jig boring machine
Tractor man21/11/2015 16:52:32
426 forum posts
Hi all. I have the option to buy a jig borer made by G.E.Hibbert of Leicester with the name shaftesbury cast into the column. I believe it will handle light milling work too. It has a 30 int taper and variable speed. Anyone have any information on said machine or knowledge of Hibbert products. There is nothing on lathes site so I'm a bit in the dark. T
Chris Evans 621/11/2015 19:54:57
1725 forum posts
Not one I have come across. A 30 int taper to ER collet chuck would make sense. Plenty of 30 int stuff around.
Tractor man22/11/2015 09:11:01
426 forum posts
Hi Chris, thanks for the comment. I hoped it would replace my raglan vertical mill which is morse 2 spindle bore. It looks a very robust machine and I'm surprised I can't find any trace of Hibbert or the shaftesbury name. I have decided to buy it regardless and see how things go. The variable speed mechanism is very similar to the raglan moving pulley set up. Smooth and quick to change speeds. I am looking at rota grip for 30 int taper mandrels and there are plenty about as you say. Regards T
Chris Evans 622/11/2015 10:11:29
1725 forum posts
Hi, T I hope the purchase goes well for you. Not knowing the machine one concern may be high enough spindle speeds for small milling cutters, maybe overcome with a digital inverter to speed things up. Possible cheaper options than Rota grip around, try WMT or is it WNT ? I have a friend retiring soon who may have some 30int stuff to dispose of.
Tractor man29/11/2015 20:43:06
426 forum posts
Well I bought it had it delivered and stripped it for cleaning. It's in good nick and the spindle bearings are sound. The variable speed works flawlessly and gives 445 to 2400 rpm .
I have cleaned all the head and rotary elements and the table is next on the agenda. Need some 30 int tooling now. Thinking about an ER 32 collet chuck, boring head and a morse 1 socket for all my taper shank drills. Any thoughts.
Vic29/11/2015 21:31:36
2570 forum posts
18 photos
ER32 collet chucks are very handy and the collets can be used in other chucks/fixtures. I have chucks for both my Lathe and Mill and collet blocks etc.
Let's see some pictures of your machine when you get a minute!
Emgee29/11/2015 21:45:58
1652 forum posts
224 photos
Hi Tractor Man
I have spare and for sale a good quality 1/2" keyless chuck mounted on an Int30 taper, PM me if your'e interested.
Emgee
Nick_G29/11/2015 22:20:59
1808 forum posts
744 photos
I have a int 30 Clarkson collet chuck going spare that I would not want a lot of coins for.
Nick
John McNamara30/11/2015 07:48:26
1313 forum posts
113 photos
Hi TM
Sounds like you have an interesting machine? I could not find a reference to it on the Lathes.co site.
Can you post a picture or two?
Rik Shaw30/11/2015 09:25:03
1354 forum posts
369 photos
Only machine I can find with "SHAFTSBURY" cast in is this one:
daveb30/11/2015 13:13:18
623 forum posts
10 photos
There is a strong resemblance to the Downham/Elliot Jig borers
Vic30/11/2015 14:08:22
2570 forum posts
18 photos
Posted by daveb on 30/11/2015 13:13:18:
Yes, apart from the colour it does look pretty similar.
Emgee30/11/2015 22:14:27
1652 forum posts
224 photos
Hi Tractor Man
Check your Inbox for a message I sent ref the Chuck, pictures below and in my Album.
Emgee.
EngineDIY
