SarahJ | 18/01/2015 16:52:34 |
19 forum posts 2 photos | Hi, I would like to make a start on Stewart Hart's Vertical Mill Engine. In the drawing of the cylinder, there are four M3 tapped holes in each end for the cylinder covers. The drawing doesn't show how deep to drill/tap into the cylinder, I was going to drill the holes 8mm deep and tap into that by 6mm. Does that sound okay? One other point I was wondering about was the 3mm dia hole into each end of the cylinder for the two steam passages. This leaves a wall thickness of 1mm between the cylinder wall and the steam passage. I could reposition the hole slightly to give a slightly thicker wall thickness of 1.4mm. I was just concerned about when drilling the hole the drill bit wandering. Any thoughts on this? Many thanks, Sarah
JasonB | 18/01/2015 17:45:00 |
![]() Moderator 20283 forum posts 2218 photos 1 articles | Welcome to the forum Sarah I'm sure Stew himself will be along at some time but those depths sound fine to me. Again the drilled passages could be moved if you wished, I think as shown the hole comes mid way between the cylinder bore and the flat surface the valve chest mounts to so just watch the outside. A good sharp drill should not wander too much it helps to retract the drill quite often to clear any swarf and also a little lubrication in the way of parafin or WD40 will help too. J Edited By JasonB on 18/01/2015 17:54:01 |
Stewart Hart | 18/01/2015 18:53:22 |
![]() Moderator 656 forum posts 354 photos | Hi Sarah
Pleases to her that you've made a start on the vertical, the depths you've suggested will be fine, sorry I missed the depth off the drawing. The passage is a bit close if you want to give yourself a bit more space by all means move it over a bit and it wont arm if you drill it 2.5mm, and follow Jason's good advice.
I hope you enjoy the build.
Stew
SarahJ | 18/01/2015 19:01:50 |
19 forum posts 2 photos | Hi Jason and Stewart, Thanks for your replies. Another question for you if that's okay. When drilling/tapping the eight M2 holes in the cylinder for the Valve Chest, I calculate that there is 5.86mm depth of material for the tapped holes. What depth would be suitable for drilling and tapping. Regards, Sarah |
JasonB | 18/01/2015 19:27:23 |
![]() Moderator 20283 forum posts 2218 photos 1 articles | A good rule of thumb is that you want 1.5times the dia of thread in the part so for a M2 thread you want 3mm of thread. Now its almost impossible to thread right to the end of your hole so I would say drill 4.5mm deep and tap until you feel the tap won,t turn any more. One thing I do with a lot of my small taps is grind off the pointed end as that usually allows you to get a bit deeper into a blind hole, not enough to cut into the teeth but just enough to remove the pointed end |
SarahJ | 19/01/2015 18:25:08 |
19 forum posts 2 photos | Hi Jason, Thanks for your help, I'll mark up the drawing with the depths I need. Many thanks, Sarah |
Jmccrack | 20/03/2015 14:43:39 |
9 forum posts | Stewart. I am looking for the material list for this project. Has it been published yet?
Stewart Hart | 20/03/2015 14:50:44 |
![]() Moderator 656 forum posts 354 photos | Hi its on the home page towards the bottom on the right or click below Materials List Edited By JasonB on 20/03/2015 15:20:50 |
Mad muppet | 26/06/2016 09:35:20 |
9 forum posts 118 photos | Good morning All. Help please How can I obtain a set of drawings for the cross vertical engine. Regards Mad Muppet
JasonB | 26/06/2016 09:51:29 |
![]() Moderator 20283 forum posts 2218 photos 1 articles | If you ask Stew nicely he may sort you out. |
Eric Cox | 26/06/2016 10:46:00 |
![]() 529 forum posts 35 photos | Sarah, for material you will find 5" pipe for the flywheel here .ebay.co.uk/itm/Mild-Steel-Pipe-127mm-5-x-3mm-450mm-long-Chimney-Round-Tube-/291164852350?pt=LH_DefaultDomain_3&hash=item43cac7107e and aluminium plate here ebay.co.uk/itm/Aluminium-Flat-Bar-Plate-width-from-120mm-to-250mm-many-thicknesses-and-lengths-/151080276666?pt=UK_BOI_Metalworking_Milling_Welding_Metalworking_Supplies_ET&var=450190730544&hash=item232d1612ba usual disclaimer |
Mike Bondarczuk | 27/06/2016 19:14:49 |
91 forum posts 6 photos | Hi Sarah, I am just putting the finishing touches to the Stewart Hart Horizontal engine and will be starting the vertical engine build once completed. I hope that you will be posting a build log so that I can follow your progress as well as any hints, tips or get-me-out-of-jail situations you come across. I have posted a short video of my engine on the Model Engine Maker forum and have entered it into the built from plans section, so you are welcome to have a look. I may also post it on this site if I can find a way of attaching a YouTube video, and a full build log will follow shortly together with the cosmetic changes I made to the original design. Mike |
JasonB | 27/06/2016 19:20:42 |
![]() Moderator 20283 forum posts 2218 photos 1 articles | Mike have a look part way down this page on how to post youtube video. Or ask me to do it |
Dullnote | 13/02/2021 16:44:48 |
![]() 92 forum posts 28 photos | Hi hope this works, first run for the engine today, not completed but enough to get it alaive
Dullnote | 13/02/2021 16:45:35 |
![]() 92 forum posts 28 photos | |
Steviegtr | 13/02/2021 16:51:37 |
![]() 1975 forum posts 268 photos | Posted by Dullnote on 13/02/2021 16:45:35:
JUST TRIED TO VIEW & IT SAYS THE VIDEO IS PRIVATE. Steve. |
Dullnote | 13/02/2021 16:53:13 |
![]() 92 forum posts 28 photos | I will have a look though it was anyone who had link
Dullnote | 13/02/2021 16:54:22 |
Steviegtr | 13/02/2021 16:55:52 |
![]() 1975 forum posts 268 photos | Yes but that is not a link. It is just the address to put in the search bar. I always set my videos to anyone can view. Steve. Edited By Steviegtr on 13/02/2021 16:56:36 |
Steviegtr | 13/02/2021 16:57:24 |
![]() 1975 forum posts 268 photos | No still not able to view. Steve. |
