Stamp laser engraving or cnc cut?
Chris Richards 323/01/2015 22:24:49
68 forum posts
13 photos
Hello,
I hope someone can help me out with this. I basically need a stamp making to leave an impression in leather with some text approx 50mm x 40mm. It's not something I could do on a manual mill or by hand easily as it needs to be neat. I figured someone with a small cnc mill, engraver or laser engraver may be able to help? I guess it's best in mild steel but it doesn't need to be heated and Is just pressed into leather so maybe something softer like brass could be used?
Any ideas or offers to help would be much appreciated.
Thanks,
Chris
Bob Brown 123/01/2015 22:37:25
1016 forum posts
127 photos
Another method may be to etch the design into a block of steel, process **LINK**
Bob
Chris Richards 323/01/2015 23:10:35
68 forum posts
13 photos
Hi Bob,
Certainly a good point, etching maybe a good option. The shopping list maybe the tricky part mmm.
Thanks,
Chris
Tony Ray23/01/2015 23:49:48
138 forum posts
25 photos
Chris,
If it's going to be used repeatedly I would stick with steel, it would be a shame to put the work into something that could wear quickly. Another option would be to have it CNC spark eroded.
Michael Gilligan24/01/2015 00:03:32
16366 forum posts
714 photos
Chris,
This may well be a pricey option, but it's worth a look.
Chris Richards 324/01/2015 00:04:20
68 forum posts
13 photos
Hi Tony, thanks for another alternative.
So far contacting local businesses has drawn a blank a company that said yes we'll fit it in and do it and a month later said they can't. Engineering places are never interested in little one offs if only someone could spare a lunch break or two
Thanks,
Chris
Billy Mills24/01/2015 00:05:37
377 forum posts
Chris,
I would suggest that if this is for commercial use you go to an engraver who is very used to making exactly what you need, you will end up with crisp lettering from someone who is fully versed in the requirements to make stamps.
You might find someone with a cnc mill who can do the job, but engraving cutters are a little different and are usualy run at very high speed to produce smooth sided letters. Many signmakers offer engraving services.
A low power laser will not cut metal but they are in common use to make rubber stamps. Etching is fine for a foil but deeper etches undercut. Lasers will directly mark leather, I have engraved images and lettering into leather for many people, that's the delux option.
Billy
Geoff Moore15/03/2015 21:02:04
1 forum posts
Chris,
I am a machine engraver with a bit of past experience (1965 - today), perhaps I could take a look at what you require, if you still need it that is.
Geoff
EngineDIY
