'C' spanners
John Walker 722/05/2015 17:52:10
3 forum posts
Hi,
I am currently building the 2" Shand Mason to Edgar Wesbury's design. I am making gland nuts of the round type with 6 grooves around the circumference. These are 1/2 " and 3/8" dia. Obviously they need a 'C' spanner or Hook spanner to tighten them. Does anyone know of an easy way to make such spanners.
Thanks in anticipation John
Michael Cox 122/05/2015 18:42:37
539 forum posts
27 photos
Have a look at this:
http://www.toolsandmods.com/lathe/mini-lathe-spindle-nuts-wrench
This could be easily scaled down to suit your application.
John Walker 722/05/2015 18:52:11
3 forum posts
Thanks for the quick response Mike, that'll do the trick......John
JasonB22/05/2015 19:58:30
20474 forum posts
2269 photos
Micrometer adjusting spanners work very well for me or when the glands are hard to get at a small flat blades screwdriver can be useful.
If you want to make something that cut a narrow strip off some 20g or 1mm steel sheet. Hacksaw a slot across the end of some 3/8" rod. put one end of the strip into the slot and wrap it 1/3rd way around the rod then bend back at a suitable angle to make the head. Repeat with a 1/2" rod. The glands don't need a lot of force so mild steel will do but you could use annealed spring steel if you wanted.
J
Edited By JasonB on 22/05/2015 20:03:02
Enough!22/05/2015 23:00:12
1719 forum posts
Or fully unscrew the spindle and use the micrometer itself devil
John Walker 723/05/2015 09:13:10
3 forum posts
That sounds like something Chuck would do
Neil Wyatt23/05/2015 12:14:41
18585 forum posts
723 photos
78 articles
Cut out the body of the spanner and fit metal pegs that are just a TINY bit smaller than the body, silver soldered in place. The round bits were cut out with a step drill and then filed to shape by eye.
Neil Wyatt23/05/2015 12:17:41
18585 forum posts
723 photos
78 articles
I'm boggled! A mini-lathe with the plastic bearing cover and gear spacer replaced by polished metal items!
Michael Cox 123/05/2015 15:49:34
539 forum posts
27 photos
The owner of the toolandmods website is Jose Menezes. He is a Portuguese, a perfectionist and a professional photographer. His site was very active until about 3 years ago. Since then nothing seems to have been added.
Jose also hosts all the drawings prepared by Ralph Patterson of the modification he made to his minilathe. This is a useful resource.
JD Metals
