Martin Kyte | 05/08/2015 09:21:47 |
![]() 2755 forum posts 48 photos | Hi Chaps I'm after the standard wheel profile for Derwent in 2 1/2" gauge if anyone has the info or a link to it. Thanks in anticipation. regards Martin |
Neil Wyatt | 05/08/2015 10:51:11 |
![]() Moderator 19037 forum posts 734 photos 80 articles | Wheel standards are gauge specific rather than design-specific, if there isn't one on the plan, you should be able to use the profile from any broadly similar design in the same gauge. Neil |
Martin Kyte | 05/08/2015 11:06:37 |
![]() 2755 forum posts 48 photos | Yes. I perhaps wasn't too clear in my question. My friend is building Derwent and he needs the standard profile for 2 1/2" gauge. I thought maybe someone had a link to the data handy. regards Martin |
Martin Kyte | 05/08/2015 11:50:47 |
![]() 2755 forum posts 48 photos | OK, to answer my own question for the benifit of others the data is here:-
Martin |
HomeUse | 05/08/2015 11:51:12 |
![]() 168 forum posts 12 photos | This might be a good link to start with
http://ibls.org/mediawiki/index.php/IBLS_Wheel_Standard |
RRMBK | 05/08/2015 11:51:54 |
154 forum posts 18 photos | Try national 2.5 Gauge association **LINK** |
HomeUse | 05/08/2015 11:52:35 |
![]() 168 forum posts 12 photos | You piped me at the post |
Martin Kyte | 05/08/2015 12:00:07 |
![]() 2755 forum posts 48 photos | Thanks for the responses anyhow. Martin |
IanT | 05/08/2015 13:59:27 |
1993 forum posts 212 photos | Sorry to disagree with some of the other posters Martin - but I think there is a better solution for your friends 'Derwent'. As you will (probably) know, 'Dewent' is a small Gauge '3' locomotive designed (by G3 member Dick Allan) for garden railway (e.g. scenic) operation. I've seen Dicks' version of this engine run a few times at G3 GTGs (under radio control) and very nice it is too. So it would make much more sense (at least to me) if you used the Gauge '3' Society's wheel standards. You can either download them (as a PDF) from the G3 Society's website - or if you prefer, just PM me and I will email them to you.. Your friends engine will still run on 2.5" MES tracks (should he wish it to do so - although it's clearly not a passenger hauler) but the engine will also be able to freely navigate the turnouts and other track features at any Gauge '3' Garden Railway - if he ever decided to give one of our GTGs a visit. We are always happy to see Guests (and their engines & stock) at our GTGs but as they are held in Members Gardens, we do ask for people to contact us (for an invite) beforehand - rather than just turning up. You might also tell him that the Tea and Cakes at our GTG are also usually very good too! Regards,
IanT (G3 Member) Edited By IanT on 05/08/2015 14:06:58 |
Neil Wyatt | 05/08/2015 14:03:29 |
![]() Moderator 19037 forum posts 734 photos 80 articles | Lots of interesting stuff there, not least a picture of LBSC in his later days, a rare thing indeed. Neil |
IanT | 05/08/2015 14:15:48 |
1993 forum posts 212 photos | Neil - He looks a bit like my Uncle Harry (who is also long deceased I'm afraid) Martin - I've just checked & it seems that the G3 Society website has changed a wee bit since I last paid it close attention - in that I couldn't find a PDF on first glance... However, here's a link to the G3 wheel standards If you want a PDF version of this - I have one. Regards, IanT |
IanT | 05/08/2015 14:22:18 |
1993 forum posts 212 photos | Sorry Martin - I've just noticed that the PDF link is still there (at the bottom of the 'standards' page given). And for anyone else interested - here is Dicks 'Derwent' on display at a Gauge '3' Society GTG last year. You can see some of the very early carriage stock he built to run it with, in the background. Regards, IanT Edited By IanT on 05/08/2015 14:26:34 |
John Baguley | 05/08/2015 14:54:57 |
![]() 507 forum posts 56 photos | Just to add to Ian's post here's the wheel standards used by the N25GA: As we run mostly on passenger hauling raised tracks our standard is a bit coarser than that required by the G3 Society as we don't need to run through points etc. The width of the wheel tread is wider than the G3 standard, which can be useful when running on some raised tracks which are a bit over gauge in places! Some people with G3 standard wheels do seem to have problems running on some raised tracks as the wheels sometimes tend to fall between the rails due to the narrower treads. John |
IanT | 05/08/2015 15:59:32 |
1993 forum posts 212 photos | Agreed John The narrower tread is pretty much for cosmetic reasons (it does looks more prototypical - if they are too wide - you can get a "road roller" look) but I can't think (off hand) of any reason why a slightly wider tread would cause any problems on a G3 garden railway. However, I've seen many engines that meet G3 wheel standards run quite happily on MES tracks (most recently at Cheltenham of course). The flange width and depth are both important in G3 - not only for getting through turnouts (flange width) but also to ensure that the top of the flange doesn't hit the top of the track chairs (flange depth) - which is another thing that the typical MES track doesn't tend to have. One of my 2.5" engines (previously only used on MES tracks I assume) which is otherwise very nicely built, had flange widths that varied around 1/8" on different axles. It needed a lot of attention before it could be used on our garden tracks. I'm sure the original builder thought his flanges were "robust" but it was a real pain to sort out. I've also seen another (LBSC designed) engine 'bounce' along the top of the chairs because of too deep flanges. 'Derwent' is designed for garden use and I'd build her accordingly. I'm certain Dicks version of this engine was built to meet the G3 track standards - so this would also be as-per the original design. Regards,
IanT |
Neil Wyatt | 05/08/2015 16:44:10 |
![]() Moderator 19037 forum posts 734 photos 80 articles | Two societies divide by a common gauge, to misquote Shaw Neil |
John Baguley | 05/08/2015 18:01:17 |
![]() 507 forum posts 56 photos | I hope we are not divided, just catering for the different aspects of 2½" gauge John |
IanT | 05/08/2015 18:23:08 |
1993 forum posts 212 photos | Not really Neil. We actually share quite a lot of common members between the two groups. Whilst some people do have very specific preferences in terms of their modelling, others are much more "broad church" and get involved in all aspects of 2.5" gauge. I am a long term member of both the Society and the Association, although my personal preference is to model in Gauge 3. However, I do attend local 2.5" Association Rallies when I get the chance, mainly to show support for both the Association & the gauge. At first look, I guess other folk will just see the difference as being between 'passenger hauling' versus 'scenic running' but I think the real differences run much deeper than that and can sometimes be quite subtle. For instance (as you may have gathered from my other posts) - for me, it's all about the Cakes! The Association MES Rallies I've visited have always been very good with their catering arrangements but I must say that the Gauge '3' Ladies are in a different league altogether when it comes to the quality (and quantity) of the Cakes served at Society GTGs. Of course, other modellers may have different priorities to mine. Regards,
IanT |
Neil Wyatt | 06/08/2015 11:36:52 |
![]() Moderator 19037 forum posts 734 photos 80 articles | That was humour - I'm sure the 'entente cordial' between the two societies is as good as that between the US and UK... Neil |
IanT | 06/08/2015 13:33:49 |
1993 forum posts 212 photos | I'm sure we realised that Neil - but perhaps a better analogy would be the Twix twins in the TV chocolate advert? And I did notice that JB quietly slipped the word "catering" into his post (even if subconsciously), so obviously a man who also values his cake and sandwiches. Maybe we could have a new joint slogan? Two & Half Inch - The Gauge where you can have your Cake and Eat It OK, sorry - I'll stop now. IanT
PS I hope a that at least some of this has been useful to your friend Martin |
