Simple Mill Engine - Stewart Hart ME.4460 - Part CP11
Bruce Edney24/01/2015 04:39:02
161 forum posts
53 photos
Hi
I have just started making this little engine and can not find anything about this part mentioned except in Fig 3
I take it that this is just a cap and is glued in place using Loctite.
Would it also benefit from a small hole to avoid compression issues at the top of the valve piston?
Thanks for an awesome project
Bruce Edney
Stewart Hart24/01/2015 08:00:50
655 forum posts
354 photos
Hi Bruce
Yes its just a simple cap a tight fit and fixed with supper glue, in fact the engine will work perfectly without it, its just their to tidy things up.
It doesn't need a vent hole the exhaust port does that job.
Thanks for you interest in the engine, there have been quite a lot made, the design is very robust to the odd mistake and is ideal for a beginner.
Cheers
Stew
Edited By Stewart Hart on 24/01/2015 08:04:14
Bruce Edney24/01/2015 18:24:12
161 forum posts
53 photos
Thanks Stew
Bruce Edney16/03/2015 07:29:26
161 forum posts
53 photos
Hi Stew
I have another question. I know the dimensions are not critical but just trying to get it looking right.
In the photos and the drawing of the base it shows a significant amount of material at the crankshaft end however the measurements don't stack up.
Should the overall base length actually be about 250-260mm?
Cheers
Bruce
PS. I have had the engine running and after fixing a few engineering issues (engineer not design) it runs like a dream.
Edited By Bruce Edney on 16/03/2015 07:29:56
JasonB16/03/2015 07:50:33
19587 forum posts
2150 photos
The 4 mounting holes should be 225mm ctrs and the overall length 240mm
Check your messages
Edited By JasonB on 16/03/2015 08:04:11
Stewart Hart16/03/2015 08:08:04
655 forum posts
354 photos
Hi Bruce
Pleased to her you've got the engine running.
I've measured up the base of my engine, as you have guessed I didn't follow my own drawings embarrassed, I actually shaped the end of the base to make it look more like a casting, the actual size of my base is 205*50 and the wooden brick work is 215*55, with the mounting holes 198*39
You can see this in these photos.
Sorry if I've confused the issue, but I sometimes don't actually publish what I have made as I try to and correct/simplify things that I've found out in the process.
Cheers
Stew
Dullnote28/10/2017 17:38:31
73 forum posts
19 photos
Hi hope this is the correct thread for this, couple of photos of my attempt to construct this engine, I have never used a lathe from leaving school and I plan on retiring in two years so you can work out the sums.
This is the start of my further education, the engine is still to be completed and is in rough stages, the threaded bar to be cut to correct length, washers added.
May not be to the same high standard I see on this forum, but I am pleasantly please with me efforts, when I get it completed and running I will then spend time making it look good
Best thing about it is, I have had a great time leaning new skills.
Just thought I would share
Neil Wyatt28/10/2017 18:06:29
18416 forum posts
718 photos
78 articles
Looks good from over here
Stewart Hart30/10/2017 07:21:05
655 forum posts
354 photos
Posted by Neil Wyatt on 28/10/2017 18:06:29:
Looks very good from her
Nice work Jim
Its always great to see one of these engines being made by a beginner, as it was designed as a beginners engine, there must have been quite a lot made by now.
Can't wait to see a picture of the finished engine or even a video of it running
Cheers
Stew
SillyOldDuffer30/10/2017 10:47:33
6699 forum posts
1507 photos
I'm building my second example at the moment. The engine works, is reasonably tolerant of mistakes, and has some interesting challenges without being baffling. I enjoyed making the first one.
This time it's a beginner+ project in that I'm being much more fussy about finish and building to plan. The idea is to compare the two builds to see where I've improved, and - more important - identify which skills still need attention. Judging by the reject rate, I have a long way to go!
I'm experimenting with another approach to construction too. First time, I made the parts one at a time, each starting as a lump of metal and only downing tools when the part was complete. Second time round I'm making several parts in parallel and not necessarily finishing all machining before moving on to another part. The disadvantage of the first method was making mistakes because I got bored, The disadvantage of the second method is I make mistakes because I misremember what needs doing next. It appears I'm better at making mistakes than engines!
roy entwistle30/10/2017 11:00:20
1300 forum posts
Dave The man who didn't make mistakes, didn't make anything. Also experience is built on mountains of scrap
Roy smiley
Dullnote27/01/2018 20:06:04
73 forum posts
19 photos
img_0788.jpgimg_0789.jpgJust thought I would update, slow but getting there
Jim Nic27/01/2018 20:56:46
288 forum posts
164 photos
That's looking very tidy Jim. Do she run yet?
Jim
Dullnote27/01/2018 22:57:14
73 forum posts
19 photos
Not yet still got eccentric to fit. The flywheel does turn the crank around and everything does what it should do but feel unit is tight, think I will need to tweak it a bit to get smooth movement but plan to do that when everything is fitted, hope to get some workshop time tomorrow
Jim
Stewart Hart28/01/2018 07:09:36
655 forum posts
354 photos
Hi Duffer
Sorry I missed your post on 30/10/17 I was on holiday at the time and got behind with following the forum.
Your build is looking good, have you got her running ?.
Stew
Hi Jim
That,s looking good too, best way to shake out the tight spots is to loosen all the screws, then tighten them up one by one any screw that causes it to bind needs investigating and the cause fixing.
Look forward to seeing the completed engines and a video if posible
Cheers
Stew
Hopper28/01/2018 11:50:00
5084 forum posts
114 photos
Posted by Stewart Hart on 16/03/2015 08:08:04:
Stewart, on the brass bands around the wooden lagging strips on the cylinder, are those brass rivets' holes drilled into the metal cylinder, or are they just into the wood?
Also, where's a good place to buy the graphite packing for the piston ring and glands?
SillyOldDuffer28/01/2018 12:38:49
6699 forum posts
1507 photos
Posted by Stewart Hart on 28/01/2018 07:09:36:
Hi Duffer
Stew
Stew
Yes she goes but I left off the inner brass washers whilst pinning the crankshaft and bent it slightly on re-assembly. Although the valve is rather stiff and the crankshaft's bent the engine runs given enough air. Now waiting for me to make another crankshaft and ease the valve where it's binding on the guide. Then beautifying. Your paint and wood work photos have given me something to aspire to. The engine build is temporarily paused while I play with a computer project but it's still top of my metal bashing list.
Stewart Hart28/01/2018 13:02:06
655 forum posts
354 photos
Posted by Hopper on 28/01/2018 11:50:00:
The method I used on the brass banding wasn't one of my better ideas I used two way sticky tape the rivets are just dummy, but the darn stuff starts to peal off and I have to press it back down, for the follow on engine I drilled through the banding into the cylinder and used some small M2 dome headed cap screws to fasten it down, you can get the screws from model fixings http://www.modelfixings.co.uk/
I had terrible trouble the first time I tried to clad a cylinder then someone told the trick of first gluing the batons with copydex to a piece of cotton material then cut to shape and fix the whole lot to the cylinder, the batons are coffee sterers.
You can get the graphite from Macc Models or Blackgates but you could use ptfe thread tape that you get from plumbers merchants just twist it into a string and use a graphite packing works just as well.
Hope this helps
Stew
Stewart Hart28/01/2018 13:04:33
655 forum posts
354 photos
Posted by SillyOldDuffer on 28/01/2018 12:38:49:
Hi Duffer
Stew
Stew
Hi Dave
Pleased you got a runner we all go through a learning curve no mater what we attempt, the important thing is to learn from mistakes and don't give up.
Stew
Hopper28/01/2018 13:08:28
5084 forum posts
114 photos
Posted by Stewart Hart on 28/01/2018 13:02:06:
Thanks. LOL, trust me to ask the awkward question!
I've used the rolled thread tape dodge I don't know how many times on full-sized steam plant years ago, glad to see at least some of my skills transfer across to the smaller scale stuff. At least it was a step forward from my old boilerhouse foreman's dodge of pulling a string off the floor mop and using it to pack a leaky gland with.  laugh
Edited By Hopper on 28/01/2018 13:10:24
EngineDIY
