Suction Cup Adhesive
mick H24/11/2016 15:26:55
763 forum posts
28 photos
I have bought a SatNav with a standard suction cup base which I would like to sit in the centre of the car dashboard. Unfortunately, the dashboard, whilst pretty smooth, is not smooth enough to allow proper adhesion. There are plastic discs available to first stick on the dashboard and then the suction cup is applied to the disc. As an alternative I was wondering whether there is such a thing as a "low tack" adhesive which could be applied to the suction cup to enable it to create the necessary vacuum to hold it in place? The ideal substance would also be easily removable from the dash and the suction cup if necessary. Any ideas most welcome.
Mick
Roger Provins 224/11/2016 15:39:46
344 forum posts
"The 3m adhesive can be removed without leaving a residue when you are finished with the mount."
US site but probably available in UK
Roger
Journeyman24/11/2016 15:40:46
1114 forum posts
221 photos
You could try one of these airvent clips it saves glue and messing up the dash. Don't forget to remove the SatNav from display when parked up. You can now get lost with GPS authority!
charadam24/11/2016 15:48:46
185 forum posts
6 photos
Try a search for "dashboard sticky pad". Ebay has hundreds.
Neil Wyatt24/11/2016 16:09:58
18899 forum posts
734 photos
80 articles
My GPS holder stuck to the window was given as an MOT fail last time! Easy to fix....
Brian Oldford24/11/2016 16:27:02
686 forum posts
18 photos
Try those double-side self-adhesive foam pads.
Martin W24/11/2016 17:28:33
908 forum posts
30 photos
Hi
TomTom do what they call a beanbag mount as shown here. I have had one for some years now and found it very stable when placed on the dash of other flatish surface in the car. The benefit is that it can be removed and put somewhere discrete at the end of the journey and leave no indication that there might be a satnav in the car. You can of course move it about until you find a place that suits you and your driving style.
Marttin W
john carruthers24/11/2016 17:39:35
612 forum posts
180 photos
egg white ? works on fine textured plastic and obscured glass.
Mike Poole24/11/2016 17:46:11
3168 forum posts
72 photos
As I got a 7" tablet free with my tv, I stuck it in the car with 3 blobs of blutak on the odd occasion I needed a sat nav, worked a treat.
mick H24/11/2016 18:54:46
763 forum posts
28 photos
Thank you, gentlemen, for the usual excellent selection of options.
Mick
Ady125/11/2016 00:42:22
4910 forum posts
726 photos
A glue gun will give you a rock solid join for as long as you want and the adhesive peels off surfaces when no longer required
They replace gluey stuff in a myriad of situations and cool to a permanent joint in around 5 minutes
Sandgrounder25/11/2016 07:12:15
237 forum posts
6 photos
It might only fit a Garmin but I've just bought a 'portable friction mount' for my '5" Garmin Drive 50', it has a flexible sticky gel base which forms to the curves on the dashboard, I was very sceptical about it's performance when I bought it but it works great, just put it on and either leave it or take it off when not needed. I bought it from Halfords for £19.99 and was very pleased, Halfords now have them for £9.99 so I would have been even more pleased had I waited a few weeks.
http://i1.adis.ws/i/washford/164040?w=637&h=403
Edited By Sandgrounder on 25/11/2016 07:12:58
Steven Vine25/11/2016 09:00:44
340 forum posts
30 photos
Gluing and marking the dashboard, it does not seem right to me. Lay the damn thing near the gear stick somewhere.
An Audi dealer i used to know told me they had to take back a car when the buyer could not keep up the payments. To their horror they found the buyer had screwed a crappy old bent up L bracket to the dash with two wood screws, and bent up some wire to make a cup holder! The car was brand new. It cost them a fair few bob to replace the dash.
Steve
Neil Wyatt25/11/2016 09:14:33
18899 forum posts
734 photos
80 articles
Posted by Steven Vine on 25/11/2016 09:00:44:
One ring short of an Olympics
Steven Vine25/11/2016 09:19:26
340 forum posts
30 photos
Posted by Neil Wyatt on 25/11/2016 09:14:33:Posted by Steven Vine on 25/11/2016 09:00:44:
Lol. laugh
Bodgit Fixit and Run25/11/2016 09:53:49
91 forum posts
Be careful what you use on the dash. I had a cardboard air freshener sat on it. which dissolved the top layer of the plastic. it was freebee from a car wash. Oops.
mark costello 125/11/2016 20:19:04
685 forum posts
12 photos
MOT fail? How picky is that! (Living in Ohio USA with no vehicle inspections.)
Cornish Jack25/11/2016 21:27:39
1219 forum posts
171 photos
Two possible solutions -
1. buy a Berlingo - fixed quarter light is ideal fixing point and no problems with opening windows.
2. Shape a piece of Perspex, or similar, to fit the width of a dashboard storage pocket and wedge it into position with the ubiquitous heavy duty white foam. Can also be used as a small drinks table (while stationary!!!) Have both of these ... 2. in VW Passat.
rgds
Bill
Howard Lewis27/11/2016 21:45:15
5751 forum posts
13 photos
To prevent any telltale rings where the sat nav had been mounted, I formed an Aluminium sheet to the shape of the dashboard, and clamped the sat nav to it, along with a lump of steel to add some ballast.
To the underside of the Aluminium sheet was glued some "nonslip" rubber sheet. It takes quite a big bump to shift it even slightly.
After use, it can be locked in the boot, (trunk) or taken with me, leaving no trace that there might be a sat nav somewhere in the car waiting to be stolen.
Gordon Tarling28/11/2016 10:21:38
180 forum posts
4 photos
I use one like this - **LINK** and use a piece of non-slip matting underneath it. I hasn't moved yet.
Edited By Gordon Tarling 1 on 28/11/2016 10:21:58
JD Metals
MIDLNDS GARDEN RAIL Jan 2022
rapid Direct
