Bennys Tools
Workshop tooling
Benny Avelin08/03/2017 05:56:20
80 forum posts
86 photos
Since I like building tools I will probably make a continuous stream, thus I felt it easier to make one thread for all my tool builds.
Benny Avelin08/03/2017 06:05:21
80 forum posts
86 photos
I will start off this thread with pictures of my current ongoing project. It is a ER25 Collet chuck that mounts directly to the backplate of my mini-lathe. Why ER25 you ask? Well, ER32 would be better due to the upper size limit of 20mm which corresponds to the spindle bore instead of ER25 16mm max. But I had a set of ER25 collets for my milling chuck so I decided to reuse.
The base material is S355 hot rolled, I acquired these slugs and this is what they look like after pickling in some vinegar to remove the mill scale. The leftmost piece (105mm dia) will be the chuck, one of the pieces to the right will eventually become a steady rest.
I faced of one end and then got discouraged and left the lump for a couple of months...
Well some months later things got started up again and now I just kept going, I started making the back face and register for the chuck. Strangely the register on the lathe is 72.04mm as best I can measure (caliper, could not reach with a micrometer, would be nice to have a set of disc-mics).
Time to put a makers mark and drill and tap the mounting holes. I am quite surprised at how straight the stamping became...
Benny Avelin08/03/2017 06:12:52
80 forum posts
86 photos
I then proceeded to mount it on the lathe, a very snug fit indeed but it is removable. I call that a success!
Now it is time to hog out some material, not a trivial task on this small lathe.
At this point I was discouraged, I had been using HSS tools and the low rpm range of the lathe lacked a bit of strength at this diameter as well as it got hot and started to smell hot lacquer (nooot good). I then switched to insert tooling and maxed the rpm and kicked up the feed rate quite substantially and some time later and a bag full of chips I came to this point
Next I proceeded to make a bevel on the front face, firstly for cosmetic reasons, secondly to get access with my threading tool to the small diameter.
which also ended up with a mountain of swarf
Benny Avelin08/03/2017 06:14:01
80 forum posts
86 photos
Next I proceeded to thread the M32x1.5 thread and test fitted a nut. This is all for today.
Edited By Benny Avelin on 08/03/2017 06:14:51
bricky08/03/2017 06:44:11
402 forum posts
47 photos
Hi Benny
Great work and a nice finish.
Frank
Bob Stevenson08/03/2017 08:19:29
333 forum posts
6 photos
How did you transfer the positions of the fixing studs from the spindle plate?....this was the tricky bit for me as you cant get proper access to spot thru accurately.
Benny Avelin08/03/2017 21:54:25
80 forum posts
86 photos
Bob. The way I do it is to measure the distance between the holes with a caliper and then subtract the hole diameter to get the cc distance. Then I use this table (disregard the Swedish)
to calculate the diameter that the holes lie on, this can then be marked out on the target, then using a compass to mark out the holes.
Benny Avelin08/03/2017 21:56:50
80 forum posts
86 photos
Thanks Frank!
I managed to cut the taper today, I am not sure if I am going to grind the taper with a toolpost grinder or not.
Benny Avelin09/03/2017 16:14:32
80 forum posts
86 photos
This was an interesting turn of events. When I removed the chuck to drill holes for a tommy bar, I realized that the fit over the register was almost loose but before it was a tight interference fit. My guess is that although it is hot rolled it must have been slightly compressed from the mill. This compression got reduced as I turned down the outer layer and thus enlarged the register by a couple of 0.01 mm. I am usually very wary about this when I mill cold rolled steel but I did not know this could happen. I would say cool! Apparently it registers good enough and I have 0.005 mm runout on the body and 0.02 TIR at a test bar 15mm dia 40mm out from the chuck, this is actually smaller than the stated runout on the collets, again cool! As everything seems to work I will not grind the internal taper since I got such a fantastic finish on it.
Raymond Anderson09/03/2017 17:02:30
734 forum posts
140 photos
Him Benny, Nice work, looks a great finish. Am wondering why you made the body so wide ? I would have thought it would have been better to have the body thinner and thus the collets are then closer to the spindle nose.
Still nice work though yes.
Benny Avelin09/03/2017 20:04:27
80 forum posts
86 photos
Well it is a combinations of things that led to the wider body. My original thought was that it would look better, secondly it suited the material at hand, thirdly (and this is an afterthought) greater rotational mass seems to improve finish and reduce vibrations when turning. Maybe these are valid points but who knows it's a god question.
Benny Avelin09/03/2017 21:24:29
80 forum posts
86 photos
Just a thought... in the data sheet for s355 steel one notices different material tensile strength for different bar diameter (lower strength for larger bars). This must be an indication that the outer layer is compressed from the rolling process, and the smaller diameter the compressed layer makes up more of the bar and thus it becomes stronger?
Benny Avelin12/03/2017 09:38:08
80 forum posts
86 photos
Begun mocking up a steady rest. I decided that this southbend type design is quite neat, now I need a good locking mechanism...
SillyOldDuffer12/03/2017 10:02:48
5127 forum posts
1073 photos
Posted by Benny Avelin on 08/03/2017 06:05:21:
Nice work Benny.
How do you keep your stamping so neat? My efforts are drunk in comparison.
Benny Avelin12/03/2017 12:28:32
80 forum posts
86 photos
Posted by SillyOldDuffer on 12/03/2017 10:02:48:
Nice work Benny.
Thanks Dave.
I have to say I don't really know, it is almost a hit and miss procedure. This one came out really nice according to my standards, even though they have in average improved through training they often have at least one letter that looks drunk. I do stamping freehand and usually scribe a line to follow, then when I place a letter I try to look from the side to see where the edge of the letter is and just judge the distance to the previous letter and the scribed line. Getting the letter straight is easily done by gauging the square shank of the stamp against the scribed line.
Tim Stevens12/03/2017 12:33:39
1123 forum posts
Benny - there is another reason why large diameter steel is not the same as small, as regards tensile strength and some other characteristics. This is because the large bar is likely to be made from a large billet given a heat treatment. Any change in temperature in this process takes time to be conducted through from the outside (where the change starts) to the inside. With a small bar - likely to be heat treated as a small bar - the distance is shorter and so the changes take place more quickly. And the speed of the change can make a big difference to the effect.
A second cause with some material is the rate of cooling (and therefore the crystal size and composition) when a billet is cast. A big casting is never as good in the middle as it is around the outside, and this effect can persist as the cast steel is rolled to size.
I'm not saying you are wrong - just that there is (as too often) more to it than that.
Cheers, Tim
Benny Avelin12/03/2017 21:31:38
80 forum posts
86 photos
Tim, those as excellent points! I actually found some research papers on the second cause. I.e. The residual stress in hot rolled profiles due to the uneven cooling, in that case the made the simplification that the profile is rolled and left in a hot annealed state and then cooled by advection, this then caused the uneven residual stress.
Benny Avelin13/03/2017 05:32:42
80 forum posts
86 photos
This is the paper I was talking about, the pictures are at the end. Specifically see page 80 for a rectangular plate.
Benny Avelin16/03/2017 08:41:28
80 forum posts
86 photos
Recently I have had a lack of time in the shop, but I managed to get some time to work on the faceplate. First I drilled and reamed a 10mm hole and milled a flat around the hole.img_2949.jpg
I then pressed this onto a turned spigot and proceeded to face off and prepare the step for the spindle.
The reason for the spigot is that I cannot mount this large piece in any reasonable way on the lathe. However drilling the mounting holes I needed to keep the disc flat on the milling table and since this is a scrap piece, actually the end of a bar I had to mill the other side reasonably flat before drilling the holes for the mounting screws. This is where I realized that end-pieces can be quite tricky. One of the edges had a moon shaped inclusion of steel that was noticeably harder than the bulk material, had to take it slow on my less than rigid milling machine.
I then drilled the mounting holes and put it on the lathe.
This is where I again noticed the problem with the hard inclusion, it showed up when turning. Even though I was taking material off the whole diameter the lathe sounded like it was taking a mild interrupted cut and the finish was terrible on the harder part. I hope it will not come back and bite me but I just decided to polish the surface until everything looked homogeneous.
I decided that the next step will be to mill t-slots in the faceplate. On the Myford you have a threaded spindle so the faceplate for that can have slots all the way through and almost all the way down to the centre of the plate. However these mini-lathes have this rediculous backplate making the faceplate concept less then ideal, therefore t-slots will allow me to move the mounting points as I please. I will be making the t-slots to the Myford dimensions to improve compatibility of things.
Btw. In all my photos you will find splotches, this is due to my broken camera that I have not taken the time to fix (Iphone). Apparently a new camera costs about 10 £, but you have to disassemble most of the phone to get to it. Maybe I will take the effort at some point.
Edited By Benny Avelin on 16/03/2017 08:43:40
Benny Avelin18/03/2017 15:07:25
80 forum posts
86 photos
I have now milled the T-slots. Wow that was time consuming smiley
Of course it got crooked after milling. So now how do I get it straight again? Maybe I should try to straighten it by pressing or should I just mount it back on the lathe back plate and that would maybe make it straight, as long its on the lathe.
