JasonB | 20/07/2015 17:45:56 |
![]() Moderator 19512 forum posts 2131 photos 1 articles | Testing |
Brian Wood | 20/07/2015 18:23:00 |
2316 forum posts 37 photos | Are you looking for a response Jason? Brian |
jason udall | 20/07/2015 18:28:08 |
2029 forum posts 41 photos | One two one two. Mary had a little lamb. The midwife had a fit. |
JasonB | 20/07/2015 18:28:09 |
![]() Moderator 19512 forum posts 2131 photos 1 articles | Thanks Brian but No, I was posting in response to this thread |
Turbine Guy | 08/10/2020 19:10:13 |
275 forum posts 156 photos | I am trying to test if the following link works. |
JasonB | 08/10/2020 19:29:29 |
![]() Moderator 19512 forum posts 2131 photos 1 articles | Takes me to the model turbines thread which I assume is what you wanted. |
Turbine Guy | 08/10/2020 19:40:08 |
275 forum posts 156 photos | Posted by JasonB on 08/10/2020 19:29:29:
Takes me to the model turbines thread which I assume is what you wanted. Yes. When I first tried to test making a link, I did it on a draft of a post and it did not work. Thor suggested that I use the Testing thread to see if it worked after making a post. I used my Model Turbines thread for the test. |
Michael Gilligan | 08/10/2020 20:17:28 |
![]() 16993 forum posts 754 photos | Posted by Turbine Guy on 08/10/2020 19:40:08:
. I guess Thor probably meant this one: **LINK** https://www.model-engineer.co.uk/forums/postings.asp?th=99158 MichaelG. |
Turbine Guy | 08/10/2020 21:17:35 |
275 forum posts 156 photos | Posted by Michael Gilligan on 08/10/2020 20:17:28:
. I guess Thor probably meant this one: **LINK** https://www.model-engineer.co.uk/forums/postings.asp?th=99158 MichaelG. Thor tries hard to keep me going the right direction, but I always find a way to screw up. Byron
Thor | 09/10/2020 05:14:31 |
1321 forum posts 40 photos | Posted by Michael Gilligan on 08/10/2020 20:17:28:
I supplied him with both, the one he used happened to be the first on my list, I guess either should do the job? Thor |
Michael Gilligan | 09/10/2020 06:50:57 |
![]() 16993 forum posts 754 photos | Posted by Thor on 09/10/2020 05:14:31:
I supplied him with both, the one he used happened to be the first on my list, I guess either should do the job? Thor .
MichaelG. [ Happily reverting to dis-interested observer mode ]
Michael Gilligan | 09/10/2020 08:53:53 |
![]() 16993 forum posts 754 photos | Posted by Michael Gilligan on 09/10/2020 06:50:57:
. Oops ... my mistake : This new thread is Jason’s It gets weird around here sometimes MichaelG. Edited By Michael Gilligan on 09/10/2020 08:54:51 |
JasonB | 09/10/2020 10:11:59 |
![]() Moderator 19512 forum posts 2131 photos 1 articles | New is a relative thing when you look at the date of my opening post |
Michael Gilligan | 09/10/2020 11:46:20 |
![]() 16993 forum posts 754 photos | Posted by JasonB on 09/10/2020 10:11:59:
New is a relative thing when you look at the date of my opening post . You win, as always MichaelG. |
