Three cornered Philips type screwdriver
Brian Wood21/12/2015 11:28:59
2549 forum posts
39 photos
Rather than have to make one, does anyone know where I might be able to source one of these? It is for a security screw on the back of a time switch
They do exist, but my internet searches all lead me to the regular four point drivers
Thank you
Gray6221/12/2015 11:33:58
1057 forum posts
16 photos
Do a search for security or tamperproof screwdriver bit, it will bring up a number of options.
Dave Martin21/12/2015 11:36:18
101 forum posts
11 photos
Brian - try searching for "tri-lobe" or "tri-wing". Cheapest may be a bit set such as this one.
Keith Long21/12/2015 11:41:54
877 forum posts
11 photos
Try a quick google search for "tri-wing" screwdrivers or bits. Lots of places stock them, Amazon, Cromwell, Screwfix, Maplins possibly, it will depend on what's local to you. I bought a set of various "security bits" from Maplins, I think, that includes the tri-wing variety. One issue you might find is that as well as using the tri-wing design they are often in quite deep counterbores so it can be a bit if an issue actually getting the screwdriver deep enough to make contact. I've certainly found that using the 6mm hex screwdriver bits, the holder is too big to go down the counterbore,so an ordinary screwdriver type tool might be needed, in which CPC Farnell or RS might be a better bet.
Ady121/12/2015 11:44:16
5065 forum posts
734 photos
Pound shops and TKmax type places have little tool sets with those goofy fitments as well if you want to try an instant cheap option
Stuart Bridger21/12/2015 11:44:44
538 forum posts
29 photos
+1 on the security bit set. I bought one from Screwfix at a very sensible price and it has got me out of trouble many times.
Brian Wood21/12/2015 12:11:06
2549 forum posts
39 photos
Thank you all for these helpful suggestions.
It is clearly the correct use of semantics that opens the door; I hadn't thought at all of tri-lobe or tri-wing.
Ian S C21/12/2015 12:26:23
7468 forum posts
230 photos
I needed one for a job a while back, so I attacked a spare screw driver, first wit the off hand grinder, then the Dremel, I suppose it took about ten minutes.
Ian S C
Brian G21/12/2015 12:52:23
837 forum posts
37 photos
Small sizes are sold on eBay as "Nintendo Screwdrivers" due to their use when repairing the games.
Vic21/12/2015 13:40:39
3060 forum posts
8 photos
Lidl had security bit sets on sale a few weeks back which included the tri wing. Worth keeping a look out for them as they'll come round again I'm sure.
davidsuffolk21/12/2015 15:10:33
48 forum posts
8 photos
This set is available from eBay at £4.29 posted so hardly worth trying to make /alter something else. I have similar and very often comes in useful, especially the TORX drivers
Les Jones 121/12/2015 15:40:58
2255 forum posts
156 photos
Hi Brian,
Toolstation also stock these.
Screwfix also stock a few different sets. I did a search for "security bit set"
Les.
Brian Wood21/12/2015 15:53:52
2549 forum posts
39 photos
Thank you all again, a most surprising degree of response. As David Suffolk observed it might not be worth the bother of making something except for the wee problem that this wretched screw is recessed deep in the hole; a point Keith Long so astutely made.
Once the horrible thing is out it will be replaced with a standard self tap. So I rather fear I shall be forced to make a suitable tool to extract it after all.
But it has been an interesting little diversion even so.
Regards all round and have a good Christmas
JasonB21/12/2015 16:32:02
22574 forum posts
2634 photos
Brian, you can get longer sets, mine are 100mm long
mark costello 121/12/2015 18:30:12
711 forum posts
12 photos
Do Youall across the pond have Harbor Freight?
Brian Wood21/12/2015 19:09:12
2549 forum posts
39 photos
Mark,
I don't know, maybe others do
Brian Wood21/12/2015 19:45:53
2549 forum posts
39 photos
Thank you Jason, useful to remember.
John Rudd21/12/2015 21:40:13
1452 forum posts
10 photos
Posted by mark costello 1 on 21/12/2015 18:30:12:
Not here in the UK, but I have visited a number of their stores in the States and had some great items from them.....
Back to the op's question, Maplin provided me with my tool set.....
AJS21/12/2015 23:16:04
37 forum posts
Brian,
I have made one which is perfectly satisfactory for the odd screw which needs to be shifted.
Nothing more than a piece of silver steel filed with a triangular taper at the end to fit the recess in the screw. If it is the sort with a security pin in the centre then drill a small clearance hole in the end.
Harden and temper if you need to use it several times.
Alan
Brian Wood22/12/2015 09:43:13
2549 forum posts
39 photos
Alan Rudd and AJS,
Once again, thank you for your suggestions, item now made and the screw removed. I will save the tool though, it might be needed again
Rapid RC
Dreweatts
