Neil Wyatt | 05/01/2017 17:51:01 |
![]() Moderator 19076 forum posts 736 photos 80 articles | Last year I bought a mid-price tape measure from Wickes that had such a confusing numbering system I kept making errors and threw it in the bin! I went in to get a cheap shelf, and looked at the FatMax ones, but decided not to invest as they were all a bit too chunky. Lo and behold! At the checkout was a sweet jars full of FatMax keyring tape measures reduced to 99p. Very compact, 2M and only marked in centimetres (remember those?) but at least marked in a totally unconfusing way (every cm unambiguous with no clever change in the number format at metres or 10-cm intervals) just the 10 cm intervals larger and red. Best of all they appear to be decent quality mechanisms with a full width tape rather than the usual typical keyring 'thin as string' tape. So a very well spent 99p and I think I will get a couple more! Neil |
Michael Gilligan | 05/01/2017 18:36:42 |
![]() 20289 forum posts 1064 photos | If it's this model **LINK** https://www.thetapestore.co.uk/stanley-fatmax-2m-keyring-tape-measure-1-33-856 that certainly looks a bargain, Neil Thanks MichaelG. |
MW | 05/01/2017 18:40:06 |
![]() 2051 forum posts 51 photos | That pound (well it is really) gets you a lot. I can think of many uses for that. The big ones feel a little intrusive bulky body at times and inflexible when measuring. (desirable when laying out ground/building work but not when you're measuring something awkward). I had an engineering tutor who thought very little of the CM, basically ascribing it to a dodo in real life, only ever taught in school. Michael W Edited By Michael-w on 05/01/2017 18:42:35 |
Ajohnw | 05/01/2017 19:30:34 |
3631 forum posts 160 photos | I keep a 2ft fabric tape from an Xmas cracker in my pocket. That is compact and has been of use many times. Metric on one side and imperial on the other. I've tried several small tape measures and can't say as I like any of them. Fat Max 13mm wide tape seems a bit broad to me for a keyring. I did have a thin light metal cased 6ft one for a long time with a 1/4" wide tape. Eventually it gave up the ghost and wouldn't retract. I'v failed to find anything remotely like it.
John - |
John Stevenson | 05/01/2017 19:41:19 |
![]() Moderator 5068 forum posts 3 photos | Posted by Michael-w on 05/01/2017 18:40:06:
I had an engineering tutor who thought very little of the CM, basically ascribing it to a dodo in real life, only ever taught in school. Michael W .
Only the BBC and dressmakers use centimeters |
Michael Gilligan | 05/01/2017 19:52:16 |
![]() 20289 forum posts 1064 photos | Posted by Ajohnw on 05/01/2017 19:30:34:
"We seem to have a synergy on the tape width probably down to global forces." . That is sheer poetry, John [even if it doesn't rhyme] ... It could live-on, long after we are all gone. MichaelG. |
Brian H | 05/01/2017 20:16:09 |
![]() 2312 forum posts 112 photos | I'm with John Stevenson with respect to CMs, I find them very confusing being brought up on metres and mm. I much prefer inches though and got a boss, on a visit to US to get me Lufkin 6Ft and 16 Ft tapes. They are only in inches;magic! |
bodge | 05/01/2017 20:21:48 |
186 forum posts 3 photos | Then there is the decimetre, Should have made it part of conditions = 25 mm to 1 inch, try buying a 6 inch rule marked decimal inch on more than one edge..........b Edited By bodge on 05/01/2017 20:27:48 |
Ajohnw | 05/01/2017 21:02:26 |
3631 forum posts 160 photos | The synergy doesn't apply to some parts of the world. This could be a good replacement for the one that broke. There are some other similar options on ebay.com. The type I had that broke was often handed out as gifts by companies. Well made as gifts shouldn't upset people and obviously very cheap too. John -
V8Eng | 05/01/2017 21:11:59 |
1727 forum posts 6 photos | Posted by John Stevenson on 05/01/2017 19:41:19:
Only the BBC and dressmakers use centimeters Furniture Stores use the CM regularly! |
Neil Wyatt | 05/01/2017 21:13:18 |
![]() Moderator 19076 forum posts 736 photos 80 articles | Posted by bodge on 05/01/2017 20:21:48:
Then there is the decimetre, Should have made it part of conditions = 25 mm to 1 inch, try buying a 6 inch rule marked decimal inch on more than one edge..........b Edited By bodge on 05/01/2017 20:27:48 I always said it should be 25.6mm = 1 inch. 6.40 mm = 1/4" 3/8" = 9.60 mm All fractions = lovely round figures, no need for 'thous', with Imperial and Mewtric living in perfect harmony. Neil |
Neil Wyatt | 05/01/2017 21:14:50 |
![]() Moderator 19076 forum posts 736 photos 80 articles | Posted by Michael Gilligan on 05/01/2017 18:36:42:
If it's this model **LINK** https://www.thetapestore.co.uk/stanley-fatmax-2m-keyring-tape-measure-1-33-856 that certainly looks a bargain, Neil Thanks MichaelG. Blimey! They're only 1.99 Wickes standard price, and 1.76 elsewhere! N. |
Another JohnS | 05/01/2017 21:40:54 |
832 forum posts 56 photos |
Posted by Neil Wyatt on 05/01/2017 17:51:01:
Last year I bought a mid-price tape measure from Wickes that had such a confusing numbering system I kept making errors and threw it in the bin! I have that issue - "over here" in metricated Canada, go to most stores, and measuring tapes are solely in that ancient of ancient measurements - inches. A problem with being so close to the USA, so count yourself lucky! Nobody in Canada under about the age of 50 was taught inches and so on in school, but somehow, like a bad smell, they still infiltrate... (try finding a steel rule over here with metric markings on both top and bottom, or even (oh heavens!) right to left markings... I have to go to the UK for *real* measuring tackle) Ok, ok. Inches do have their uses, at least that's what I've heard! John. Sad and depressed in Canada. |
john swift 1 | 05/01/2017 21:56:14 |
![]() 318 forum posts 183 photos | I've not yet decided if it's one of those things you buy and find its not as useful as you first thought but how about this tape measure - £2.99 from amazon Edited By john swift 1 on 05/01/2017 21:56:59 |
norman valentine | 05/01/2017 22:08:06 |
280 forum posts 40 photos | I used to be a teacher of design and technology. I tried to get the kids to use millimetres, it was impossible. Every other department in the school used centimetres. I tried to persuade the other teachers that they should use SI units (which does not include CMs) what a waste of my time! I've given up. It was easier with inches, at least we were all singing from the same hymn sheet. It no longer matters to me. I am retired. |
Ajohnw | 05/01/2017 22:20:48 |
3631 forum posts 160 photos | The reason people use cms, a fact that iso just wont accept is that stating some thing like about 300mm is stupid.30cm makes more sense, if it is even a rougher guess about 3 of what ever 10 of those is would be ideal.
The other fact that many forget is that the none English speaking european countries as far as I am aware often use cms and always have. Then there a ccs and mls. Even more stupid really where they are often used it doesn't really matter. Next time some one wants a pint ask for 568.261485ml instead. I'd probably not even remember the number before I had drunk one. No chance after 2 or 3. I often drink halves when I'm driving - even worse. John - |
jason udall | 05/01/2017 22:22:17 |
2031 forum posts 41 photos | When advisors to Napoleon were calculating the metre..designed to be a specific fraction of the equatorial circumference of the earth... And possibly more importantly NOT a yard. .. ironically the small errors in these calculations if done correctly ,would have been closer to a 36" rather than 39".. Now if a yard =1m Harmony would reign. .same unit just slice it in decades or binarys your choice... Btw like the write on tape..this thing is this long who cares how many inches /mm/barnes/angstroms/plank lengths |
jason udall | 05/01/2017 22:27:29 |
2031 forum posts 41 photos | Wikipeadia corrects me. One /10 000 000 of the quarter of the prime meridian passing through Paris ( as apposed to Greenwich) |
Brian H | 05/01/2017 22:56:04 |
![]() 2312 forum posts 112 photos | I still think that we should ditch the metric system, purely on the grounds that it was invented by the French and promoted by that idiot Napolean. |
john swift 1 | 05/01/2017 23:22:52 |
![]() 318 forum posts 183 photos | Brian +1 from me they have to be different just look at their wacky SECAM tv system they would not transmit programs using the American NTSC (never twice the same colour heaven forbid PAL as used in Germany & the UK.
Ironically the tv stations had to use PAL so could use a PAL vision mixer to mix between the various video sources. the stations output being converted to SECAM for transmission Edited By john swift 1 on 05/01/2017 23:25:59 |
