Turning tool holder
Old School13/01/2016 12:15:42
323 forum posts
26 photos
I have got some PCD tips ref TPGW080202 and I need a holder for them any ideas where I can get one.
I want to use them for the turning of the outside diameter of pistons made from aluminium with a high silicon content
Thanks Oliver
David Clark 113/01/2016 13:29:47
3357 forum posts
112 photos
10 articles
I think Kennametal do them. I think that is where I used to buy the tips.
Old School13/01/2016 22:19:56
323 forum posts
26 photos
Had a look at Kennametal no joy can anyone one else help or do I make one its not going to be taking big cuts. Would mild steel do?
Emgee13/01/2016 22:43:35
1447 forum posts
212 photos
Have you considered using a left handed boring tool that takes the TPG inserts, you would of course fit the tool as a normal boring tool but use on the OD and not ID.
If you make your own you could use silver steel and harden and temper if required.
Emgee
Muzzer13/01/2016 22:56:23
2904 forum posts
448 photos
Triangular, 11 degrees clearance, ground, with countersunk clamp screw hole. 8mm inscribed circle, 2.38mm thick, 0.2mm radius. Something like this?
Bit of a minority sport by the looks of it. If you click under where it says "See pages B109–B112 for inserts", it shows you a pic of the dimensions etc. It has 5 degrees slope on the top mounting face. Combined with the 11 degree insert, that leaves 6 degrees of clearance. M2.5 / Torx T7 screw? You can get the screws from APT.
