Forum sponsored by Allendale Until July 27th
external frame rod drive diesel
attaching counterweights
Perko721/06/2015 13:22:48
260 forum posts
23 photos
Newbie to both this hobby and this forum. Needing advice on preferred way of attaching counterweights to axles on a 5inch gauge rod-drive diesel with external frame. Thinking of press fit with keyway, but other options would be considered.
Bazyle21/06/2015 22:26:27
4582 forum posts
185 photos
Press fit might be a bit tricky for a beginner to get firm. Keyways too are tricky. Consider Loctite with a pin for peace of mind. Loctite can be used with as good a fit as you can manage easily (for alignment) but does not need to be so precise as a press fit, and does not actually need a gap (and hence slop) as mentioned in some of the older instructions. You can put in a tiny anular groove a thou or so deep if it helps to have a sort of reservoir for the loctite so you feel there is some there. If you screw up the quartering it can be got apart with heat.
Steve Addy24/02/2016 16:51:43
88 forum posts
41 photos
I did Loctite and keyways on my loco. That was to get the quartering engineered into the axles and cranks.
TRANSWAVE Converters
