Lubrication - new lathe & milling machine
Andrew Dunn 211/03/2015 14:48:50
2 forum posts
As a newbie, I just acquired a new Warco GH1236 lathe and a Chester Super Deluxe milling machine. Can anyone give me advice on what lubricants I should be using?
In the manual for the lathe, they suggest a "heavy non-slinging grease" for the gears and machine oil for the headstock and other parts.
I would be interested in suggestions of the best lubricants to use and also for cutting oil.
Thanks, Andrew
Oompa Lumpa11/03/2015 16:41:38
888 forum posts
36 photos
Well, good choice with the Mill, I have just agreed to purchase that exact same model, the big attraction for me was the size of the table.
Anyhow, I use Vactra 2 on the slideways, 30 weight motor oil on the gears and as for cutting oil I bought ten litres of rotabroach cutting oil at an unbelievable price so I use that. If you want to use grease Moly grease is good but it IS dirty and I prefer to use Lithium grease. There was an online Bike shop selling this at a terrific price but I cannot remember where this was.
graham.
Michael Gilligan11/03/2015 16:48:35
15879 forum posts
693 photos
Posted by Oompa Lumpa on 11/03/2015 16:41:38:
... I prefer to use Lithium grease. There was an online Bike shop selling this at a terrific price but I cannot remember where this was.
ChainReaction
Bob Brown 111/03/2015 17:00:16
1010 forum posts
127 photos
I use a bike chain spray on the gears as it is easy to apply.
Bob
mechman4811/03/2015 18:29:13
2689 forum posts
421 photos
Motor bike chain spray for the gears, WD40 for aluminium, either dry or suds or neat cutting oil for MS, dry for brass,
motor gearbox oil in the lathe g/box, ...should cover most of your needs
George
Oompa Lumpa11/03/2015 19:57:00
888 forum posts
36 photos
Posted by Michael Gilligan on 11/03/2015 16:48:35:
ChainReaction
Thank you for that Michael, it was your good self who pointed this out to me in the first instance.
Bought a couple of tubs and time to buy a couple more.
graham.
ChrisH11/03/2015 20:04:37
862 forum posts
29 photos
Just a thought - as an alternative to motor bike chain spray, is chainsaw oil any good for gears? Might try it on my gears anyway.
Only, I have a chain saw and it's oil, but don't have a motor bike so no spray!
Chris
Bob Brown 111/03/2015 20:10:49
1010 forum posts
127 photos
Chain oil is available from Toolstation £4.54 a can
JA11/03/2015 20:16:34
936 forum posts
51 photos
I use chain saw oil on the rear chains of my bikes (350cc to 700cc). It works very well. Like bike chain oil it is designed to penetrate into the chain and throw off the dirt.
JA
Andrew Dunn 212/03/2015 10:05:20
2 forum posts
Thanks for all your comments. Vactra 2 seems to be a good way to go for the slideway. Mostly it seems to be sold in 20l cans, but I found it available in smaller quantities at RHR Tools, so I ordered it there.
For the headstock and gearbox, Warco sell their own lubricant at a reasonable price. I was thinking of ordering this. What do you think? Link: http://www.warco.co.uk/14-lubricants-neatcut-cutting-oil
I like the idea of a spray for the gears, as suggested by Bob and George, as its easy to apply. Any suggestions of a particular product and where I can get it?
Thanks,
ChrisH12/03/2015 10:44:22
862 forum posts
29 photos
Andrew, I use Warco's Headstock Lub in my (not Warco) old Weiler lathe for the past 4-5 years. It seems quite OK, have had no problems.
Chris
mechman4812/03/2015 12:48:54
2689 forum posts
421 photos
I bought...
Muc-off, hi performance dry PTFE bike chain lube.. Halfords.. (usual disclaimer..  )
George
Edited By mechman48 on 12/03/2015 12:49:41
andrew winks15/03/2015 11:34:50
117 forum posts
I use hydraulic oil or power steering fluid for lubricating slides, acme threads and the like. Read somewhere that engine oils should not be used due to the detergent or cleaning additives. Old wives tale or truth, perhaps some lubrication engineers can comment.
cheers
EngineDIY
