Myford super 7 tailstock thread
Myford super 7 tailstock lever feed attachement
ian j16/01/2016 18:27:54
306 forum posts
285 photos
img50.jpgHi.
I've just bought a tailstock lever feed attachement for my ML7R from the ads here, ( thanks Nick)
It did not include the barrel or the threaded cap which screws into the right hand side of the tailstock. I plan to make these parts (after all I have a lathesmiley )
Question is:-
(1) does any one know what the internal thread in the right hand side of the tailstock is?
(2) Can any one with this attachement measure these two parts?
I've incuded a photo (taken from lathes.co.uk) which clearly shows the two parts I hope to make.
ie. the barrel and threaded cap.
Thanks in advance.
Ian
Edited By ian j on 16/01/2016 18:31:30
Edited By ian j on 16/01/2016 18:37:12
John Stevenson16/01/2016 21:13:05
5068 forum posts
Think I might have a spare barrel and nut kicking about, check tomorrow as it's twenty past dark now and the workshop is haunted.
daveb16/01/2016 21:19:26
626 forum posts
10 photos
Anyone else think their old mill is haunted?
"Bill Hancox"16/01/2016 22:38:28
257 forum posts
77 photos
Mine is haunted with the ghosts of projects past.
ian j16/01/2016 22:54:02
306 forum posts
285 photos
John.
That would be great if you have.
Ian
Kenneth Deighton17/01/2016 10:01:50
69 forum posts
Place and press a piece of blue tack inside the barrel onto the treads, carefully remove and measure the threads, I have done this several times.
Ken.
ega17/01/2016 10:02:21
2326 forum posts
190 photos
ian j:
Congratulations on getting this excellent accessory; I can certainly measure mine if needed and look forward to you sharing your impressions of it in due course.
I have made one or two small improvements to the design and will look out a photo.
Kenneth Deighton17/01/2016 10:02:28
69 forum posts
I mean THREADS. Ken.
ian j17/01/2016 10:24:44
306 forum posts
285 photos
ega.
If you could go to the trouble of making a simple sketch with some dimensions on, this would be greatly appreciated.
Another question, In the photo I posted what purpose do the cap head screws on the RHS of the casting serve.
Ian
ega17/01/2016 10:27:31
2326 forum posts
190 photos
Photos:
As you can see, I have replaced the pivots which were worn; two are custom-made phos bronze bolts and the third is a modified shoulder screw. The clamp has been provided with a ball handle and the cap screws retaining the collar have been replaced with CSK screws to give a little more travel. Also visible is the knurled end of the draw bar which the lever feed makes possible.
I have fitted a slightly longer lever with a more comfortable handle. Because the device makes the tailstock "tail heavy" the new lever is taper drilled at the handle end to improve balance. Finally, the other end has been fitted with a brass nose so that the lever can be used as a drift to knock out tooling (see first photo).
Edited By ega on 17/01/2016 10:28:57
ega17/01/2016 10:34:52
2326 forum posts
190 photos
ian j:
Does my last post, which crossed with yours, answer your question?
I'll be delighted to do a sketch and suggest you PM me with your email address for this purpose, always assuming the offer from John Stevenson does not make this unnecessary.
ian j17/01/2016 11:23:23
306 forum posts
285 photos
ega.
Thanks for the photo's. It's becoming a lot clearer now on whats's missing.
I've sent  you a PM
Regards Ian
Edited By ian j on 17/01/2016 11:23:53
John Stevenson17/01/2016 12:46:42
5068 forum posts
Is this what you want Ian ?
ian j17/01/2016 13:36:43
306 forum posts
285 photos
John.
That's brilliant , the very thing.
I've sent you PM
Ian
ian j20/01/2016 13:12:06
306 forum posts
285 photos
p1201449.jpgThought I would post a couple of photo's showing the lever feed tailstock attachement now fitted to my ML7R.
Thanks to Nick for selling it, John for providing the missing parts ( I had to mill the key way approx. 1" longer to get the full travel) & ega for the photo's and the offer of assistance.( I wil make a draw bar as you have)
Edited By ian j on 20/01/2016 13:16:18
Edited By ian j on 20/01/2016 13:20:28
Nick Dring20/01/2016 13:30:09
8 forum posts
18 photos
Ian,
It's really good to see that the attachment went to a good home! My Dad would be most impressed with the installation on your machine.
Hope it serves you well in the years to come.
Nick.
ega20/01/2016 13:45:55
2326 forum posts
190 photos
ian j:
Thanks for the photos. That's a good-looking ball handle! As you know, I prefer a more hand-friendly handle on the lever itself.
Mark Kilgore21/01/2016 01:32:27
9 forum posts
I've been using one of these attachments for a few years. Had planned to install some sort of DRO, as many of you have, but found that I could set the travel stop within half a hundredth (inch) using a steel rule. That means I can watch the drilling process, not the readout, and let the stop worry about the end of the process. What a pleasure!
rapid Direct
walker midge
JD Metals
