is this a usual sound from these little units, they hold 400 ml each.
Ian S C
Cornish Jack14/03/2017 13:35:29
1219 forum posts
171 photos
Ian - re. the buzzing noise - yes, at least mine does. One thing I also discovered when mine stopped buzzing - there is an INTERNAL fuse!!blush
rgds
Bill.
Harry Wilkes14/03/2017 13:37:35
1347 forum posts
65 photos
Posted by David Colwill on 13/03/2017 18:18:25:
Regards.
David.
Neil many years ago when I worked at British Silverware we had a small shop with a bank of 6 in there as I remember they were filled with 'Tric' they were around 3ft x 3ft and around 4ft deep, in later years I moved on and part of the equipment I had to maintain was a large ultrasonic the inside was 12' 6" by 4' and 6' deep filled with methyl chloride and electrically heated. Changing an heater or transducer was a challenge one lay on your back working at arms length in a 12" space under the machine boy was I glad to see it go however the aqueous wash that replaced it was never as good and used around three times more energy.
H
KWIL14/03/2017 15:19:16
3557 forum posts
70 photos
Type F Schuco plug. you can get adaptors to 13A 3 pin (Maplin)
Ian S C15/03/2017 10:46:42
7468 forum posts
230 photos
I tried it with some aluminium foil this evening, pin holes! no more like lace curtains, so I suppose it works.
Ian S C
Meunier15/03/2017 21:18:31
448 forum posts
8 photos
"we had a small shop with a bank of 6 in there as I remember they were filled with 'Tric' they were around 3ft x 3ft and around 4ft deep,"
My first job after school was as Trainee Instrument maker, the plating shop had a degreasing tank 4x3ft x 3ft deep that wasn't ultrasonic but 'Tric' vapourised by heating coils. It was run by Charlie, a wizened chap in black waistcoat, flat cap and a lit roll-up always hanging from the corner of his mouth. He would stick his hands and head, roll-up, cap and all, in the tank to hang/remove the wire baskets of components. Tried it myself once and skin on hands came out with a chalky white appearance after not long in the vapour. Looking back now I reckon 'old Charlie' was probably only about 40yrs old....but his flat cap was always immaculate.
DaveD
Antony Powell28/04/2017 17:25:23
147 forum posts
19 photos
Hi
Nobody's mentioned it so I thought I'd chip in....
Don't run it without fluid in - It can badly damage it (vibrates itself apart)
Or so I was told when I bought mine.
Tony
Rapid RC
Dreweatts
