Forum sponsored by Allendale Until July 27th
Gillett & Sibert [Scottish microscope makers]
Seeking Information ...
DAvid Wright 1817/02/2018 12:59:33
3 forum posts
Apologies - don't really checkthis forum and didn't get an email alert!
I'll check it now
Raymond Griffin17/02/2018 15:27:23
42 forum posts
25 photos
These microscopes were popular in the past with some Cytology Laboratories, screening cervical smears for cancer. They were equipped with a compact quartz iodine (QI) lamp; useful for the technique of blue light fluorescence. In this technique FITC (fluorescence isothiocyanate) used as the fluorescent stain, fluoresced with the wavelengths generated by the QI lamps. It was claimed that Blue light fluorescence gave higher detection rates of malignancy than the traditional Papanicolaou (PAP) stain. It was an elegant idea that did not become established.
Expensive and potentially explosive mercury vapour lamps and strong filters normally required for Ultra Violet light fluorescence were not needed.
I retain a G&S for use, though have replaced the objectives with Leitz products; to my mind superior.
Happy microscopy.
Ray G
Michael Gilligan17/02/2018 17:10:29
13271 forum posts
578 photos
Thanks for the notes, Ray yes
It's all so much easier now ... with Blue-Violet light sources available as regular or laser LEDs.
Incidentally; the only real problem I've found with this G&S Conference Microscope is the field condenser diaphragm: ... This is badly buckled, because some previous user had tried [too hard] to adjust it, when it was seized-up with hardened grease.
sad
My working assumption is that the heat from the QI lamp is the source of that problem.
I have dismantled the diaphragm, but flattening the blades will be a real challenge.
Michael Gilligan17/02/2018 18:24:56
13271 forum posts
578 photos
UPDATE:
I have just been informed, on good authority, that the grease-stuck diaphragm is not a common fault on the G&S Conference Microscope. ... That said; it is, of course, known as a potential problem on any microscope with a powerful lamp.
Graham Compton08/05/2018 23:13:25
10 forum posts
2 photos
I've come rather late to this posting but:
I have a G&S Conference microscope. It's a hernia job to move as it has a generous 100W built in power supply. I also have a G&S inverted microscope (that's equally heavy). More to the point, I have some G&S literature that a member of the Quekette (spelling) Society was kind enough to provide. It's a while since I looked at it but I think it's advertising literature. I can send you a copy.
regards
Graham
Michael Gilligan08/05/2018 23:26:07
13271 forum posts
578 photos
Many thanks, Graham
I will send you a 'Personal Message' with my contact details
[go to the Inbox icon on the green bar, at the top of this page]
Meridienne Sept 2019
Ausee.com.au
TRANSWAVE Converters
