Humbrol Paint
Nick_G07/11/2014 15:48:59
1808 forum posts
744 photos
Are the range of Humbrol enamel paints suitable for painting a model steam engine that later in it's life may have 'live steam' fed to it.
Basically is it capable of being used at the temperatures the cylinder will achieve and of course able to resist oil.
Also would 'real' engines have been finished in a gloss or a more satin paint.?
Cheers, Nick
JasonB07/11/2014 15:56:04
22751 forum posts
2653 photos
Should be OK with Humbrol thats whatI used on my couple of Stuarts. Brunswick green is about right.
Too glossy a finish can look a bit toy like but if you spray teh Humbrol the thinners helps to knock off a bit of teh sheen. Phoenix are also worth looking at.
So is it all done and ready for paint then?
Nick_G07/11/2014 16:09:00
1808 forum posts
744 photos
Posted by JasonB on 07/11/2014 15:56:04:
Yeahhh, course.! cheeky
Nick
Neil Wyatt07/11/2014 16:32:25
19037 forum posts
734 photos
80 articles
Isn't there a law against using anything other than Humbrol 3 Brunswick Green and 21 Gloss Black for Stuart engines?
Kevin Bennett07/11/2014 16:39:48
193 forum posts
56 photos
hi I use RUSTINS paint search for ruskins Buckingham green paint on eBay I have found it very good and the finish is a nice gloss
Kevin
Vic07/11/2014 18:20:50
3074 forum posts
8 photos
Posted by Neil Wyatt on 07/11/2014 16:32:25:
Oh yes.
^^^ Kevin^^^ is in real trouble now! smiley
JasonB07/11/2014 18:29:43
22751 forum posts
2653 photos
Actually I've seen a few Stuarts in blue that look quite nice. Cream would also look good on the table engine. Or our German friends like a touch of satin black which is OK but they do tend to buff up the brass a bit too much for my liking.
Boiler Bri07/11/2014 18:52:15
842 forum posts
199 photos
I painted my first traction engine with Humrol. Worked a treat and never had a problem, apart from runs and streaks from using a brush!
I am not sure if it is still made in the uk at Hull or not! 😚 maybe Hornby have moved it to China like all their other stuff.
FMES07/11/2014 18:58:27
608 forum posts
Hi Nick,
I use Humbrol enamel on my engines, the gloss black is good on the cylinders, I've seen oil boiling on mine,but reds tend to discolour after a while and give that well used look.
Nick_G07/11/2014 19:16:44
1808 forum posts
744 photos
Pink.!!!!! surprise
Yup deffo pink. It will be errrrrrrrrr, well, unique don't you all think.? devil indecision
Nick winkwinkwink
Vic07/11/2014 19:24:34
3074 forum posts
8 photos
Can I hijack this thread a minute and ask what you can add to Gloss paint to give it a Satin finish instead?
Nick_G07/11/2014 19:39:37
1808 forum posts
744 photos
Posted by Vic on 07/11/2014 19:24:34:
I personally don't consider that a hijack in any form. - It's related to a general painting question so I would say well and truly 'on topic'
No idea what to add to the paint though. frown
Nick
JasonB07/11/2014 20:33:46
22751 forum posts
2653 photos
I think Phoenix that I linked to above do a matting agent. Accelerating the drying can also help thats what I do when using artists oils on my model figure, stand them directly under a 100w light bulb.
Gordon A07/11/2014 23:25:10
157 forum posts
4 photos
Quote from the Hornby website/news 28/11/2012 :
Humbrol’s manufacturing has been moved back to the UK from China to improve supply, and ensure high quality standards continue to be met, but from an easier location nearer to the Margate Head Office.
Gordon.
Ed Duffner08/11/2014 02:01:24
840 forum posts
94 photos
Hi Vic,
I've never tried but maybe adding satin clear to a gloss may take the edge off the sheen. Other than that you could always spray a top coat of satin over your gloss colour.
I have polished matt paint in the past to make a kind of scale lacquer finish on 1/35th armour barrels.
Ed.
Matt Homer 109/02/2016 10:37:49
51 forum posts
47 photos
Humbrol Enamel Gloss or Acrylic gloss ? ...going to start building the Myfordboy Steam engine soon so going to order some paint...thanks Matt
Neil Wyatt09/02/2016 10:52:31
19037 forum posts
734 photos
80 articles
Another quick worker!
JasonB09/02/2016 11:44:39
22751 forum posts
2653 photos
I find the solvent base enamels level out better so would go for them in preference to the acrylic if you are brushing it on.
Matt Homer 109/02/2016 13:04:07
51 forum posts
47 photos
Thanks .... got a reply from David (myfordboy YouTube)
I always use the Precision pain on my models, without any primer. Humbrol would be fine though but go for the gloss enamel although if you are going to run on steam I don't know how that one does.
Some of my friends use car spray but that is probably more expensive than precision paints.
if you want the same colour as i used it's P125 B R Southern coach green (gloss)
Robbo09/02/2016 14:15:19
1504 forum posts
142 photos
Humbrol do make a range of Satin enamels as well as Gloss, but only one green in it. The range of Matt paints is huge.
Rapid RC
Dreweatts
