Lady Stephanie
starting project
john carruthers23/09/2015 08:06:15
614 forum posts
180 photos
As a winter project I'm starting a Lady Stephanie six column pumping engine from A.J.Reeves.
Anyone done one? anything to watch out for?
I haven't seen the drawings yet but what other materials will I require?
Is it worth making governor gears or using stock items? (I have used a pair from an old hand drill before).
David Clark 123/09/2015 10:25:44
3357 forum posts
112 photos
10 articles
I think this has been published as a series. Not sure if it was Model Engineer. Popular science or popular mechanics rings a bell. This would have been the UK version published probably in the 1970s. I remember a beam engine in one of the last two mentioned.
Roderick Jenkins23/09/2015 18:15:39
2176 forum posts
608 photos
Serialised in Engineering in Miniature in 1981.
Rod
Neil Wyatt23/09/2015 21:12:15
18990 forum posts
734 photos
80 articles
I've been half way through one since about 2004.
Some of the ones I've seen simplify the entablature, which is a shame.
My flywheel was badly dished, I've got one laser cut as a replacement.
john carruthers25/09/2015 13:13:17
614 forum posts
180 photos
Sorry for the tardy reply, had a login problem.
Thanks for your comments. The castings arrived within 24 hours of order.
I've been giving the drawings 'a good coat of looking at' and started on the entablature.
I shall go through the drawings rationalising the mixture of dimensions, mm, inch fractions and decimal inch fractions :-/
TBC.....
Neil Wyatt25/09/2015 14:13:35
18990 forum posts
734 photos
80 articles
Read Tubal Cain's book on engineering drawing and see how many of his own rules he broke with Lady Steph!
Bob Unitt 125/09/2015 18:50:14
202 forum posts
33 photos
I started one of these in (I think) 1992. One of these days I'll get round to finishing it...
See http://www.bobunitt.me.uk/steph/steph.htm
Edited By JasonB on 25/09/2015 19:56:43
john carruthers27/09/2015 10:17:15
614 forum posts
180 photos
Thanks Bob, I saw your video when I was researching the project.
Progress so far; filed up and drilled the entablature and beam. I would like to centre the beam bosses on the holes. I can't swing it so I'll make a little annular cutter.
The flywheel had some horrible hard chills, sparks flying off in places. Still got to clean up the spokes, might get a carbide burr as even my best files won't touch them.
Edited By john carruthers on 27/09/2015 10:18:29
Roderick Jenkins27/09/2015 13:38:47
2176 forum posts
608 photos
Posted by Neil Wyatt on 25/09/2015 14:13:35:
or maybe the EIM illustrator converting them into the house style? Apparantly it can happen in even the best regulated magazines wink
Rod
Neil Wyatt27/09/2015 13:52:14
18990 forum posts
734 photos
80 articles
The sheets are his own drawings, they match his style. I haven't found errors, just matters of style (and lack of projection symbols).
Bob Unitt 127/09/2015 16:49:22
202 forum posts
33 photos
You may find this of use, john - it's an index I made to all the Lady Stephanie construction articles.
john carruthers28/09/2015 07:36:13
614 forum posts
180 photos
Thank you Bob, yes I will look them up. It seems as good an order of operations as any as well.
I'm still gathering materials. I'd like to do as much as I can in brass.
john carruthers01/10/2015 08:31:54
614 forum posts
180 photos
I've acquired a diamond file and tidied up the flywheel, just needs reaming now and a keyway cut.
Has anyone ever worked out what one of these costs in materials, tooling and time? must run into thousands?
Neil Wyatt01/10/2015 10:34:57
18990 forum posts
734 photos
80 articles
Materials aren't a huge cost, it's a pretty small engine really.
Time is the biggest investment, a lot of fiddly bits.
Ian S C02/10/2015 11:29:38
7468 forum posts
230 photos
Time and tooling are the big money, I don't know the charge out rates are in a UK engineering shop, but 50 pounds an hour might not be too much, no wonder every one (well a number) on here want things to go faster.
Ian S C
john carruthers03/10/2015 15:35:50
614 forum posts
180 photos
Crank done (loctite and 1.5mm pins) and the flywheel.crank and flywheel
john carruthers10/10/2015 16:22:20
614 forum posts
180 photos
crank bearingsbeam fittedGood progress today, made the beam pins and bearings, finished the crank bearings, machined the steam chest except the 4 flange holes - have to make a drill jig for them so all fit the same.
steam chest
john carruthers11/10/2015 14:35:22
614 forum posts
180 photos
cyl st chest.jpgGetting there, one piece at a time; cylinder bored a thou under size to allow for honing, and the steam passages drilled.
john carruthers26/10/2015 14:28:39
614 forum posts
180 photos
Steady progress....
Neil Wyatt26/10/2015 18:23:31
18990 forum posts
734 photos
80 articles
Cripes, you're past me already... and I've only be going at it for about 10 or 12 years...
Dreweatts
Rapid RC
