Forum sponsored by Allendale Nov 29
Steam Raising Blower
Michael Malleson09/12/2016 10:38:49
56 forum posts
I am interested in making the Steam Raising Blower described by Brian Baker in recent Model Engineer magazines. However, a comprehensive internet search has failed to find a 12 volt fan motor suitable for a 7.25" loco as featured in Part 2. can you, Brian, or anyone else please advise where I can buy such a motor. Many thanks, Mike
not done it yet09/12/2016 10:59:14
2572 forum posts
11 photos
Not seen it, but 12V and blower usually conjures up thoughts of car heater fans.
Russell Eberhardt09/12/2016 11:22:39
2394 forum posts
82 photos
Haven't seen the article but isn't it more usual to mount a sucker on the funnel rather than using a blower? You then need a fan that is impervious to smoke and heat.
Where can you fit a blower?
Russell.
Ian S C09/12/2016 14:47:57
7190 forum posts
227 photos
I'm not a loco type, but you could use a blower that doesn't involve a fan on the chimney, instead a blower line through a venturi, seen one like that used as a workshop vacuum. It could probably operate with the air from a 12v car heater fan.
Ian S C
Diane Carney09/12/2016 15:40:22
394 forum posts
10 photos
Posted by Russell Eberhardt on 09/12/2016 11:22:39:
... but isn't it more usual to mount a sucker on the funnel rather than using a blower? ...
Brian Baker 109/12/2016 17:28:34
78 forum posts
13 photos
hi Michael,
thanks for your interest in my fan design, and sorry to find the problem with sourcing a suitable motor.
I looked on Ebay and found about a dozen, when I built my blower back in June, but today not easy to find. The motor I used was normally used to operate a radiator cooling fan or car heater fan, made by smiths 7 fitted to many UK built cars in the 70s, 80s, & later.
However, ebay item 162175639784 may well be suitable, or, perhaps try a car breakers.
I will look into recommending a suitable motor, when I can find a reliable source.
hope this helps, and please let me know how you get on.
regards
Neil Wyatt09/12/2016 18:03:23
15459 forum posts
651 photos
72 articles
Try breakeryard.com, and request quotes for a fan blower motor
http://www.breakeryard.com/partfinder
You may need to spoof a reg number so you can manually chose a suitable donor car.
julian atkins09/12/2016 23:14:37
1196 forum posts
353 photos
A few points.
I know nothing about electric motors.
All my steam raising electric blowers use ex WD 24V motors. Most clubs have 12V and 24V supply on the steaming bays. If they have air lines via a compressor I much prefer this with a tube dropped down the chimney that has a 'U' bend on the bottom.
The car Smiths type heater fan doesnt work well on 12V but ok on 24V. However the fan itself is usually plastic.
The temperature of exhaust gases via the smokebox will eventually be well above what the fan can cope with. And the ex auto type motor will also get very hot.
I would much prefer clubs to have air lines instead of having to rely on electric motors on top of the blower vanes.
I havent seen the article yet in ME.
Cheers,
Julian
Brian Baker 110/12/2016 07:45:32
78 forum posts
13 photos
Greetings Julian, thank you for your comments.
In my experience, the compressed air system can use quite a lot of air, and just when you need the most, someone else opens up, thus reducing the supply, just what you need.
You are quite right about the plastic fan being next to useless, and my design was to provide a laser cut replacement for the fan & casing.
Above all, it was meant to be simple to construct, with a view to encouraging someone who has purchased a locomotive, to start making some thing simple, and thus beoming converted to this wonderful hobby of ours.
Michael Malleson10/12/2016 11:05:55
56 forum posts
Hi Brian.
I followed your directions and have a motor on order, so now I can make a start on the steam raising blower, what all miniature loco people call them ! Many thanks. It's for a 7 1/4" William Dean Armstrong Class 4-4-0 "Gooch", the most beautiful express passenger loco ever built (see J.N Maskeleyne, A Further selection of Locomotives I Have Known p. 36) !!!
Thanks Neil for your helpful comments, I will follow up breakeryard site for future use.
Brian Baker 110/12/2016 11:43:47
78 forum posts
13 photos
Hi Micheal, that is a most beauttful loco that you have picked, and coming from a dyed in the wool LNER man,, thats saying something. I have seen several running. I had one my self, but my son in law pinched it.
Good luck with your build.
regards
Neil Wyatt10/12/2016 20:35:22
15459 forum posts
651 photos
72 articles
For the record, I got 6 or 7 responses from breakeryard,. I put in my old Vectra's registration so a fairly hefty fan. Prices came back from nearly £60 down to £20.
I have a suspicion that a high-torque (with a soft steel outer wrapper) 540 'buggy motor' would do the job just fine is matched with a smaller but faster fan.
Doubletop11/12/2016 10:19:35
381 forum posts
4 photos
I'd started making a blower along the lines of the article, prior to it being published. I needed a motor and realised I had one of these laying around.
Its more than adequate and needs a speed controller otherwise you'll be sucking coal down the firetubes !!
Seriuosly this motor makes such an effective blower. I was using it for the first time the other day and once I'd got steam up one of the guys wanted to try it. He said "put it on full" as he only had about 10 psi on the guage. He went from 10psi to safety's blowing in less than a minute.
OK Jaycar is Oz/NZ but these are Chinese products so I'm guessing Maplins (are they still around?) will do similar, otherwise its Ebay or Alibaba.
Pete
PS - 7.25" guage locos. The tube for the chimney is 2" I'll do some photos if more details are required.
Edited By Doubletop on 11/12/2016 10:22:03
paul rushmer11/12/2016 12:44:28
72 forum posts
10 photos
Just a thought when Blackgates first designed Charlatan (5" 08 diesel shunter ) they used 4 smiths motors, still listed at £42.50 each but I do not know if they are he same, worth a phone call?
Paul
Doubletop13/12/2016 09:39:35
381 forum posts
4 photos
Here's my nearly finished blower for a 7.25" loco (Dart) with the Jaycar motor (see link above)
The rotor was supposed to be just some flat baldes welded to the two plates. i don't have welding kit so made a hub and copper plades and silver soldered it all together. The other plate is held on stand offs like the main body. Rather than spending time making standoffs I used 1/4" stainless tube and 4ba bolts
By the way the direction of rotation is with the sweep of the blades trailing. I felt that the leading face would swash the air outwards and a vacuum would be created in the concave cavity of the trailing face. The combined effect drawing air from the center
This blower (sucker) is cabable of lifting something the size of a book off the table.
And the speed controller
Hope that helps somebody.
Pete
Edited By Doubletop on 13/12/2016 09:41:29
Ian S C14/12/2016 11:45:32
7190 forum posts
227 photos
Not quite as efficient, but the blades will work even if they are just straight flat plates set radially.
Ian S C
Doubletop15/12/2016 08:55:45
381 forum posts
4 photos
I wasn't sure that would be the case or whether flat blades should be offset from the radial axis. A bit of googling indicated that any would work to some degree or other. However as I had no way of welding on the flat blades I'd been given with the disks I had to seek an alternative.
I did consider the tabs similar to those used by Brian or tabs a push fit into holes in the discs and the whole lot clamped together as a sandwich with the spacers and bolts.
In the end I went for the copper blades and silver solder. Adding the curved blades wouldn't be a problem. They were just annealled and bent by hand around a 3in tube.
Pete
Kerrin Galvin16/12/2016 08:23:31
38 forum posts
9 photos
Hi Pete,
I built a sucker a while back, I used the fan out of a vacuum cleaner, no idea which as I nicked the fan off dad! I enclosed the fan and attempted to make an involute ( well I think it is) put an chimney on it so the smoke is directed up, not much fun breathing up coal smoke, espeacally if it's got sulphur in it! Like the idea of a speed control, have to go to Jaycar & get one.
Cheers Kerrin
Doubletop18/12/2016 06:21:59
381 forum posts
4 photos
Posted by Kerrin Galvin on 16/12/2016 08:23:31:
Hi Pete,
...... Like the idea of a speed control, have to go to Jaycar & get one.
Cheers Kerrin
Kerrin
When you read the instructions you'll see that you will need a diode across the motor to protect the unit from back EMF. Its a 1N5404 so order one at the same time.
I found out too late.
Pete
Brian Baker 118/12/2016 07:42:04
78 forum posts
13 photos
Greetings, Doubletop is quite correct to say that curved trailing fan blades are more efficient & would be used in industry, but, please remember that this blower is designer to tempt locomotive purchasers into becoming builders, and the use of straight blades makes it easier to construct for a beginner.
The suggested motor seems fine, thanks for that, and as stated a speed control really helps to stop pulling the fire out in the early stages of steam raising.
regards
TRANSWAVE Converters
