triple start tap die
capnahab21/04/2015 20:05:29
182 forum posts
64 photos
Does anyone know where to purchase specialist taps ?.
I need a triple metric 12mm x 0.75 , - its for a pen top. The specialist pen turner suppliers in the US but can't find anyone in the UK.
Edited By capnahab on 21/04/2015 20:23:22
Roderick Jenkins21/04/2015 20:20:16
2138 forum posts
586 photos
Sorry, just noticed the triple start!
Rod
Edited By Roderick Jenkins on 21/04/2015 20:22:27
JasonB21/04/2015 20:22:19
22017 forum posts
2540 photos
Rod, its a triple start one that he is after, not even Tracy's have them
Roderick Jenkins21/04/2015 20:24:01
2138 forum posts
586 photos
8 seconds too slow in editingblush
capnahab21/04/2015 20:25:04
182 forum posts
64 photos
sorry , my fault , should have put it in body, have done so now. Some of the penturners forms have had group buys for a specialist order but not at the mo.
Bob Brown 121/04/2015 20:30:05
1021 forum posts
127 photos
This lot make "specials" **LINK** may be worth a telephone call.
Bob
Oompa Lumpa21/04/2015 20:49:34
888 forum posts
36 photos
Posted by Bob Brown 1 on 21/04/2015 20:30:05:
Bob
A really nice, genuine chap. But kept me on the 'phone for twenty minutes chatting and sometimes this can be frustrating. I emailed him last week but I don't think he "does" email very well.
I need an 6x48 tap and this is an arse of a thread. I can get them in the US but one tap works out at twenty quid by the time it gets here So I will just take a chance he is busy too tomorrow
graham.
Ian P21/04/2015 22:00:56
2552 forum posts
113 photos
Posted by Oompa Lumpa on 21/04/2015 20:49:34:
graham.
Can I be the first to ask, what is a 6x48 tap?
Ian
duncan webster21/04/2015 22:12:04
3710 forum posts
69 photos
why not screw cut it?
capnahab21/04/2015 22:22:02
182 forum posts
64 photos
Because I am not good enough at cutting an internal triple start m12 x 0.75 thread in a blind hole ( without wrecking the work piece) in which I have invested some time.
Oompa Lumpa21/04/2015 23:46:43
888 forum posts
36 photos
Posted by Ian Phillips on 21/04/2015 22:00:56:
graham.
Ian
Ah, yes. I was confused with this too the first time I saw it. The 6 refers to wire gauge and of course it is 48 TPI.
Or so it was explained to me.
graham.
I.M. OUTAHERE22/04/2015 04:21:37
1468 forum posts
Depending on what material you are cutting i wonder if you could make your own from silver steel ?
Then use that home made tap to make a die for the male thread ?
Just a thought.
Clive Hartland22/04/2015 07:16:24
2759 forum posts
40 photos
I use these type of 3 start taps on eyepiece threads and they are mostly an adjustable type of tap with a screw down the center to allow easy entry into existing threads. They are quite delicate to adjust and are very expensive from our Leica tooling section in Switzerland. I have cut one but as a solid and not adjustable and it worked fine.
JasonB22/04/2015 07:38:44
22017 forum posts
2540 photos
graham.
Ian
As said in the US for threads below 1/4" dia they use a number system similar but not the same as our swg as the numbers go in the opposite direction eg a low number is larger dia eg 10=0.190" , 6= 0.138" , 0= 0.060".
Typically used for UNC, UNF and UNEF and UNS thread forms.
The way to write it to save confusion is 6-48 or #6-48
J
Edited By JasonB on 22/04/2015 07:40:33
Michael Gilligan22/04/2015 07:59:11
19601 forum posts
997 photos
Posted by JasonB on 22/04/2015 07:38:44:
Useful tabulation, here
JasonB22/04/2015 08:07:45
22017 forum posts
2540 photos
Or the more colourful one I tend to use or should that be colorful?
HERE
Frank.N Storm22/04/2015 09:03:06
48 forum posts
So Mr. Capnahab wants to cut a internal 12 mm thread and for this needs a #6 tap of 0.138" ? (= 3.43 mm!).
Somehow these numbers don't come out even...
Regards, Frank
JasonB22/04/2015 09:11:48
22017 forum posts
2540 photos
No Capnahab wants a tripe start M12x0.75 which can be bought from the US, Graham uses 6-48 which also come from the US and thats the common link.
JD Metals
MIDLNDS GARDEN RAIL Jan 2022
rapid Direct
