4 jaw chuck jaw numbering
David Colwill24/10/2016 10:21:07
779 forum posts
40 photos
So my 4 jaw chuck doesn't have any legible numbers on the jaws. Up to now I have written them on in marker pen as required which is fine but they do rub off rather easily. I was thinking about getting the number stamps out but then thought do I go 1,2,3,4 or do I go A1,B1,A2,B2 or is this over complicating things.
Any thoughts.
David.
Ian Parkin24/10/2016 10:25:00
1035 forum posts
243 photos
Surely on a independant 4 jaw it does not matter which goes where
MW24/10/2016 10:28:39
2051 forum posts
51 photos
Posted by Ian Parkin on 24/10/2016 10:25:00:
Indeed, they are all screw forms, they only stamp numbers on the order of the jaws on the face of the chuck so that you can remember which ones you have set up. not because it's important which goes where.
Michael W
Edited By Michael Walters on 24/10/2016 10:49:38
Ian S C24/10/2016 10:34:41
7468 forum posts
230 photos
You only need to number the jaws on a self centering chuck, whether 3 jaw or 4. I do tend to keep the jaws of my 4 jaw chucks in the same positions out of habit, take it out, turn it round, put it in, next jaw and so on.
Ian S C
Tim Stevens24/10/2016 10:37:16
1622 forum posts
You are likely to have difficulty with stamps, as the jaws will be hard. If you do decide to mark (unnecessarily) then perhaps etching ?
Tim
David Colwill24/10/2016 10:39:40
779 forum posts
40 photos
No but when adjusting jaws it is useful.
David.
David Colwill24/10/2016 10:40:28
779 forum posts
40 photos
I was thinking of the chuck body.
David.
Tim Stevens24/10/2016 11:02:35
1622 forum posts
You can mark the body (usually) with a series of 1, 2, 3, 4 centre-punch marks on the cylindrical surface.
Cheers, Tim
Michael Gilligan24/10/2016 12:30:34
20289 forum posts
1064 photos
Posted by David Colwill on 24/10/2016 10:40:28:
That may indeed be useful. David ['though I hadn't contemplated it before]
Thinking about the 4-jaw centering process;
I might be tempted to mark the body N E W S [as in points of the compass].
P.S.
Solar astro-photographers may prefer the alternative sequence N W S E
Edited By Michael Gilligan on 24/10/2016 12:31:20
Nick Hughes24/10/2016 12:37:04
264 forum posts
144 photos
Just mark 2 opposing positions with a center punch mark,. no need to mark all 4 positions, unless you really struggle to remember the last jaw you adjusted.
Nick
Edited By Nick Hughes on 24/10/2016 12:39:05
Neil Wyatt24/10/2016 12:39:12
19076 forum posts
736 photos
80 articles
Posted by Michael Gilligan on 24/10/2016 12:30:34:
P.S.
Lunar astrophotographers may disappear in a puff of logic trying to decide.
old Al24/10/2016 14:14:09
186 forum posts
most 4 jaw chucks have a manufacturers label on the face of the chuck.
Use the jaws adjacent to the label if you are doing repetition type work. Maybe mark the bit of work with felt tip to coincide with the label, if it has to go back after another operation.
Yes you wear two jaws out quicker than the other two. And in my life time, i dont think i will notice.
David Colwill24/10/2016 14:40:32
779 forum posts
40 photos
Posted by Nick Hughes on 24/10/2016 12:37:04:
Nick
This is indeed why I was thinking of doing it. Also I had to return a job to the 4 jaw after a couple of weeks, The numbers I had written on in marker were not visible and I had no idea which jaws I had slackened off. If I had numbered them I would almost certainly slackened 1 and 2 or A1 and B1.
It does seem that I'm being a bit dim here but my mind doesn't work the same as most other peoples.
David.
Ady124/10/2016 15:15:01
5161 forum posts
738 photos
Nearly all chucks have a logo, which is 12 oclock
Then I line up my jaws on the cross slide and enter the first one at 10 o'clock(smallest tooth) and engage it, insert the second at 7 o'clock and engage it, then the third at 5 and the 4th at two
So you don't really need numbers, just the order of engagement in relation to the logo and the first jaw (smallest tooth one) progressing clockwise to the largest tooth size
Works for 3 and 4 jaw chucks, you only really need to know where number 1 goes in relation to the logo and the rest fall into place
simples!
Edited By Ady1 on 24/10/2016 15:21:54
Neil Wyatt24/10/2016 16:45:32
19076 forum posts
736 photos
80 articles
Should the numbers increase clockwise or anticlockwise? And should this be viewed from the headstock or the tailstock end?
Perhaps 0-3 would work better than 1-4,? Why not ABCD. 00, 01, 10, 11 might be useful if it's a digital lathe?
I'll get my coat^H^H^H^H workshop overalls...
MW24/10/2016 17:33:50
2051 forum posts
51 photos
Posted by Neil Wyatt on 24/10/2016 16:45:32:
You could even have playstation markings with triangle, circle, x, square. I saw a kid with that tattoo once.party
Michael W
Edited By Michael Walters on 24/10/2016 17:34:34
phil burley24/10/2016 19:18:37
45 forum posts
I was wondering why my chuck is marked 1234 , is it just so you know which you have moved then ?
Phil
old Al24/10/2016 20:28:43
186 forum posts
Now, just think. If a 4 jaw chuck was invented today, every jaw would have to be a different colour. wouldnt that make life easier
Ady125/10/2016 00:28:36
5161 forum posts
738 photos
tsk tsk tsk
I should have said anticlockwise, wot a muppet
As viewed from the tailstock end of the lathe
So you don't really need numbers, just the order of engagement in relation to the logo and the first jaw (smallest tooth one) progressing anticlockwise to the largest tooth size
simples! (if you're not a muppet)
Edited By Ady1 on 25/10/2016 00:32:24
Hopper25/10/2016 00:59:21
6623 forum posts
347 photos
Not one of my chucks has a distinguishable logo. (They may have done 80 years ago, who knows?) But I do like the idea of number stamping 1,2,3,4 on the body next to the jaws, just for keeping track of where the high spot is when truing up work. Sometimes I lose track of whether I am sneaking up on true, or have gone past it and the high spot has now moved to the other side "over centre". Chalk marks and pen marks all seem to get wiped off by greasy mitts during the process.
Rapid RC
Dreweatts
