Portable steam cleaner
Rik Shaw18/11/2014 17:03:53
1469 forum posts
398 photos
Has anyone got one of those hand held portable steam cleaners the like they sell in ALDI or WILKO? Would it be man enough to remove seventy five years of accumulated black tarry oil deposit as seen within my shaper table?
Rik
Edited By Rik Shaw on 18/11/2014 17:11:47
Edited By Rik Shaw on 18/11/2014 17:17:16
Neil Wyatt18/11/2014 17:13:11
18894 forum posts
734 photos
80 articles
Perhaps you should get English Heritage to organise an archaeological investigation first!
Neil Wyatt18/11/2014 17:18:35
18894 forum posts
734 photos
80 articles
Howi18/11/2014 17:34:50
332 forum posts
19 photos
Well! You could suck it and see, if it won't, give it to your wife for Christmas devil.
With 75 years wirth of crud, you might be better off with a thermal lance.........
Peter Tucker18/11/2014 17:49:45
183 forum posts
Hi Ric,
I don’t know the particular cleaners you are looking at however some time ago my wife bought a handheld steam cleaner which proved to be absolutely useless so I would strongly recommend that you do not waste your money on one of these.
Best of luck.
Peter.
Phil Whitley18/11/2014 19:26:27
1394 forum posts
147 photos
we have a polti vaporetto, steam cleaner which is excellent on carpets and car interiors, it easily delivers enough steam to make short work of this, but you would need to glove up!
Phil
frank brown18/11/2014 20:04:14
436 forum posts
5 photos
I suspect that because of the high conductivity of the iron, the steam will condense into water, except for the steam that escapes to rust your other tools. We have a Vax floor steam cleaner for our kitchen tiles. Its operator says its very good. Can you not borrow a steam wall paper stripper?
Frank
Mike Poole18/11/2014 20:23:46
3162 forum posts
72 photos
I think if anyone in your area still has a hot caustic tank it would be worth a small fee rather than spend time and money on other cleaning methods, engine refurbishers could well be the people to contact.
houstonceng18/11/2014 20:26:52
38 forum posts
We have a Polti Vaporetto and I agree it's great on carpets, floor tiles, tiled walls, etc.
However, when I tried to clean the really mucky club loco and, at another time, the alloy wheels on my car, I found that the steam immediately turned to water and it was useless for these tasks.
Try some solvent - eg caustic soda or paraffin with the usual precautions - and a bit of El Bow grease.
FMES18/11/2014 22:16:07
607 forum posts
A visit to your local car garage to enquire about using a proper steam cleaner would be more of use.
I have a Kaarcher Diesel powered high temperature water (95deg) @ 140 bar that will strip paint from an engine block in seconds.
Take some rust preventer with you as it will get a surface coat of corrosion before you get it back in the boot of your car.
Gordon W19/11/2014 09:56:45
2011 forum posts
Use Gunk or similar cleaner, then pressure washer, might take a couple of goes but it will work. PS best to use next doors drive.
walker midge
JD Metals
rapid Direct
