Here is a list of all the postings Hacksaw has made in our forums. Click on a thread name to jump to the thread.
Thread: Making a cast of a blind hole |
05/01/2021 16:55:51 |
Polymorph |
Thread: Salvaging Useful Parts from Printers |
01/06/2020 22:32:40 |
That lovely bar of free cutting steel in the dead printer you always have to prise out before throwing it away ? It's now just a thin wall tube.... However , the smaller one , hooked up to a solar panel battery maintainer , gives amazing torque ! I was then thinking what could it power in the garden this summer ? A water pump for the water butt ? A fan in the pergola ? A RTP aeroplane ? A RTP car on the patio ? A fake beam engine in the middle of the lawn ? Watch this space !!
Any other ideas ? Edited By Hacksaw on 01/06/2020 22:37:12 |
Thread: Whatever happened to... |
22/04/2020 19:10:27 |
Morrissons started stocking Lemon puff biscuits last year remember them? 60p..I was buying 6 packets at a time . Even the older biddy on the till said " Corr i haven't seen those for years ! " If you leave them open they go all sticky and more lemony ...lovely .. Then the price went up to £1.20 over night , and has been ever since , so sorry Mr Morrisson , i'm not paying that much no matter how nice they are.. Edited By Hacksaw on 22/04/2020 19:11:20 |
Thread: Coronavirus |
18/03/2020 07:01:22 |
Wild bat meat ! |
Thread: Tuna Can Blower |
22/01/2020 18:17:20 |
Granny knickers |
Thread: Electric motor ratings |
08/01/2020 20:06:20 |
A 100w Marshall amp is more powerful than a Fender 100w because the knob can go to 11... fact |
Thread: Anyone with a surface grinder near Leeds? |
06/01/2020 22:27:06 |
Quick question from the side pls... what machine could re face my anvil . Would a surface grinder throat accommodate 18" or so ? What machine is used to deck a car engine block ? The anvil has a hardened face , but not particularly hard.. 2 1/2 cwt anvil maybe 1 /8" hollow in the middle of the face... Edited By Hacksaw on 06/01/2020 22:30:24 |
Thread: Satellites going over Kent Sussex |
29/12/2019 19:54:06 |
Ah, that'll be them that I saw ..I hadn't seen that report .
29/12/2019 19:36:10 |
I was outside having a fag , and a string of satellites went over ,about 18.30 tonight .. one after the other , for around 10 minutes . Not as bright as the space station , but easily visible . Not seen them before , what are they for then ? |
Thread: Archiving old data |
25/12/2019 16:21:38 |
I can see a hell of a lot of personal photos / images which will one day be historically important / interesting to someone just lost and forgotten... |
Thread: Long bed lathes affected by the tide |
29/11/2019 20:24:24 |
The friend was based in Southampton , I assumed Vospers were there too. We were actually talking about thread cutting on a lathe , 2 start threads and stuff .. Disappearing indoors , he came out with a 1" dia bolt and nut , in bronze .. "I made this as a test piece when i was at Vospers" says he It was a 4 start, one turn, over about 4" length acme threaded bolt . "When it's oiled and clean , the nut will descend slowly down the thread under gravity ...." Edited By Hacksaw on 29/11/2019 20:39:23 Edited By Hacksaw on 29/11/2019 20:40:05 |
29/11/2019 16:32:00 |
I'll avoid using my lathe then ,if the river is bursting it's banks in the valley down below . It is most likely why bits i make on it are a bit rubbish
29/11/2019 14:14:53 |
Seeing the seismic thread reminded me ...I was talking to a friend of mine , he had a decent apprenticeship with Vospers in the 70's . Their long bed lathes , really big stuff here , he said, only turned (say a propshaft for example ) accurately either when the tide was in or out ? And certain jobs would have to be fitted in around the tide .. Is that true ? |
Thread: Rod Stewart's Model Railway |
26/11/2019 21:24:48 |
Posted by Neil Wyatt on 24/11/2019 16:16:12:
Posted by Grindstone Cowboy on 13/11/2019 18:54:11:
I'm quite impressed by his modelling skills! Elsewhere I commented that he obviously has a fine eye for colour. (At the risk of upsetting some, all his best stuff was done with the Faces, Jeff Beck etc. Neil Quite right Neil , and also utterly off topic , I found this on youtoob.. Rod Stewart & Dennis Law , Angel. They do look alike ? Jeff beck lives in the next village from me and drives a blue 32 hotrod |
24/11/2019 17:39:01 |
The Faces and The Who were renowned for wrecking hotel rooms.. but that's ok ,its rock n roll |
Thread: 5 speed Hacksaw |
11/11/2019 22:35:28 |
Funny thing i've just read ! . On another forum I frequent , a member was wondering what became of his fathers " 5 speed hacksaw " . It was just an ordinary hacksaw , but the wooden handle had broken ...so it was replaced with the gear knob from an Austin Maxi... |
Thread: portable LED floodlight , power source ? |
26/10/2019 17:07:19 |
Thanks chaps , i know you'd have milled out a perfect flange to slide and lock the battery pack on .
I'm a cowboy, so i made it from wood, polymorph ,banana skins and bogies...but it works
24/10/2019 23:08:50 |
M.B , D.W . and F .I. thanks for the info on the constant current requirement ..
I have , (by re - using the circuit board bit ) and reconnecting the wires , hooked it up to a 16v drill battery ....And it works !!
I've chucked the old battery pack on the bonfire...as its nearly Guy Fawkes night anyway Edited By Hacksaw on 24/10/2019 23:11:17 Edited By Hacksaw on 24/10/2019 23:12:21 |
24/10/2019 22:46:14 |
But the light only runs for an hour or so on the cells and then it's 8 hrs charge ! A 12 v lead acid would run it for ages.. |
24/10/2019 22:31:55 |
They are bright , no doubt about it , but it's a horrible cold light .. The warm white gu10 led in my kitchen is a much nicer light . I want ideally , to have it on a lead , with croc clips to attach to a 12v lead acid , Just not sure what voltage the bulb would be ..I didn't want to pop it trying ! |
