KWIL | 20/01/2015 10:21:11 |
3563 forum posts 70 photos | I am looking at page 8 of MEW 225 with Reg Merryweather's article on Parting. off in the metal lathe There is a drawing error on Fig 5 in that the parting tool should be inverted and to the right of the workpiece, but hey-ho these happen. Notwithstanding that I thought I would simulate the same procedure of mesurement on a 40mm diameter setup. When I apply a large turning force to my chuck by means of a bar inserted into thechuck key hole the maximum dip I incure is 0.0028" (c..f.Reg's 0.0190" and with the movement towards the headstock, less than 0.0010" (c.f. Reg at 0.0140" My parting blade is a flexible blade with carbide insert, mounted in a QCTP, the DTI is a 0.0001" resolution Mercer. I do not have a digging in problem but I would like to find why my results are so different from those presented in the article.
Edited By KWIL on 20/01/2015 10:23:29 |
Neil Wyatt | 20/01/2015 10:59:45 |
![]() Moderator 19079 forum posts 736 photos 80 articles | > There is a drawing error on Fig 5 in that the parting tool should be inverted and to the right of the workpiece, but hey-ho these happen. That's how the drawing was supplied and it illustrates the measurement the author made. The differences could be down to lathe type or the individual setup. I am not convinced the place where the toolpost is attached to the slide is critical - if the toolpost and slide are very rigid and effectively act as one lump of metal. Reg may have a less rigid setup, and that may be why it works for him. I think the real question with rear toolposts (which obviously do work) is that in use they try and lift the rear of the cross slide off the bed. This puts pressure on a normally no-critical bearing surface and also they apply a large twisting moment at the front guide acting to separate the main bearing surfaces, the opposite of the normal action. The lower front bearing surface has to take the largest load of all,. Should be a recipe for disaster, but it isn't - why?
A second thought - surely in normal turning the forces on the tool are the same as on a front mounted parting tool...
I am sure the parting debate will run and run! Neil Edited By Neil Wyatt on 20/01/2015 11:05:10 |
blowlamp | 20/01/2015 11:13:09 |
![]() 1659 forum posts 106 photos | Posted by Neil Wyatt on 20/01/2015 10:59:45:
I think the real question with rear toolposts (which obviously do work) is that in use they try and lift the rear of the cross slide off the bed. This puts pressure on a normally no-critical bearing surface and also they apply a large twisting moment at the front guide acting to separate the main bearing surfaces, the opposite of the normal action. The lower front bearing surface has to take the largest load of all,. Should be a recipe for disaster, but it isn't - why? Neil Because the swarf falls out of the groove by gravitational attraction
Martin. |
Muzzer | 20/01/2015 11:17:10 |
![]() 2904 forum posts 448 photos | I don't think there is any great mystery. It must be simply down to the design of the actual machine and the severity of the load. If you take a very light cut with a razor sharp tool you will barely load the machine whereas if you take a full cut with an indexable tool, you are going to want the saddle to be fully constrained against being lifted by the cutting forces. Never owned a Myford but it seems they can tolerate moderate upward loads in typical ME useage. I've looked at the design of my Bantam and there is no obvious means of constraint. Interestingly, the Colchester rear toolpost is designed for operation of the machine in both directions although I haven't bothered getting one. Personally, I don't feel the need for a dedicated rear toolpost, as I can swap tools quickly easily with the QCTP and keep the machining area clear of projecting tools - surely that is its primary benefit? However, I often machine parts with the tool behind the centre line (usually a boring bar), with the machine running in reverse. TBH, it seems to me that if you are going to make use of a rear-mounted tool, you may as well run it in reverse and keep the tool loads in the direction the machine was designed for. Murray |
JasonB | 20/01/2015 13:09:09 |
![]() Moderator 23076 forum posts 2771 photos 1 articles | Kwil I wonder if you nice M300 has anything to do with it Neil as you say the loads when turning are the same as when parting but how often do you take a 3mm depth of cut which is basically what a 3mm wide parting tool is doing. A lot of hobby lathes would also chatter etc taking that sort of cut with a turning tool. Edited By JasonB on 20/01/2015 13:12:09 |
John Stevenson | 20/01/2015 14:32:52 |
![]() Moderator 5068 forum posts 3 photos | Posted by JasonB on 20/01/2015 13:09:09: .
how often do you take a 3mm depth of cut .
Aahh you mean a finishing cut ? |
Speedy Builder5 | 20/01/2015 16:13:54 |
2653 forum posts 219 photos | I haven't read the article, but users should be aware that if you have a chuck which screws onto the headstock, it can unscrew when parting off with a rear toolpost and reverse rotation of the chuck. |
KWIL | 20/01/2015 16:15:12 |
3563 forum posts 70 photos | Jason, All measurements made on a properly adjusted Myford Super 7. Did not try the M300!! Swarf entrapment is not a problem with insert tooling, the shape of the insert makes the swarf narrower than the kerf, so entrapment is not a problem. Edited By KWIL on 20/01/2015 16:15:43 |
blowlamp | 20/01/2015 16:23:22 |
![]() 1659 forum posts 106 photos | Posted by KWIL on 20/01/2015 16:15:12:
Agreed, and that's why they can be employed as usual in the front toolpost without problems, plus the blade is quite a bit narrower than the insert which gives clearance there as well.
Martin. |
mick | 21/01/2015 17:46:29 |
419 forum posts 49 photos | Wish I had a fiver for every time there's a thread on parting! Using a rear mounted parting tool there's no need to reverse the motion as the tool is inverted, you only reverse when using an inverted parting tool in the front tool holder and yes this could spin the chuck off under some circumstances. |
Michael Gilligan | 21/01/2015 18:50:55 |
![]() 20289 forum posts 1064 photos | Posted by Speedy Builder5 on 20/01/2015 16:13:54:
If you use an inverted blade and rear tool post with normal chuck rotation, then you would suffer the same amount of chatter as using a normal too post ? . Bob, ... only if your "normal" toolpost is mounted direct on the cross-slide I think the main cause of problems is that the top-slide introduces another layer of flexibility. MichaelG. . P.S. ... The Gibraltar ToolPost looks a very sensible design ... Can anyone offer a review? Edited By Michael Gilligan on 21/01/2015 18:56:04 |
Neil Wyatt | 21/01/2015 21:08:36 |
![]() Moderator 19079 forum posts 736 photos 80 articles | I have a sub-Gibraltar toolpost for my mini-lathe that fits on the t-slotted slide. A simple cube of meehanite that has a twin-screw t-nut to attach it and takes the standard toolpost on top. It's very good but annoyingly I got the height slightly different so I have to use different shims for each tool :-/ Neil |
Danny M2Z | 22/01/2015 06:49:57 |
![]() 963 forum posts 2 photos | Nice T-slotted topslide for the mini-lathe Neil. Any more details? - Enquiring minds need to know! * Danny M * |
JasonB | 22/01/2015 07:34:24 |
![]() Moderator 23076 forum posts 2771 photos 1 articles | Neil assuming you made the bit of iron too small then why not cut a shim the full size of the block and fit it under the toolpost so you don't have to use two sets of shim for each tool? J PS it would have looked better painted yellow |
Roger Williams 2 | 22/01/2015 09:24:50 |
352 forum posts 4 photos | John Stevenson, as a bloke who does it for a living, and must have parted off hundreds of times, what are your thoughts on the subject ?. For instance, do you use power feed ?. Thanks. |
Neil Wyatt | 22/01/2015 09:37:12 |
![]() Moderator 19079 forum posts 736 photos 80 articles | > Nice T-slotted topslide for the mini-lathe Neil. > Any more details? - Enquiring minds need to know! Yes - if you want to keep your sanity, don't do it. I chewed it out of a block of CI making the bottom to match they existing slide (plus recess so it can come further back over the index) and then three t-slots in the top. Would be an easy job on a mill, but I used a taig/peatol vertical slide... Jason I hate unsecured shims, actually with most tools it takes a 1/16" shim so it's not a big issue. The green is good old Humbrol Brunswick green I use for various home-made accessories More pics here Neil Edited By Neil Wyatt on 22/01/2015 09:40:26 |
Ian S C | 22/01/2015 11:12:57 |
![]() 7468 forum posts 230 photos | My theory for jamb ups when parting is that the side of the tool wears a few thou, more at the tip than further back(more use), and when a deep cut is made in one go is when the danger occurs, hense the idea of taking a second cut to widen the slot. This is with HSS tooling, carbide tools should be no problem. Ian S C |
Gordon W | 22/01/2015 14:05:42 |
2011 forum posts | I was asking for help re parting-off only a couple of years ago, but here is what I have found, - My lathe has 3/4 hp motor but not really enough power for parting steel with an insert tool. HSS tool ground with side clearance and 2mm wide or less work well. But cannot have top rake ground or the clearance is lost. I ground a bit more front clearance and tilt the cutter to get some top rake. Like IanSC I take an extra side cut to widen the groove when needed. To me it seems obvious that the more joints they are in the set-up the less rigid it will be. I have been looking for a bit of heavy steel to make a one piece toolholder and not use the top-slide. I don't have slots on the cross-slide, just 2 x 6mm bolts to hold top-slide or toolpost, so need a flange for mounting,hence steel so it can be welded up solid. Do not use shims if possible, one thick one if must, just an extra 2 joints. Slow speed, slower than normal, just to keep down vibration which is difficult to stop once started. |
KWIL | 22/01/2015 16:26:37 |
3563 forum posts 70 photos | Gordon, Which lathe do you have? I can chew through steel with only 3/4 hp motor using inserts on a Myford Super 7 running around 400 rpm, |
Gordon W | 22/01/2015 16:46:47 |
2011 forum posts | Chester DB8, older belt drive ( which I like ) 8" dia. max. The toolbit is 3mm wide I think, can't get at it now. No roof and 2" ice. 400 revs ok at 1" dia maybe but 200 better ie less vibration. A "V" section tool is easier on steel. I 'm not into mass production tho'. Every thing is better if all gibs etc. are tight but not always very practical. |
