Here is a list of all the postings Hacksaw has made in our forums. Click on a thread name to jump to the thread.
Thread: Wheel flanges |
21/04/2021 16:56:55 |
I've remembered , i have some smaller gears salvaged from an angle grinder ...! They might do |
21/04/2021 16:46:49 |
I bunged one in my lathe this morning , it turns beautifully .. Must be old English cast iron !! Not even a hard skin or blow hole . Just messy black mess... The chart that Duncan linked to , says overall width of a 3 1/2 " gauge wheel is 0.375 " - 9.5 mm . I reckon it's possible ! There isn't any wobble - run out , a think they'll skim up ok and still be wide enough . However... the hand drill bevel gear is a larger diameter than my wheels..?? I hadn't thought about that ..Any way around that ? Edited By Hacksaw on 21/04/2021 16:48:23 |
20/04/2021 22:25:49 |
Posted by Steviegtr on 20/04/2021 22:15:10:
Are you sure they are cast & not forged steel. Not sure the difference machining though. Steve. Yup, i hit it with a hammer and it broke one . only have 15 left .. |
20/04/2021 22:12:15 |
I think i know the answer really ... but i was having some thoughts..
Would there be enough meat on these roller door wheels to turn into loco wheels ? They're just shy of 75mm dia and 10mm wide .. The flange does appear to be cast a little thicker /deeper on the inner side , so that side would be the tread . I was only thinking Kerr Stuart 060 diesel type , 12v battery , hand drill bevel gears , something simple anyway ... ! Edited By Hacksaw on 20/04/2021 22:12:59 |
Thread: Lotus 7 and Mini 2 cylinder |
19/03/2021 22:41:06 |
Doh . can't link it ..here's the title " 2 cylinder Mini prototype engine ?! 1957 - Ivan's shed " |
19/03/2021 22:35:57 |
Old school car restorer videos... 1957 Lotus 7 https://www.youtube.com/watch?v=kat79zrVDQg
Same old fella with a prototype 2 cyl A series type Mini engine.. !! There are several videos on there if it interests you ! |
Thread: Mystery Woodwork Tool! |
01/03/2021 20:45:17 |
When i were a schoolboy, i made a folding wood work bench . Teach said it would last me a lifetime , old school enthusiastic teacher he was . . After exams , i stayed on a bit , finishing stuff i'd made . Teach, suggested i make i wooden vice for the bench too , thread an' all , as he had the tap and die to suit ... I can't remember what the die was like , or the selected wood for the screw , but it cut beautifully . The clamp bits were beech, if i remember . Now, either the tap was blunt ,or it was rubbish wood , but the internal thread was rough as a badgers ... Any way , once the screw was in,and the vice assembled , you couldn't see it anyway ! It worked fine ,sort of.... with a bit of candle fat ... until it got damp in the garage after i'd left school , and i snapped the tommy bar tying to open it ! Threw the whole lot away , good old Black n Decker workmate since |
Thread: Micro rivets |
07/02/2021 15:16:18 |
I've removed the engine ! Low mileage i guess ,but the oil is a bit low on the dipstick , and compression is low ... gummed rings I daresay , ruddy 1950's monograde oil...
Sweet innit ? |
03/02/2021 19:12:20 |
They're magnetic real rivets holding it together .. |
03/02/2021 16:04:07 |
Thanks . I've found the rivet squeezer ! Interesting possibility |
03/02/2021 15:33:46 |
More pics sump side of the engine
Axle
Fan side of radiator ,engine and gearbox mount . Dipstick ..Pulleys and fan do actually rotate !
Size wise ..that's an AA battery on the top.. so you can see there ain't a lot of room for hammering a rivet !!
Edited By Hacksaw on 03/02/2021 15:46:21 Edited By Hacksaw on 03/02/2021 15:48:13 |
03/02/2021 14:46:03 |
Thank you so much for the replies ! Every idea mentioned i have already thought about !! Tim S , the micrometer / hollow G clamp screw idea .. i thought of that too ! I was thinking I could use a modified automatic centre punch pushed down the hollow screw to clench the rivet ?? The existing rivets are magnetic , I would use soft copper or aluminium mig wire . Or buy some jewellery ones ... I Spot welding .. dummy rivet ..This i'm going to look at . Would the pieces need to be really clean , or would a belt of electric burn through any oxide ? Something like they use to weld Ni-cads tags together ? All food for thought.. I do have a new front axle my dad made , and front springs ,wheels , dampers , steering wheel and other bits .. that were detached . I have no interest in buses or coaches .. I paid about 40 quid for it at Maidstone Toy fair diecast swap meet , to give to my dad , around 20 years ago . He's dead now , he never did repair it ... so i claimed it back .. It is exquisite , maybe its beyond me to repair it , being honest , I would like it to go eventually to a museum or something , i suppose . I've just seen on TV , Antiques hunt thing , from Lewis in Sussex .( I'm in love with that Christina chick..  |
02/02/2021 23:12:58 |
Here you can see twisted wire holding the crossmember together ! How the hell am i going to re -rivet that ! |
02/02/2021 22:57:34 |
I'm trying to restore an old model bus chassis . Pretty sure its a Harrington Contender Integral chassis .. with a Rolls Royce B80 petrol engine . Who ever built it was a fabulous modeller . Perhaps it was for a motor show display . However , I guess it has been dropped .. It's constructed as per original , aluminium and rivets ... 100's of them! And quite a few have either pulled through, or just missing .And the chassis is flopping about .. They're about 1mm dia..and iron.. A lot of the ones that need replacing , are in an awkward place .. I don't suppose there's a tool , i 'm imagining something . say like a stapler..or a goose necked stapler .. or something like a leather punch shape .. that could set a rivet ? Any ideas ? If not , i'll make a snap and set , but it'll be bloomin awkward ..i'll have to get another pair of hands to hold it !! I don't really want to just glue it back together . Thanks
Thread: Making a cast of a blind hole |
05/01/2021 16:55:51 |
Polymorph |
Thread: Salvaging Useful Parts from Printers |
01/06/2020 22:32:40 |
That lovely bar of free cutting steel in the dead printer you always have to prise out before throwing it away ? It's now just a thin wall tube.... However , the smaller one , hooked up to a solar panel battery maintainer , gives amazing torque ! I was then thinking what could it power in the garden this summer ? A water pump for the water butt ? A fan in the pergola ? A RTP aeroplane ? A RTP car on the patio ? A fake beam engine in the middle of the lawn ? Watch this space !!
Any other ideas ? Edited By Hacksaw on 01/06/2020 22:37:12 |
Thread: Whatever happened to... |
22/04/2020 19:10:27 |
Morrissons started stocking Lemon puff biscuits last year remember them? 60p..I was buying 6 packets at a time . Even the older biddy on the till said " Corr i haven't seen those for years ! " If you leave them open they go all sticky and more lemony ...lovely .. Then the price went up to £1.20 over night , and has been ever since , so sorry Mr Morrisson , i'm not paying that much no matter how nice they are.. Edited By Hacksaw on 22/04/2020 19:11:20 |
Thread: Coronavirus |
18/03/2020 07:01:22 |
Wild bat meat ! |
Thread: Tuna Can Blower |
22/01/2020 18:17:20 |
Granny knickers |
Thread: Electric motor ratings |
08/01/2020 20:06:20 |
A 100w Marshall amp is more powerful than a Fender 100w because the knob can go to 11... fact |
