08 Shunter in 2 1/2" Gauge
Simeon Jackson05/10/2015 16:56:34
4 forum posts
I am in the process of designing and building a Class 08 shunter in 2 1/2" gauge and plan to drive this via an electric motor and chain drive to the main axle, however I am having trouble finding suitable chains and sprocket gears as I'm not entirely sure what I need to be looking for. Does anyone have any advice as to where to buy this sort of thing or is it easier to try to make one from scratch?
JasonB05/10/2015 17:18:14
18098 forum posts
1993 photos
You could have a look at HPC or Madler (they sell via Amazon).
Some of the sites dealing with Robotiocs are also worth a look
Edited By JasonB on 05/10/2015 17:18:58
Bazyle05/10/2015 17:28:13
5214 forum posts
201 photos
You might find small toothed belt systems used in printers and scanners suitable. What about Meccano chain drive. It was originally used in player pianos so capable of long tem operation. Is it too late to move to individual axle motors and fears like some of the 5in locos?
John Baguley05/10/2015 18:58:39
458 forum posts
49 photos
HI Simeon,
Following Jason's suggestion have a look at Technobots website. They sell small chain and sprockets. They also have a sister company with a greater range.
http://www.technobotsonline.com/sprockets-and-chain.html
IanT05/10/2015 22:22:31
1532 forum posts
144 photos
Hi Simeon,
I think 6mm chain (and the matching sprockets) will probably suit your needs. As John B states - they can be purchased at Technobots, provided the available sprocket diameters/tooth sizes are suitable for your locos needs.
A year or so ago - I was looking for a source of small (3mm) chain for a 2.5" loco project but I couldn't find anything at the right price (at least in that size). In my case, the chain had to be quite small for cosmetic reasons (it was for a Sentinel and they were visible) and I finally used a Delrin chain (from Micromotion). This was just about OK for a small G3 shunting loco but it wouldn't work for a N2.5GA type passenger hauler.
If you can find a suitable small chain (possibly from a motorcycle timing chain?) then you could try to make your own matching sprockets. I believe this is do'able and you will find some good starting pointers for any such work here:
IanT
Simeon Jackson05/10/2015 22:25:41
4 forum posts
Thanks for all the suggestions. I reckon the 6mm chain and sprockets will do the job nicely. Its now just a case of finishing designing things with these in mind.
Ian S C06/10/2015 12:10:07
7468 forum posts
230 photos
It's quite possible to make a sprocket using a drill of suitable size, then a file to dress the tips of the teeth, done a few of them that way.
Ian S C
duncan webster06/10/2015 12:36:59
2587 forum posts
33 photos
HPC do 4mm chain and sprockets at not ridiculous prices. I managed to find a local gear cutter man who made me some sprockets cheaper than I could buy them, but so far back in time that I can't remember his name. I too have made sprockets my drilling holes on apitch circle then filing till the chain ran smoothly. You need something good on the radio as it takes a long time, but is very satisfying when it works.
Edited By duncan webster on 06/10/2015 12:38:25
Ian S C07/10/2015 11:22:16
7468 forum posts
230 photos
I got some small chain from old photo copiers, there's two sizes, probably imperial, about 3/16", and 1/4"(I think).
Ian S C
