Bengs 'Karl' Hit & Miss engine.
My first engine build.
Andy Holdaway26/04/2016 16:33:35
167 forum posts
15 photos
After having no joy with the Bengs Stirling 'Laura', I decided to have a go at their Hit & Miss engine, Karl.
It's taken 4 months, and has been a steep learning curve but I finally got there!
Just need to take it all apart now and repaint it using fuel proof paint - Duh!!
Andy
JasonB26/04/2016 16:47:48
17089 forum posts
1839 photos
Runs well Andrew, I like the lever to bring the hit & Miss governor into action, not seen that on a model before.
pgk pgk26/04/2016 17:14:13
1519 forum posts
285 photos
Looks good!
Andy Holdaway26/04/2016 17:19:03
167 forum posts
15 photos
Thanks Jason and pgk, the lever just turns a cam that holds off the governor. I will be replacing the coil with a CDI unit when I strip it down, the ignition's a bit optional as the plug sits quite deep in the head and the spark isn't particularly strong.
Apologies for the poor quality video, it's the first time I've used the camera for about two years and I probably should have cleaned the lens first.
So the question is, what next? I don't have a milling machine (yet) so I'm a little restricted on what I attempt. I suppose I should revisit my failed Laura stirling engine before starting anything else.
Andy
Edited By Andrew Holdaway on 26/04/2016 17:37:04
fizzy26/04/2016 18:06:54
1670 forum posts
114 photos
I do like that!
MichaelR26/04/2016 18:51:20
350 forum posts
64 photos
I like that engine which prompted me to have a search and found this. Here    Mike.
Edited By MichaelR on 26/04/2016 18:52:58
Robert Askew 110/02/2019 21:23:12
25 forum posts
6 photos
just got my kit
and I must say the drawings and info supplied leave a bit to be desired
John Olsen11/02/2019 05:15:54
1002 forum posts
86 photos
What sort of problem are you having with the Stirling engine? They tend to need accurate work, eg pistons a good fit without being too tight, any sliding seals do not need too much friction, and so on. Any sort of air leak is bad. There are people around here, like Ian SC, who have made a lot of hot air engines and might be able to advise. I've only made one, the Rider Ericsson one. It goes well, but even just a little over tightening of the gland on the little water pump is enough to stop it.
Ian S C11/02/2019 10:39:59
7468 forum posts
230 photos
John's pretty well covered the Stirling engine. I'v been looking at your build thread from 2 or 3 years ago, you were going well right up to the end, then you pulled it apart to clean things up, then you had alignment problems, I think if you fix that you should be OK. One thing that I like is the displacer rod guide, but it could be trouble if not dead on lined up.
Ian S C
Robert Askew 111/02/2019 11:59:49
25 forum posts
6 photos
i am not making a sterling engine,I am making a Bengs hit and miss open crank 4 stroke engine,the problem is some the drawings are missing dimensions, I have to keep e maling bengs to get the sizes,and they don’t seem concerned that they are missing
Ian S C12/02/2019 13:04:23
7468 forum posts
230 photos
Sorry Andy, got a bit mixed up with another Laura. It might be worth having another bit of a go at yours sometime in the future, it's good to get it up and running.
Ian S C
Robert Askew 122/04/2019 17:45:58
25 forum posts
6 photos
Just finished my bengs hit and miss Karl
cant get it to run
checked timing got spark and loads of compression so much I can hardly spin it past tdc
any suggestions
Ian Skeldon 222/04/2019 19:58:11
421 forum posts
29 photos
Nice engine Andy.
