A New Use fior Digital Verniers??
Dave Powell 208/12/2015 17:17:48
33 forum posts
11 photos
Has anybody taken apart one of the cheap digital verniers to convert it as a dro for a lathe or milling machine? I kind of strikes me that it would be quite a cool thing to do. I will be purchasing one at some point to see if it is possible but just wondering if somebody else has beaten me to it.
Howi08/12/2015 17:24:18
330 forum posts
19 photos
Not much point really, as the igaging scales are cheap enough and designed for the job.
But, of course , if you want to have a go...............teeth 2
I have adapted a cheap digital caliper from maplins, to give a readout from my lathe tailstock, just a case of chopping bits off rather than adapting electronically though.
Edited By Howi on 08/12/2015 17:27:21
Brian Wood08/12/2015 17:26:47
2497 forum posts
39 photos
Hello Dave,
Sadly not a new idea, many others have thought the same. I have one on the tailstock ram on my Myford, there is a proper DRO system on the lathe itself.
Machine DRO sell stripped down versions without the calipers for just such applications.
Les Jones 108/12/2015 18:39:16
2241 forum posts
153 photos
I've used them for the Y axis and the quill on my X3 milling machine and the cross slide on my lathe. I did also have a cut down 4" digital caliper on the compound slide but I removed it as it sometimes got in the way.
Les
mechman4808/12/2015 18:56:58
2938 forum posts
466 photos
I use a digital tyre gauge on my tailstock, cost me about £6 on the usual auction site, fitted magnets on the back, have taken the back stop of the slide & can get up to 37 mm readout also used it on the saddle when machining a specified shoulder length.
George
Dave Powell 208/12/2015 19:18:14
33 forum posts
11 photos
Thanks for all the replies, gentlemen. I am definitely going to have a play with one but will also have a look at what is commercially available.
John Stevenson08/12/2015 20:28:12
5068 forum posts
Take a look at this.
walker midge
JD Metals
rapid Direct
