Which Clinometer?
SteveM06/11/2016 00:39:28
64 forum posts
16 photos
I quite fancy putting a clinometer on my 'crikey I need one of those' list. Not one of the new fangled digital things (yet) but one of the qualty instruments from yesteryear. I've narrowed it down to two models like the ones pictured, both made by Watts/Hilger Watts/Hall Watts or even Taylor Hobson.
Do any of you have any interesting experience with these devices? Which would be the most accurate of the two? And what are the pros and cons of each?
Edited By SteveM on 06/11/2016 00:40:53
Peter Krogh06/11/2016 01:26:43
219 forum posts
20 photos
I quite like the type shown in your first picture. They are simple, rugged, straightforward tools. Nothing more than a rotary table set vertical with a sensitive bubble. Quite easy to check and, if needed, calibrate.
That's my vote. Now please send that one to me! angel 2
Pete
Speedy Builder506/11/2016 07:35:15
2447 forum posts
195 photos
Get one which will fit on whatever you are measuring??
Michael Gilligan06/11/2016 09:45:57
19291 forum posts
960 photos
Steve,
The first one you illustrate only goes to 90° so it may prove difficult to read in some locations.
The second is a pendulum clinometer ... like those new-fangled digital devices [but properly made devil]
You might also consider the TB 121-1 which is a very nice bubble [in]clinometer, reading both directions, and reasonably compact. .... see recent ebay listing, here: **LINK**
Hacksaw06/11/2016 09:48:18
455 forum posts
191 photos
I've got a Taylor Hobson one ... in a box..somewhere...I thought it looked kinda useful when i bought it . Humph , never has been ! One on ebay is £130 ! mine 100quid less ! £30 plus post if you want it
Rik Shaw06/11/2016 09:51:02
1463 forum posts
396 photos
I like the lovely looking Watts but practically it would be a bit "overkill" for me. I regularly use my WIXEY digital leveler simply because it ticks the boxes for me. It's small, very accurate, and has a magnetic base (very handy).
Still and all, that Watts is a lovely instrument and one I also would like to own. Something beautiful to look at and caress now and then (I'm getting a bit old for the other stuff.)dont know
Rik
Hacksaw06/11/2016 09:56:40
455 forum posts
191 photos
Posted by Hacksaw on 06/11/2016 09:48:18:
edit ! £130 "buy it now" is a chancer ,going by completed listings even £30 is dear for a Taylor Hobson.... Mine £ 20 +post smiley
SteveM06/11/2016 12:01:16
64 forum posts
16 photos
Peter - I like that one too!
Builder - I haven't got anything in particular to measure and I know that one of the dinky digital devices will do all the measuring and fit everywhere I need. I want something that'll be useful for a number of things occasionally, but in particular I want one of these because it's a beautiful tool. Sad but true.
Michael - thanks for the tip, I hadn't seen one of those. Now it is also on the list!
Hacksaw - PM sent. Also nice username.
Rik - I agree almost word for word with both paragraphs!
Steve
Ed Duffner06/11/2016 12:14:42
831 forum posts
94 photos
I've recently been given a smart phone, my first one ever! and found a couple of 'apps' that offer this function. Possibly not ideal for a coolant soaked machine though
Ed.
Hacksaw06/11/2016 12:40:38
455 forum posts
191 photos
I've got a Mitsubishi Pajero . There's one on top of the dashboard smiley
John Haine06/11/2016 12:42:51
4272 forum posts
251 photos
One thing to consider is the size of the thing. Try doing this with one of the above.
JasonB06/11/2016 13:24:05
21632 forum posts
2493 photos
I originally imported my Wixey from the US before they and the copies became commonplace, It was the ideal thing to stick on the side of my tablesaw blade to set the angle.
Callibration was mentioned earlier, the Wixey is zeroed at the tough of a button on any surface so even if your saw table, mill, lathe bed, etc is not spot on it is easy to set to zero and measure the angle relative to that surface. Also stays stuck to a lathe chuck so you can do simple angular setting out.
Michael Gilligan06/11/2016 15:17:16
19291 forum posts
960 photos
Posted by SteveM on 06/11/2016 12:01:16:
Steve,
Just to confuse the list slightly:
My example is badged 'Rank Taylor Hobson Ltd.' 142/42
I've attached a copy of the [very brief] instruction leaflet for info.
Nicholas Farr06/11/2016 15:18:56
3050 forum posts
1385 photos
Hi, those Clinometers look very nice, but unless your planning to build a bridge over a large river for example or something similar, they are not exactly user friendly in an everyday workshop. However nothing wrong with owning one for the sake of it. I have a Wixey also, which I find is very accurate for various jobs. I also have a couple of these **LINK** which have an advantage that they can be set back to true level at any time, but one down side is they don't have a magnetic base.
Regards Nick.
Samsaranda06/11/2016 18:56:11
1246 forum posts
5 photos
Remember using a Clinometer in the early 60s for checking dihedral on aircraft wings when I was an aircraft technician in the RAF, once we passed out of training never saw or used one since. I have one of the small digital angle gauges, great bit of kit.
SteveM06/11/2016 22:07:27
64 forum posts
16 photos
Thanks for posting that Michael. They certainly didn't go overboard with instruction manuals in those days!
Steve
Ian S C07/11/2016 09:21:22
7468 forum posts
230 photos
12 Bore, the one you used during training was probably the only one they (RAF) had, probably dates back to 1914/18.
Ian S C
rapid Direct
walker midge
JD Metals
