Rubber hose
steamdave24/10/2016 14:58:58
435 forum posts
33 photos
I'm looking for some wound rubber hose either 1/8" or 4mm bore. The sort of thing would be like the hose used on loco brake pipes, but I can't find it in the catalogues I've looked at.
About 18inches total length needed. Does anyone know of a supplier?
The Emerald Isle
JasonB24/10/2016 15:11:28
17854 forum posts
1954 photos
Not seen it that small Dave. You may have to resort to winding wire around a plain hose and then covering with heat shrink insulation.
not done it yet24/10/2016 15:34:49
4503 forum posts
16 photos
A length of bicycle valve rubber?
steamdave24/10/2016 16:19:10
435 forum posts
33 photos
JB. Your idea is ok, if I can find thin enough rubber to start with. Don't want it too bulky!
NDIY. Can you get bicycle valve rubber in long lengths (2 x 9" or 4 x 4-1/2" - ish)? If so, that might be better than JB's idea.
The Emerald Isle
Roger Provins 224/10/2016 16:26:02
343 forum posts
Try Demon Tweeks http://tinyurl.com/h2rktp3
Roger
steamdave24/10/2016 16:50:26
435 forum posts
33 photos
Found some. From our favourite on line auction establishment: 190885058500. Shoulda looked there in the first place!
Thanks for the various suggestions.
The Emerald Isle
JasonB24/10/2016 17:16:55
17854 forum posts
1954 photos
But that is smooth hose, I thought you were after something that looked like the old reinforced hose. Could have pointed to to smooth straight away
