Forum sponsored by Allendale Until July 27th
Gas burner for steam plant
Design ideas needed
Peter Russell 105/08/2016 16:39:00
3 forum posts
I have just finished phase 1 of my latest project - a 5 foot long rear paddle steamer - at present powered by an electric motor. Phase 2 is steam power and I'm well on, having built the boiler and started on the cylinders. What I need now is information- and possibly a proven design- for a gas torch burner for the boiler. The fire tube is 1 inch od, so the burner has to fit that. If anyone can point me in the right direction I would be grateful. Thanks.
By the way, if anyone's interested, you can see the development of the steamer here:-
www.steamrail.co.uk
Chris Shelton05/08/2016 19:35:32
77 forum posts
45 photos
It might be worth having a look at myfordboy on YouTube, part 12 of his constructing a traction engine article, which uses a cheap pencil gas torch as the basis of the gas burner.
HTH
Peter Russell 107/08/2016 08:22:05
3 forum posts
Thanks for that, but I think it might be a bit too small. My boiler is about twice the size of his so it's going to need a lot of heat.
Ian S C07/08/2016 12:43:15
7382 forum posts
230 photos
I have seen a burner in the form of a Bunsen burner with the end blocked, and holes along the barrel for the flames. I think it was about 1/2" diameter x 4" long.
Ian S C
duncan webster07/08/2016 15:17:15
2105 forum posts
26 photos
If you want a torch type burner why not buy one from Sievert, or canibalise one off a blowtorch?
If you want a poker type then **LINK**
is quite good.
If you want radiant heat (might be optimistic inside a 1" tube) then **LINK**
look good. I think Cheddar used to make something similar, but can't find them on the interweb
Peter Russell 108/08/2016 17:08:36
3 forum posts
Thanks for that guys. You have given me a few ideas.
I've got a spare Ronson gas torch lying in the workshop.
I think its about to be modified.
Peter.
TRANSWAVE Converters
