JimmieS | 25/02/2017 20:20:20 |
290 forum posts 1 photos | Can anyone recommend lightweight thermal gloves suitable for workshop use. I suffer from poor circulation and, when the temperature is less that 15C my fingers go numb. The obvious solution is heating. I have tried pig house bulbs, radiant heaters, fan heaters all with little success as the workshop is part of a single brick garage. It is also too small to divide into two units |
KWIL | 25/02/2017 21:41:38 |
3550 forum posts 70 photos | Extra clothes and fingerless gloves, that way you have still the ability to feel what you are doing. Advice given by former secretary who had to type in a "frig" office.!! |
Jim Nic | 25/02/2017 22:04:16 |
![]() 378 forum posts 214 photos | I am not normally an Elf''n'safety jobsworth but I would be VERY wary of using gloves when machining, especially if my fingers lacked feeling. If your budget allows it insulation, and loads of it, (for the garage as well as you) would be a good first move. Jim Edited By Jim Nic on 25/02/2017 22:16:02 |
Alan Waddington 2 | 25/02/2017 22:17:11 |
522 forum posts 87 photos | Pot belly stove ? Had one in my old workshop which was also a brick uninsulated single garage. Proper toasty |
Hacksaw | 25/02/2017 22:21:43 |
463 forum posts 199 photos | I suffer that too ..Ansell hy-flex 11-800 Edited By Hacksaw on 25/02/2017 22:23:07 |
Roger Williams 2 | 25/02/2017 22:23:30 |
346 forum posts 3 photos | Jimmie, I wear thin white cotton gloves all the time in the workshop in winter, similar to what the Japanese train drivers use. Oh, and I keep my fingers away from rotating things !!. You can buy them off ebay by the bagful. By the way, every video Ive seen of Japanese lathe operators, all wear gloves. Just needs common sense. |
Hacksaw | 25/02/2017 22:26:47 |
463 forum posts 199 photos | Those Ansell gloves .... you don't want to be paying more than £22 for 12 pairs delivered ! SOME Ebay sellers grossly inflate the price |
Paul Lousick | 25/02/2017 23:11:22 |
2019 forum posts 712 photos | I second the comment that wearing gloves while machiniing is dangerous. They can easily get caught in rotating parts unless you are 101% confident that your hands will always be completely clear of rotating parts. I'm not and never wear gloves. If you cannot heat the workshop, get one of the heated jackets which are powerred by cordless drill batteries. Sold by AEG and Milwaukee (possibly others as well) |
Mike Poole | 26/02/2017 00:12:35 |
![]() Moderator 3308 forum posts 73 photos | I worked with a team from Honda Engineeering and they all wore gloves all the time, they also had a complete set of clean overalls every day, not like us stinky Brits who had a weekly change of overalls, mind you the humidity in Japan needed two changes of shirt a day so maybe they didn't realise Oxford was a bit more temperate than Tokyo. Mike |
Paul Lousick | 26/02/2017 00:58:01 |
2019 forum posts 712 photos | Mike, Did the Japanese machinists operate automatic/CNC machines or old manual lathes and mills like us poor hobby machinists ? Paul. Edited By Paul Lousick on 26/02/2017 00:58:37 |
Ian S C | 26/02/2017 08:13:02 |
![]() 7468 forum posts 230 photos | Some time after I left aero engine over haul, the workshop went to negative pressure, the workers to disposable caps gloves, over shoes, and overalls. Warmth was OK , three 3Kw sections of under floor heating. Ian S C |
Brian G | 26/02/2017 08:21:12 |
839 forum posts 37 photos | Rather than gloves which could get caught up and do some real damage, how about replacing machine handles with wood or plastic so they are less efficient at sinking the heat from your hands? Away from rotating machinery, gloves with a "Thinsulate" layer may offer the best compromise of warmth and feel. Brian |
Alan Wood 4 | 26/02/2017 09:02:57 |
229 forum posts 12 photos | I quite like MSC's Nitrile gloves. Very comfortable to wear, tight fitting, tactile and have a good grip. MSC code MPA-55308-L for size 8. Usual disclaimers. |
Neil Wyatt | 26/02/2017 09:44:28 |
![]() Moderator 18994 forum posts 734 photos 80 articles | I worry about gloves, because my nephew was on ambulances and saw several people who had been 'de-gloved' and that doesn't mean the glove was pulled off their hand... Neil |
mechman48 | 26/02/2017 11:56:39 |
![]() 2947 forum posts 468 photos | Vary wary of gloves in the vicinity of rotating machinery, one split second lapse of concentration... no use going to the 'second hand shop'. Once had to do an H & S enquiry into a guy that was de-gloved using a pedestal drill. Please look at alternatives as suggested above. |
Nick Hulme | 26/02/2017 16:30:11 |
750 forum posts 37 photos | Heating your wrists warms the blood flowing to your hands, have you investigated infra-red wrist heat pads? Long term I'd suggest insulating and draught proofing the garage. |
Ed Duffner | 26/02/2017 17:17:21 |
834 forum posts 94 photos | A few weeks back I was machining some black steel and got to the end of a 6" or so cut. I wanted to flick away the oil and swarf from on top the work piece and used the piece of rag I was holding instead of the brush I always use. Having not switched off the spindle first it was a wake up call to pay attention and concentrate when the rag was snatched from my hand and wrapped itself around the roughing cutter. If I had been wearing gloves I might have just used a gloved finger to flick some of the swarf away, but I never wear them when machining. I think tiredness also played a part in lack of concentration, which I think gets worse in cold environments, so it's not just hands that need to be kept warm. We used to install down-draft fan heaters in retail shops above the doors to create a curtain of warm air which theoretically was a barrier for cold air entering a premises. Maybe something like this could be an alternative? Ed. |
JimmieS | 26/02/2017 19:29:01 |
290 forum posts 1 photos | Many thanks for all suggestions. Should have added that my request was for bench work only. Some 55 years ago my m/w teacher may sure his instructions would not be ignored a second time re clothing and things that revolve. I recently visited my GP who, after seeing my collect of 'finger chilblains,' decided my problem was caused by "a lifetime of smoking resulting in narrowing and damaged of the arteries". After I said I was a non-smoker he recommended in cold weather I should stay in a warm environment and wear good quality clothing! I have tried all kinds of industrial gloves, ones which keep me warm are too thick for practical work. Despite being well wrapped up down to the wrist, with fingerless ones the fingers start turning grey and are numb within 5 minutes. The nitrile ones much the same. So warm environment it will have to be. Perhaps a move to some sunny land - following a lotto win. |
Dougie Swan | 26/02/2017 20:16:24 |
234 forum posts 53 photos | I use little things called hotties They are like large tea bags with a chemical mixture inside that reacts with moisture in the air to create heat Kept in a pocket they work wonders when my digits get too cold http://www.costco.co.uk/view/p/little-hotties-hand-warmers-40-pair-pack-186892 Dougie |
Neil Wyatt | 26/02/2017 20:22:30 |
![]() Moderator 18994 forum posts 734 photos 80 articles | How about a radiant IR heater aimed at the bench? Neil |
