Forum sponsored by Allendale Nov 29
Roller Bearings for a Myford Super 7
Articles
Improved Headstock Bearings for a Myford Super 7
While many users are more than happy with the standard bearings fitted to Myford Super 7 lathes, some critics consider that roller bearings should have been fitted.
Neil Wyatt23/02/2017 12:43:54
15697 forum posts
659 photos
73 articles
In response to a query from a forum member, here's a reprint of an interesting and useful 2011 article by Ken Willson.
mgnbuk23/02/2017 12:59:18
492 forum posts
10 photos
Logged in, MEW subscriber & can't access this Neil ?
Nigel B
Michael Gilligan23/02/2017 13:31:06
12766 forum posts
553 photos
Posted by Nigel B on 23/02/2017 12:59:18:
Nigel B
Working fine [for me] now, Nigel
... maybe Neil posted the note, before the link was activated.
mgnbuk23/02/2017 13:36:58
492 forum posts
10 photos
Sorry, this is Subscriber-only content...
No difference when I just tried again, Michael
Nigel B
Neil Wyatt23/02/2017 13:47:16
15697 forum posts
659 photos
73 articles
Nigel, I've sent you a PM.
I hadn't meant it to be subscribers only. I want those without subscriptions to see what they are missing
Brian Wood23/02/2017 14:03:56
1853 forum posts
36 photos
For those who might be considering the modification, I made the change to my ML7B as a direct result of this article and have no hesitation in recommending it to others.
​Bearing adjustment has not been needed since
KWIL23/02/2017 14:27:39
3060 forum posts
56 photos
Brian, Thank you
Dick Ganderton 118/03/2017 13:23:06
8 forum posts
Definitely well worth doing. However, there are a few problems with the drawings and part numbers in the article.
I have since found that the useless oil nipple on the rear bearing housing wasn't letting any oil through. I have replaced this with a brass oil cup that really does let the oil get through to the bearings.
Here is what I found. (I think it was later published in MEW.)
I have just completed the mods to my Myford S7 Headstock as described in Ken
Wilson's Article in the April 2011 Model Engineers Workshop.
I have never been able to get this machine to run on the top speed range or to
get the rear bearings to properly adjust to take end thrust when drilling with large
drills. This is in complete contrast to my previous, earlier S7, which spent most of
its life running at top speed with no trouble. Now I can run at top speed - I have
even tried it at twice top speed as I have a 3-phase motor fitted driven from an
invertor to give speed control.
However, I think that there are problems with the dimensions given for the
modifications to the two locking rings and the new spacer. The recess depth,
given as 3.4 - 3.5 mm (0.134" - 0.138" in understandable units) is not deep
enough to clear the inner race of the new bearings. I had to increase the depth to
0.140" to just clear the inner race - 0.144" would be better. It's very frustrating to
discover this when you have got the headstock in bits and no way to remachine
the rings! Fortunately, I had opted to buy new rings from Myford - the part
number is G2340 not G2430 as quoted in the article, order that part number and
you will get a driver plate - so I was able to put the headstock back together and
take the extra few thousandths off.
Having gone to the trouble to make a new spacer to the dimensions given in the
article, I found that with it fitted the front locking ring protruded too far into the
headstock while the rear one was so far into the housing that the C-spanner
could not get hold of the slots. So I put the old spacer back and everything was
OK.
It's definitely worth doing the mods as it now runs faster and quieter and is much
easier to adjust than with the standard ball races.
Dick G
KWIL18/03/2017 16:08:41
3060 forum posts
56 photos
Dick,
I am sorry you had the difficulties you describe. As stated in the article the bearing are metric and so I kept to those units (I too am an imperial person). Dyslexic fingers are the cause of the G number error in transcribing from the Myford parts listing.
As you had only one lathe you could well have tried the bearing against the modified locking ring whilst still in the chuck so avoiding any interference troubles, a long term held view of this hobby, never trust drawings!!
I am pleased, that in the end, you found it all worth while. Long may your lathe run well.
Ken Willson
TRANSWAVE Converters
