Special ER Collets
Following on from Vic's "Wouldn't it be Nice?" thread and not wishing to hijack that thread
Peter Greene03/04/2016 19:04:15
15 forum posts
ER collets have always seemed to me to be a very versatile system and I'm surprised some enterprising manufacturer hasn't come up with special collets.
Two which I would find useful:
- collets with a shortened grip length (longer rear counterbore) so that short screws could be held for end-finishing after cutting from a longer screw. I know there are other ways but they get progressively more fiddly as the diameter gets smaller.
- collets with a recess on the face that would hole thin round parts - washers etc - for facing or boring.
I don't see any particular difficulty in doing these and perhaps other specials. In fact I've made the second one myself a couple of times using carbide toos on a standard collet.
Michael Gilligan03/04/2016 19:14:52
16408 forum posts
715 photos
Peter,
Given that the ER gets its extended range by being slit from both ends ... I would have thought that any such modification might lead to distortion of the collet under clamping loads.
That said: I'm delighted to hear that you have had some success.
JasonB03/04/2016 19:23:14
18915 forum posts
2082 photos
As both of those uses are work holding then emergency 5C collets would be a good option with the added bonus that they hold at the business end as Michael mentions. The washers can already be done in a 5C with an elephants foot extension to a backstop.
All these specials would mean a large outlay for any supplier if they were to be in all the increments of the popular ER ranges, could quite easily run into 100 stock items which would have a limited turnover.
I do think there would be a market for emergenct ER collets as ER1-40 would only meanhaving to stock six products which the purchaser could then make to exactly their screw, washer, tool, etc. size as most people don't want to set up to get the angles and cut the slots.
J
Neil Lickfold03/04/2016 19:41:54
637 forum posts
102 photos
I have made Delrin ER40 collets, and for special collets , I just made them from P20 tool steel, and slit them with a slitting saw on a mandrel to stop it collapsing in on the saw.
Michael Gilligan03/04/2016 20:01:43
16408 forum posts
715 photos
It may be worth talking to JWA Tooling
Edit: This is going off-topic, I'm afraid, but
have a look this mad and rather pricey collet nut !
Edited By Michael Gilligan on 03/04/2016 20:14:25
Vic03/04/2016 20:05:57
2615 forum posts
20 photos
Half inch square ER32 would be handy if it's doable?! smiley
Ian P03/04/2016 20:55:39
2420 forum posts
101 photos
Posted by Michael Gilligan on 03/04/2016 20:01:43:
Well I could imagine that would work on some materials and at high spindle speeds and if someone wants to spend that much then its up to them. A moulded plastic fan with a bore to suit normal ER nuts and then just pushed on, would do the same job.
You could buy a 3D printer, print a fan and have lots of money left over!
Then again you could do the job properly and print it using 3D laser sintering.....
Ian P
JasonB03/04/2016 20:57:34
18915 forum posts
2082 photos
Posted by Vic on 03/04/2016 20:05:57:
Should be able to hold that in an 18mm collet by the corners
Vic03/04/2016 21:02:14
2615 forum posts
20 photos
Expensive nut! They do collets in 1/2mm steps (which could be handy) but at $27 each they can keep them. cheeky
John Reese03/04/2016 21:02:48
847 forum posts
Could you explain elephant's foot to me. Never heard that term in the shop.
Thanks,
MW03/04/2016 22:30:21
2051 forum posts
51 photos
I think they don't exist commercially speaking, for precisely the reasons you gave, those uses are far too specialist for it to make any kind of money in the volume you'd need to sell. I would add further that they probably do exist but only when commissioned to do so.
The latter collet could be quite troublesome if you were tempted to use a longer piece of rod or take too big a bite as the grip range would be too small, even with ER collets as they are they can slip occasionally.
That's not knocking what you said too much i hope, i do like to hear new ideas people have, i just hope too much criticism doesn't put people off putting their head above the pulpit.
Michael W
Peter Greene04/04/2016 01:36:27
15 forum posts
Posted by JasonB on 03/04/2016 19:23:14:
.... but with the added disadvantage that, if you've concentrated mostly on the ER system and your 5C gear is minimal, then you need a considerable outlay to go that route.
Peter Greene04/04/2016 01:50:18
15 forum posts
What I was thinking of more was that, with decent tooling, specials such as these could be modified from existing collets. In that case I wouldn't think it would be a significantly different undertaking than, say, the ER collet blocks.
True, but you could say that of almost any tool (or many other things) that we use. They all have their limitations; we all push them a bit beyond those limitations in a pinch; thus doing, we find out what the absolute limitation is in our own situation and we gain experience.
Not at all - fair comment. And on-topic wink
(I do wish this editor would let us intersperse quotes with comments properly. Sometimes it really is the best way.)
JasonB04/04/2016 07:37:52
18915 forum posts
2082 photos
Posted by John Reese on 03/04/2016 21:02:48:
Thanks,
More often used when talking about DTIs, basically its a flat "foot" on teh end of a shaft. As the usual 5C end stops are about 8mm dia they would not support a large flat washer so fit a "foot" to the end and you have something to push the washer against.
The ER system is really a tool holding system and its model engineers with there usual deep pockets that have taken to using it as a work holding system. The are other advantages of having two collet systems, for example if you have gone for an all ER system and are holding say a 10mm dia bar in your ER block on the mill and want to use a 10mm shank cutter on that work how are you going to hold it? A second set of ER collets maybe
Edited By JasonB on 04/04/2016 07:45:33
Ian P04/04/2016 11:41:33
2420 forum posts
101 photos
MG mentioned quite correctly, that as ER collets are slit at both ends they are unsuitable for gripping items that only touch the very front of the collet.
However it one had a particular requirement (and only had ER and not 5C) that justified making a one-off collet then a custom ER collet could be made that was only slit at the front.
It might not have the optimum taper angles or closing system but I cannot see why it would not work.
Ian P
JasonB04/04/2016 12:30:15
18915 forum posts
2082 photos
Another option is a simple split bush. Below is a collet from my router on the right which is very similar to an ER type collet and on the left a 1/2" to 8mm reducer which only has one of the slots cut all the way through, just slips into a 1/2" collet. Good for 23,000rpm and quite deep cuts so should be OK for a drill bit or small item of work
Edited By JasonB on 04/04/2016 12:30:46
Michael Gilligan04/04/2016 12:34:41
16408 forum posts
715 photos
Posted by Ian Phillips on 04/04/2016 11:41:33:
Ian P
Quite correct, Ian yes
I was thinking along those lines whilst we were out this morning [domestic chores].
It would, of course, remove the 'extended range' ... but that should not be too much hardship on a 'special'.
Gordon W04/04/2016 14:22:04
2011 forum posts
For gripping short ends you can put another short end at the rear.
Michael Gilligan04/04/2016 15:13:51
16408 forum posts
715 photos
Posted by Gordon W on 04/04/2016 14:22:04:
This ^^^ is true
John Stevenson04/04/2016 15:18:36
5068 forum posts
The Jacobs rubberflex collet chuck was supplied with rubber bungs for putting in the tail end for just this purpose
EngineDIY
