James Coombes Engine
NJH | 09/02/2015 19:40:46 |
![]() 2314 forum posts 139 photos | Nick Yes - Stuart Models do sell the book. See their site - part No. :- 36-50-72466 N |
Nick_G | 15/02/2015 20:19:12 |
![]() 1808 forum posts 744 photos | . This weekend I have been making the parts that link the eccentric to the valves. So basically the bits from the brass eccentric strap up to the valve cross head. Some parts want finishing / dressing and some threads shortening but basically this section is sorted. (hopefully)
Nick |
Harry Wilkes | 15/02/2015 21:11:45 |
![]() 1024 forum posts 63 photos | Nice work it looking good. H |
ChrisH | 15/02/2015 22:01:56 |
923 forum posts 30 photos | I like I like it, very nice, you're inspiring me!! Chris |
Nick_G | 16/02/2015 10:54:10 |
![]() 1808 forum posts 744 photos | . Thanks for the nice remarks guys, Chris. Normally the only thing I have ever inspired is women wanting to stick knives in me.
Nick |
Nick_G | 20/02/2015 01:56:40 |
![]() 1808 forum posts 744 photos | . I have started doing some painting. I still have a few parts to make but these will not require paint. The reason I have started painting is I am using Humbrol enamels which I know have quite a long drying time comparison to acrylic and I figure I can make the remaining parts while each coat is drying. Question.! ......... How long should I leave the Humbrol enamel between coats.? - I know that this is temperature related and there is a difference between dry and cured paint. But if someone can put me in the ball park please.
Cheers, Nick |
Nick_G | 20/02/2015 16:30:28 |
![]() 1808 forum posts 744 photos | . Can anyone answer the paint dry / cure question.?
Cheers, Nick |
pgk pgk | 20/02/2015 16:51:10 |
2030 forum posts 290 photos | ..from humbrol's website: (the last time I used their paint was 52 years ago) Tip: Humbrol Products: Drying TimesPaints
Sprays
Weathering
JasonB | 20/02/2015 17:24:13 |
![]() Moderator 19587 forum posts 2150 photos 1 articles | Are you airbrushing, brush painting or using spary cans as the film thickness and amount of thinner in the three options will all affect drying times. Also whats the primer a sthat can affect drying too. |
Neil Wyatt | 20/02/2015 17:51:24 |
![]() Moderator 18416 forum posts 718 photos 78 articles | Fresh Humbrol dries OK, old stuff isn't so good, but adding the proper thinners (not white spirit) can improve drying times. Some ancient Brunswick green freshed up with a little thinners dried OK in a day and a half on my Parvalux. the brand new blue for the Adept dried overnight, but it was in a very warm place over a heater (about 30 degrees). both brush applied. I would allow 24 hours between coats for fresh paint at room temperature and a few days for it to fully set. Matt dries much quicker. neil |
Nick_G | 21/02/2015 09:16:59 |
![]() 1808 forum posts 744 photos | Posted by JasonB on 20/02/2015 17:24:13:
Thanks for the information chaps. Jason. I am using an airbrush with the paint thinned with enamel thinners. Using No.1 matt as a primer so far. I started at a ratio of 2 paint to 1 thinners, however I seem to get a better result when mixed 1:1 through the airbrush. I presume this may also change when I use a different paint for the top coats.? I am as you may guess new to airbrushing so I still have a lot to learn re paint types, thinning, air pressure and spraying technique for best results. - Perhaps I should remind myself I am painting a model steam engine here and not requiring the finish of a new Bentley lol I also have a supply of a 5 ltr can of cellulose thinners. But I am presuming that changing to this once a paint job has started may lead to issues with the coats already laid down.??? So I am just using that for airbrush cleaning.
Thanks, Nick |
NJH | 21/02/2015 10:23:52 |
![]() 2314 forum posts 139 photos | Nick My experience is don't apply cellulose over enamel - unless you are seeking a "crackle" finish! Norman Edited By NJH on 21/02/2015 10:25:14 |
JasonB | 21/02/2015 10:46:34 |
![]() Moderator 19587 forum posts 2150 photos 1 articles | Well I've just come in from spraying my Cameron pump, put 3 coats of Precision Paints enamel on it in about 1hrs. I was thinning about 2paint : 1 thinners, by the time all the parts had been given a first coat I could go back and apply the next. Will leave them now for a couple of hours to see what if any need a slight rub down. Don't try and cover it all in one go, several light coats will be better and then you don't risk the paint sagging. Don't use the cellulose now it will lift underlaying coats. Use it for cleaning, blow some through teh airbrush and don't have a Fag at the same time |
Nick_G | 21/02/2015 13:54:00 |
![]() 1808 forum posts 744 photos | Posted by JasonB on 21/02/2015 10:46:34:
Ooooops. ........... Too late.!!
Nick |
Nick_G | 25/02/2015 20:26:17 |
![]() 1808 forum posts 744 photos | . Painting progressing :-
Humbrol 'Crimson' No.20
Nick
Nick_G | 09/03/2015 21:09:08 |
![]() 1808 forum posts 744 photos | . Its been a couple of weeks since I last posted on my first build. So here is a bit of an update. There is a short video here :- **LINK** of me turning it over by hand. I only have the con rod left to make. But I spent a bit of time getting the correct fittings of the parts and some polishing work. (I can see from the photos even from an iPhone that more needs to be done in that area.) No more excuses the con rod is next.
Nick |
JasonB | 10/03/2015 07:29:38 |
![]() Moderator 19587 forum posts 2150 photos 1 articles | Almost there Nick and looking good. No reason to put off that conrod now. I saw this yesterday and thought it might be about the right size given what you are thinking of making next |
Nick_G | 10/03/2015 11:35:34 |
Almost there Nick and looking good. No reason to put off that conrod now. I saw this yesterday and thought it might be about the right . Fantastic. But unfortunately I dont have £2K to play with ATM. Nick |
KWIL | 10/03/2015 14:41:26 |
3337 forum posts 63 photos | Hang on, you are talking about Station Road Steam, what did you expect? |
Nick Grant | 10/03/2015 15:03:58 |
32 forum posts | Looking beautiful, that shade of red really sets it off |
